petsc-dev directory structure questions
Satish Balay
balay at mcs.anl.gov
Thu Dec 13 17:07:31 CST 2007
For one, I think conf/configure.py should be ./configure.py
And conf and config are 2 different things - so they should be in
separate locations. merging them doesn't make sense to me. The primary
issue I see is the names "conf" and "config" are extremely close to
each other.
One option is to move config to src/config [this would work well with
./configure.py]
Satish
On Thu, 13 Dec 2007, Barry Smith wrote:
> Matt,
> This is a rational for the current set up (or perhaps more a
> rationalization :-))
> The reason for merging is for others attempting to understand our
> system; all the little complications add up to a system that is overwhelming
> to other people so in my mind anything that reduces the complications is
> good thing (so long as it doesn't screw up other things).
> Does anyone else have comments?
> Barry
> On Dec 9, 2007, at 10:03 AM, Matthew Knepley wrote:
> > I am cool with the division because
> > 1) config is for configuration tools explicitly
> > 2) conf is for things that customize the build
> > They have completely different things in them, and I do not see that we
> > need to merge them.
> > Thanks,
> > Matt
> > On Dec 8, 2007 10:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > Currently petsc-dev has the subdirectories
> > > bin include src conf config ...
> > > $PETSC_ARCH has the subdirectories
> > > bin include conf lib ...
> > > conf has
> > > adic.init adicmf.init base test
> > > adicmastercontrol adicmfb.init rules
> > > variables
> > > config has
> > > PETSc BuildSystem configure.py +tons of sample configure.py
> > > files for different systems
> > > I find that having both a conf and a config directory is confusing
> > > and unneeded and propose:
> > > 1) merging the config and conf directory
> > > 2) putting the ons of sample configure.py files for different systems
> > > into a subdirectory called samples
> > > Questions:
> > > 1) Does this make sense?
> > > 2) What should the directory be called? conf or config? Are there any
> > > standards that dictate/suggest
> > > one over the other? If we use config then I would like to change
> > > the $PETSC_ARCH/conf directory
> > > to match it, but would that violate some standard? I'm inclined
> > > to go with conf even though that breaks
> > > our long standing config/configure.py script to become conf/
> > > configure.py
> > > 3) This is perhaps also a good time to reopen the question of PETSc
> > > "installs": currently they go into
> > > (system independent) prefix/bin prefix/include prefix/conf and
> > > the system dependent prefix/$PETSC_ARCH/conf
> > > prefix/$PETSC_ARCH/include prefix/$PETSC_ARCH/lib If one selects
> > > a PETSC_ARCH of "" then
> > > everything ends up in prefix/bin prefix/include prefix/conf
> > > prefix/lib.
> > > The reason for this design is so that the same makefiles with
> > > includes based on PETSC_DIR and
> > > PETSC_ARCH will work in all three cases: no install of PETSc,
> > > install with PETSC_ARCH and install with
> > > PETSC_ARCH ""
> > > I know we will never get full agreement on everything, but what
> > > are the concerns with this layout?
> > > Thanks
> > > Barry
> > > Remember if I don't get comments I may do some crazy thing :-(
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
