petsc-dev directory structure questions
Barry Smith
bsmith at mcs.anl.gov
Thu Dec 13 19:41:14 CST 2007
On Dec 13, 2007, at 5:07 PM, Satish Balay wrote:
> For one, I think conf/configure.py should be ./configure.py
How come this wasn't done originally or hasn't been changed to
this already?
> And conf and config are 2 different things - so they should be in
> separate locations. merging them doesn't make sense to me. The primary
> issue I see is the names "conf" and "config" are extremely close to
> each other.
Exactly, so how the heck is anyone suppose to know what is in either
one of them?
> One option is to move config to src/config [this would work well with
> ./configure.py]
config stuff is not source code so cannot go in there.
> Satish
> On Thu, 13 Dec 2007, Barry Smith wrote:
>> Matt,
>> This is a rational for the current set up (or perhaps more a
>> rationalization :-))
>> The reason for merging is for others attempting to understand our
>> system; all the little complications add up to a system that is
>> overwhelming
>> to other people so in my mind anything that reduces the
>> complications is
>> good thing (so long as it doesn't screw up other things).
>> Does anyone else have comments?
>> Barry
>> On Dec 9, 2007, at 10:03 AM, Matthew Knepley wrote:
>>> I am cool with the division because
>>> 1) config is for configuration tools explicitly
>>> 2) conf is for things that customize the build
>>> They have completely different things in them, and I do not see
>>> that we
>>> need to merge them.
>>> Thanks,
>>> Matt
>>> On Dec 8, 2007 10:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Currently petsc-dev has the subdirectories
>>>> bin include src conf config ...
>>>> $PETSC_ARCH has the subdirectories
>>>> bin include conf lib ...
>>>> conf has
>>>> adic.init adicmf.init
>>>> base test
>>>> adicmastercontrol adicmfb.init rules
>>>> variables
>>>> config has
>>>> PETSc BuildSystem configure.py +tons of sample configure.py
>>>> files for different systems
>>>> I find that having both a conf and a config directory is confusing
>>>> and unneeded and propose:
>>>> 1) merging the config and conf directory
>>>> 2) putting the ons of sample configure.py files for different
>>>> systems
>>>> into a subdirectory called samples
>>>> Questions:
>>>> 1) Does this make sense?
>>>> 2) What should the directory be called? conf or config? Are there
>>>> any
>>>> standards that dictate/suggest
>>>> one over the other? If we use config then I would like to change
>>>> the $PETSC_ARCH/conf directory
>>>> to match it, but would that violate some standard? I'm inclined
>>>> to go with conf even though that breaks
>>>> our long standing config/configure.py script to become conf/
>>>> configure.py
>>>> 3) This is perhaps also a good time to reopen the question of PETSc
>>>> "installs": currently they go into
>>>> (system independent) prefix/bin prefix/include prefix/conf and
>>>> the system dependent prefix/$PETSC_ARCH/conf
>>>> prefix/$PETSC_ARCH/include prefix/$PETSC_ARCH/lib If one selects
>>>> a PETSC_ARCH of "" then
>>>> everything ends up in prefix/bin prefix/include prefix/conf
>>>> prefix/lib.
>>>> The reason for this design is so that the same makefiles with
>>>> includes based on PETSC_DIR and
>>>> PETSC_ARCH will work in all three cases: no install of PETSc,
>>>> install with PETSC_ARCH and install with
>>>> PETSC_ARCH ""
>>>> I know we will never get full agreement on everything, but what
>>>> are the concerns with this layout?
>>>> Thanks
>>>> Barry
>>>> Remember if I don't get comments I may do some crazy thing :-(
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
