GMRES/FGMRES and KSP_NORM_NO
Lisandro Dalcin
dalcinl at gmail.com
Wed Aug 29 11:44:27 CDT 2007
On 8/29/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You could perhaps an additional option
> -ksp_convergence_test <skip,default>
> if you like that allows turning it off from the command line.
You are completely right, I'll add this on petsc-dev.
Now, other issue, regarding this adition. Currently, passing
'-ksp_norm_type NO' ALSO set KSPSkipConverged. Should I remove that?
The 'correct way' for both features would be
$ XXX -ksp_norm_type NO -ksp_convergence_test skip
Sounds this fine?
> On Wed, 29 Aug 2007, Lisandro Dalcin wrote:
> > GMRES and FGMRES generate an error if the user sets KSP_NORM_NO? Is
> > this really needed?
> > Curently using option '-ksp_norm_type NO' is handy, as it implies
> > KSPSkipConverged being set.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
