GMRES/FGMRES and KSP_NORM_NO
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Aug 29 10:54:37 CDT 2007
  Lisandro,
     No. NORM_NO is suppose to mean that the norm computations
are turned OFF. In the gmres algorithms the norm calculation cannot
be turned off, therefore setting this flag should generate an
error as it currently does.
   Barry
 You could perhaps an additional option
-ksp_convergence_test <skip,default>
if you like that allows turning it off from the command line.
On Wed, 29 Aug 2007, Lisandro Dalcin wrote:
> GMRES and FGMRES generate an error if the user sets KSP_NORM_NO? Is
> this really needed?
> Curently using option '-ksp_norm_type NO' is handy, as it implies
> KSPSkipConverged being set.
