GMRES/FGMRES and KSP_NORM_NO
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 29 14:03:55 CDT 2007
On Wed, 29 Aug 2007, Lisandro Dalcin wrote:
> On 8/29/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > You could perhaps an additional option
> > -ksp_convergence_test <skip,default>
> > if you like that allows turning it off from the command line.
> You are completely right, I'll add this on petsc-dev.
> Now, other issue, regarding this adition. Currently, passing
> '-ksp_norm_type NO' ALSO set KSPSkipConverged. Should I remove that?
No, I think it should remain the same.
Barry
> The 'correct way' for both features would be
> $ XXX -ksp_norm_type NO -ksp_convergence_test skip
> Sounds this fine?
> > > GMRES and FGMRES generate an error if the user sets KSP_NORM_NO? Is
> > > this really needed?
> > > Curently using option '-ksp_norm_type NO' is handy, as it implies
> > > KSPSkipConverged being set.
