petsc-dev recompile needed
Barry Smith
bsmith at mcs.anl.gov
Wed Jun 28 09:41:41 CDT 2006
Mathieu,
I try to avoid I but cannot say for sure.
With hg there is an easy way to generate a patch with your
changes and then email to petsc-maint at mcs.anl.gov then we simply
apply it to the master.
Barry
On Wed, 28 Jun 2006, Mathieu Taillefumier wrote:
> Hy,
> do your modifications include variable name like I (upper i) in your
> structure. My question seems to be strange but it motivated by the fact
> that the code will not be compliant if you use a C compiler for complex
> types (Sorry for that, I am not defining the norms). In fact, I almost
> made all corrections in the code in order to compile complex version of
> PETSC with gcc (icc works also), but I didn't send any modifications
> just because of time. The number of modified files is little and mostly
> it corresponds to give a different name to the variables. I will do this
> job again on the last development version of the library and send the
> modified files to the mailing list if I don't find any others ways.
> A second point should be noticed. I use the library (complex type
> compiled with C compiler) and it seems to work correctly. At least I
> didn't have any difference in the results. However, i think that this
> option should be used with caution.
> Mathieu
>> I have changed some of the data structures for the various AIJ matrix
>> formats. On you next pull you will need to recompile all the matrix
>> code.
>> cd src/mat
>> make ACTION=libfast tree
>> Let me know if the behavior of the matrices changes due to me update
>> to the code.
>> Barry
>> I'm starting to get the various AIJ matrices to shared more common data
>> structures and code.
