new PETSc release
Barry Smith
bsmith at mcs.anl.gov
Thu Apr 28 14:35:24 CDT 2005
Portable, Extensible Toolkit for Scientific Computation (PETSc)
http://www.mcs.anl.gov/petsc
We are pleased to announce the release of the PETSc 2.3.0
The CHANGES in this release are a bit more extensive then usual.
1) You MUST use config/configure.py to install PETSc, see
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
2) The BOPT option to determine optimization/debugging and C/C++ compiles
is GONE. Now you use a different PETSC_ARCH (for example linux-g and
linux-O) for different optimizations and set the optimization as a
config/configure.py option. See
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/changes/230.html
3)* The prototypes of many methods, for example VecScale, MatShift, ... have
been changed to take the Vec or Mat object as the FIRST argument, otherwise
the arguments are the same as before. See
for a complete list of the functions changed.
As always, please send bug reports, questions, and requests for new
features to petsc-maint at mcs.anl.gov.
Thanks for your continued support.
The PETSc developers,
* this change was made to make all the PETSc calls more "object oriented"
so we could have the same calling sequences for our new PYTHON PETSc binding.
More information about the petsc-announce
