Error when compiling with SGI MPT
Jim Edwards jedwards at ucar.edu
Mon Jan 24 16:22:21 CST 2022
Hi Alvin,
I don't know if this will help but we use pnetcdf with mpt regularly
without a problem.   I can send you build details if you like.
On Mon, Jan 24, 2022 at 3:07 PM Alvin Christopher Galang Varquez <
varquez.a.aa at m.titech.ac.jp> wrote:
> Greetings,
> I have been using intel-mpi with PnetCDF and would like to explore
> compiling it using SGI MPT.
> When I run the make check and ptest in batch queue system, I got the
> following error in the src/utils/ncvalidator/test-suite.log :
>    PnetCDF 1.12.2: src/utils/ncvalidator/test-suite.log
> # TOTAL: 2
> # PASS:  0
> # SKIP:  0
> # XFAIL: 1
> # FAIL:  1
> # XPASS: 0
> # ERROR: 0
> .. contents:: :depth: 2
> XFAIL: xfail_runs.sh
> MPT ERROR: Failed to execute ./ncvalidator on host r1i5n3 (errno:2)
> XFAIL xfail_runs.sh (exit status: 1)
> FAIL: wrap_runs.sh
> MPT ERROR: Failed to execute ./tst_open on host r1i5n3 (errno:2)
> FAIL wrap_runs.sh (exit status: 1)
> Compilation settings:
> module load cuda intel mpt cmake
> export MPICC=mpicc
> export MPIF77=mpif90
> export MPIF90=mpif90
> export MPICXX=mpicxx
> export CFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
> export CXXFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
> export FFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
> export FC=mpif90
> export FF=mpif90
> export CXX=mpicxx
> export F77=mpif90
> export F90=mpif90
> export CC=mpicc
> ./configure --prefix=(full path)/pnetcdf-1.12.2 --enable-fortran
> --enable-large-file-test LIBS=-lmpi
> The relevant error in the make check is,
> make[5]: Entering directory '(full
> path)/pnetcdf-1.12.2/src/utils/ncvalidator'
> FAIL: wrap_runs.sh
> Testsuite summary for PnetCDF 1.12.2
> # TOTAL: 2
> # PASS:  0
> # SKIP:  0
> # XFAIL: 1
> # FAIL:  1
> # XPASS: 0
> # ERROR: 0
> See src/utils/ncvalidator/test-suite.log
> Please report to parallel-netcdf at mcs.anl.gov
> Makefile:950: recipe for target 'test-suite.log' failed
> Thank you for your time.
> Best regards,
> Alvin
> Varquez, Alvin Christopher Galang
> Associate Professor
> Department of Transdisciplinary Science and Engineering
> Global Scientists and Engineers Program
> Tokyo Institute of Technology
> Ishikawadai Building 4 Rm. 403 (mailbox: I4-9)
> 2-12-1 Ookayama, Meguro-ku, Tokyo 152-8552, Japan
> Tel/Fax: +81-3 5734-2462 or 2768 (local: 2462 or 2768)
> E-mail: varquez.a.aa at m.titech.ac.jp
> Web: *http://educ.titech.ac.jp/tse/eng/faculty/
> <http://educ.titech.ac.jp/tse/eng/faculty/>*
> The content of this email is confidential and intended for the recipient
> specified in the message only. It is strictly forbidden to share any part
> of this message with any third party, without a written consent of the
> sender. If you received this message by mistake, please reply to this
> message and follow with its deletion, so that we can ensure such a mistake
> does not occur in the future.
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20220124/a39abab3/attachment-0001.html>
