Error when compiling with SGI MPT
    Alvin Christopher Galang Varquez
    varquez.a.aa at m.titech.ac.jp
    Mon Jan 17 21:40:34 CST 2022
Greetings,
I have been using intel-mpi with PnetCDF and would like to explore
compiling it using SGI MPT.
When I run the make check and ptest in batch queue system, I got the
following error in the src/utils/ncvalidator/test-suite.log :
   PnetCDF 1.12.2: src/utils/ncvalidator/test-suite.log
# TOTAL: 2
# PASS:  0
# SKIP:  0
# XFAIL: 1
# FAIL:  1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
XFAIL: xfail_runs.sh
MPT ERROR: Failed to execute ./ncvalidator on host r1i5n3 (errno:2)
XFAIL xfail_runs.sh (exit status: 1)
FAIL: wrap_runs.sh
MPT ERROR: Failed to execute ./tst_open on host r1i5n3 (errno:2)
FAIL wrap_runs.sh (exit status: 1)
Compilation settings:
module load cuda intel mpt cmake
export MPICC=mpicc
export MPIF77=mpif90
export MPIF90=mpif90
export MPICXX=mpicxx
export CFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
export CXXFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
export FFLAGS='-O3 -xHost -ip -no-prec-div -static-intel'
export FC=mpif90
export FF=mpif90
export CXX=mpicxx
export F77=mpif90
export F90=mpif90
export CC=mpicc
./configure --prefix=(full path)/pnetcdf-1.12.2 --enable-fortran
--enable-large-file-test LIBS=-lmpi
The relevant error in the make check is,
make[5]: Entering directory '(full
path)/pnetcdf-1.12.2/src/utils/ncvalidator'
FAIL: wrap_runs.sh
Testsuite summary for PnetCDF 1.12.2
# TOTAL: 2
# PASS:  0
# SKIP:  0
# XFAIL: 1
# FAIL:  1
# XPASS: 0
# ERROR: 0
See src/utils/ncvalidator/test-suite.log
Please report to parallel-netcdf at mcs.anl.gov
Makefile:950: recipe for target 'test-suite.log' failed
Thank you for your time.
Best regards,
Alvin
Varquez, Alvin Christopher Galang
Associate Professor
Department of Transdisciplinary Science and Engineering
Global Scientists and Engineers Program
Tokyo Institute of Technology
Ishikawadai Building 4 Rm. 403 (mailbox: I4-9)
2-12-1 Ookayama, Meguro-ku, Tokyo 152-8552, Japan
Tel/Fax: +81-3 5734-2462 or 2768 (local: 2462 or 2768)
E-mail: varquez.a.aa at m.titech.ac.jp
Web: *http://educ.titech.ac.jp/tse/eng/faculty/
<http://educ.titech.ac.jp/tse/eng/faculty/>*
The content of this email is confidential and intended for the recipient
specified in the message only. It is strictly forbidden to share any part
of this message with any third party, without a written consent of the
sender. If you received this message by mistake, please reply to this
message and follow with its deletion, so that we can ensure such a mistake
does not occur in the future.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20220118/ce6f02eb/attachment.html>
More information about the parallel-netcdf
