1.8.1 pnetcdf problem with relax-coord-bound
Michael MINETER
m.mineter at ed.ac.uk
Wed Jun 10 06:41:52 CDT 2020
Hi
I am installing specific versions of netcdf and pnetcdf to run the model CESM2.
I've hit a problem and would welcome your guidance please.
CESM requests pnetcdf 1.8.1 which I had built and tested with no problem with OpenMPI10.1.1 and gnu compilers.
However I then discovered that netcdf -c needs to be configured with enable-relax-coord-bound
After the configure and make steps, the test "make ptest" then fails at the first test.
Comparing the successful (without the enable-relax...) and that with -- enable-relax-coord-bound :
< *** TESTING C pres_temp_4D_wr for writing file ------ pass
< *** TESTING C pres_temp_4D_rd for reading file ------ pass
And with the enable-relax-coord-bound:
> *** TESTING C pres_temp_4D_wr for writing file ------ Error: pres_temp_4D_wr.c at line 263: NetCDF: Index exceeds dimension bound
> Error: pres_temp_4D_wr.c at line 265: NetCDF: Index exceeds dimension bound
> fail with 16 mismatches
Do I have to amend the test files or command in some way now I have used the enable.,.. option in configure?
Apologies if this is documented - I have been unable to find it if so.
Thanks for your attention
Mike
Dr Mike Mineter
School of GeoSciences
University of Edinburgh
Crew Building (room 315)
The King's Buildings
Alexander Crum Brown Road
Edinburgh
EH9 3FF
+44 (0) 131 651 9094
The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20200610/5215790a/attachment.html>
More information about the parallel-netcdf
