1.8.1 pnetcdf problem with relax-coord-bound
Jim Edwards jedwards at ucar.edu
Wed Jun 10 19:17:34 CDT 2020
CESM requires at least pnetcdf 1.8.1 but you can use the latest 1.12.1
without any issue.
The issue you are posting seems to be about netcdf and not pnetcdf and so
you should report at
https://www.unidata.ucar.edu/software/netcdf/
On Wed, Jun 10, 2020 at 3:27 PM Michael MINETER <m.mineter at ed.ac.uk> wrote:
> Hi
> I am installing specific  versions of netcdf and pnetcdf to run the model
> CESM2.
> I’ve hit a problem and would welcome your guidance please.
> CESM  requests  pnetcdf 1.8.1  which I had built and tested with no
> problem with OpenMPI10.1.1 and gnu compilers.
> However I then discovered that netcdf –c  needs to be configured with
> enable-relax-coord-bound
> After the configure and make steps,  the test “make ptest” then fails at
> the first test.
> Comparing the successful (without the enable-relax…) and that with --
> enable-relax-coord-bound :
> < *** TESTING C   pres_temp_4D_wr for writing file
> ------ pass
> < *** TESTING C   pres_temp_4D_rd for reading file
> ------ pass
> And with the enable-relax-coord-bound:
> ------ Error: pres_temp_4D_wr.c at line 263: NetCDF: Index exceeds
> dimension bound
> > Error: pres_temp_4D_wr.c at line 263: NetCDF: Index exceeds dimension
> bound
> bound
> bound
> > Error: pres_temp_4D_wr.c at line 265: NetCDF: Index exceeds dimension
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> bound
> > fail with 16 mismatches
> Do I have to amend the test files or command in some way  now I have used
> the enable.,.. option  in configure?
> Apologies if this is documented – I have been unable to find it if so.
> Thanks for your attention
> Mike
> Dr Mike Mineter
> School of GeoSciences
> University of Edinburgh
> Crew Building (room 315)
> The King's Buildings
> Alexander Crum Brown Road
> Edinburgh
> EH9 3FF
> +44 (0) 131 651 9094
> The University of Edinburgh is a charitable body, registered in Scotland,
> with registration number SC005336.
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20200610/8ced9e94/attachment.html>
