error with --enable-shared
    Wei-keng Liao
    wkliao at eecs.northwestern.edu
    Sat Oct  5 10:00:33 CDT 2019
The output file, large_files.out, shows "*** Tests successful!”
at the end, which means the test is passed.
The error message at line 455 of ncmpio_var.c is expected.
It searches and checks whether a variable name was previous used.
Since you are creating a new variable, the search for existing
name should fail. It is an internal check and can be safely ignored.
Using the debug version of PnetCDF, can you try running this test
program without setting the environment variable PNETCDF_VERBOSE_DEBUG_MODE?
I.e.
unsetenv PNETCDF_VERBOSE_DEBUG_MODE
./large_files
If it passed, I am puzzled and believe the non-debug build of PnetCDF
should work. I suggest you to build PnetCDF using your original settings,
i.e. no '--enable-debug’ from scratch and run ‘make -s check’ again.
FYI. version 1.12.0 was released a few days ago. Maybe you can
give it a try, but note 1.12.0 does not change anything related to
the test program large_files.c.
Wei-keng
> On Oct 5, 2019, at 8:46 AM, Laura Fowler <ldfowler58 at icloud.com> wrote:
> Hi Wei-Keng:
> Many thanks for replying so quickly to my e-mail. I really appreciate it as I have a few deadlines coming up this month. I rebuilt pnetcdf using the debug mode from scratch, following your suggestions. I am attaching to the config.log file and the output from running large_files. I do see an error in the output large_files.out (line 455).
> Regard,
> Laura
> <large_files.out><config.log>
>> On Oct 4, 2019, at 11:08 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>> Hi Laura
>> I tried the failed test program ‘large_files’ on a Mac, but
>> could not reproduce the error you encountered.
>> In order to get more information about the error, could you
>> rebuild PnetCDF in debug mode, by adding the configure
>> option '--enable-debug’. For example,
>> make -s distclean
>> ./../pnetcdf-1.11.2/configure \
>> --prefix=/Users/LauraLaptop/InstalledSoftwares/pnetcdf-1.11.2.gfortran-8.3 \
>> --enable-shared --enable-large-file-test --enable-debug
>> make -s -j4
>> cd test/largefile
>> make large_files
>> setenv PNETCDF_VERBOSE_DEBUG_MODE 1
>> ./large_files
>> This should print the location of the error.
>> Please send me the output. Thanks.
>> Wei-keng
>>> On Oct 3, 2019, at 5:38 PM, Laura Fowler via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
>>> Hello:
>>> I would like to compile pnetcdf-1.11.2 on my MacBook Pro (macOS Mojave 10.14.6) with the following options:
>>> setenv CC mpicc
>>> setenv CXX mpic++
>>> setenv F77 mpif77
>>> setenv FC mpif90
>>> From my “install” directory, I used the following configure options:
>>> ./../pnetcdf-1.11.2/configure --prefix=/Users/LauraLaptop/InstalledSoftwares/pnetcdf-1.11.2.gfortran-8.3 --enable-shared --enable-large-file-test
>>> (see attached config.log).
>>> <config.log>
>>> I got the following error message with “make check”:
>>> /Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
>>> FAIL: large_files
>>> PASS: large_var
>>> PASS: large_dims_vars_attrs
>>> PASS: high_dim_var
>>> PASS: tst_cdf5_begin
>>> PASS: large_coalesce
>>> PASS: bigrecords
>>> PASS: tst_flarge
>>> Testsuite summary for PnetCDF 1.11.2
>>> # TOTAL: 8
>>> # PASS:  7
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  1
>>> # XPASS: 0
>>> # ERROR: 0
>>> See test/largefile/test-suite.log
>>> Please report to parallel-netcdf at mcs.anl.gov
>>> (see attached test-suite.log).
>>> <test-suite.log>
>>> I would really appreciate if you were able to help solve this issue. Thank you.
>>> Regards,
>>> Laura Fowler
More information about the parallel-netcdf
