error with --enable-shared
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Oct 4 12:08:52 CDT 2019
Hi Laura
I tried the failed test program ‘large_files’ on a Mac, but
could not reproduce the error you encountered.
In order to get more information about the error, could you
rebuild PnetCDF in debug mode, by adding the configure
option '--enable-debug’. For example,
make -s distclean
./../pnetcdf-1.11.2/configure \
--prefix=/Users/LauraLaptop/InstalledSoftwares/pnetcdf-1.11.2.gfortran-8.3 \
--enable-shared --enable-large-file-test --enable-debug
make -s -j4
cd test/largefile
make large_files
setenv PNETCDF_VERBOSE_DEBUG_MODE 1
./large_files
This should print the location of the error.
Please send me the output. Thanks.
Wei-keng
> On Oct 3, 2019, at 5:38 PM, Laura Fowler via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> Hello:
> I would like to compile pnetcdf-1.11.2 on my MacBook Pro (macOS Mojave 10.14.6) with the following options:
> setenv CC mpicc
> setenv CXX mpic++
> setenv F77 mpif77
> setenv FC mpif90
> From my “install” directory, I used the following configure options:
> ./../pnetcdf-1.11.2/configure --prefix=/Users/LauraLaptop/InstalledSoftwares/pnetcdf-1.11.2.gfortran-8.3 --enable-shared --enable-large-file-test
> (see attached config.log).
> <config.log>
> I got the following error message with “make check”:
> /Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
> FAIL: large_files
> PASS: large_var
> PASS: large_dims_vars_attrs
> PASS: high_dim_var
> PASS: tst_cdf5_begin
> PASS: large_coalesce
> PASS: bigrecords
> PASS: tst_flarge
> Testsuite summary for PnetCDF 1.11.2
> # TOTAL: 8
> # PASS:  7
> # SKIP:  0
> # XFAIL: 0
> # FAIL:  1
> # XPASS: 0
> # ERROR: 0
> See test/largefile/test-suite.log
> Please report to parallel-netcdf at mcs.anl.gov
> (see attached test-suite.log).
> <test-suite.log>
> I would really appreciate if you were able to help solve this issue. Thank you.
> Regards,
> Laura Fowler
