error with --enable-shared
    Laura Fowler
    ldfowler58 at icloud.com
    Thu Oct  3 17:38:44 CDT 2019
Hello:
I would like to compile pnetcdf-1.11.2 on my MacBook Pro (macOS Mojave 10.14.6) with the following options:
setenv CC mpicc
setenv CXX mpic++
setenv F77 mpif77
setenv FC mpif90
From my “install” directory, I used the following configure options:
./../pnetcdf-1.11.2/configure --prefix=/Users/LauraLaptop/InstalledSoftwares/pnetcdf-1.11.2.gfortran-8.3 --enable-shared --enable-large-file-test
(see attached config.log).
I got the following error message with “make check”:
/Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
FAIL: large_files
PASS: large_var
PASS: large_dims_vars_attrs
PASS: high_dim_var
PASS: tst_cdf5_begin
PASS: large_coalesce
PASS: bigrecords
PASS: tst_flarge
Testsuite summary for PnetCDF 1.11.2
# TOTAL: 8
# PASS:  7
# SKIP:  0
# XFAIL: 0
# FAIL:  1
# XPASS: 0
# ERROR: 0
See test/largefile/test-suite.log
Please report to parallel-netcdf at mcs.anl.gov
(see attached test-suite.log).
I would really appreciate if you were able to help solve this issue. Thank you.
Laura Fowler
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191003/a9560994/attachment-0003.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191003/a9560994/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191003/a9560994/attachment-0004.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191003/a9560994/attachment-0003.obj>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191003/a9560994/attachment-0005.html>
More information about the parallel-netcdf
