Parallel NetCDF Configure Error
Gates, Jason Matthew
jmgate at sandia.gov
Tue Jul 30 10:22:09 CDT 2019
?Good morning,
I'm trying to build pnetcdf-1.11.2, but I'm running into the following configure error:
checking whether we are cross compiling... configure: error: in `/Users/jmgate/toolchain/build/pnetcdf-1.11.2':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details
The config.log file and the full output from the following configure command
/Users/jmgate/toolchain/src/pnetcdf-1.11.2/configure --prefix=${TOOLCHAIN_INSTALL}/pnetcdf-1.11.2 2>&1 | tee config$(date +%y%m%d%H%M%S).log
are attached. My compiler/TPL stack so far (and not all these are relevant, but included for the sake of completeness) is
* ??gcc-9.1.0
* openmpi-4.0.1
* cmake-3.15.0
* python-?3.7.3
* lapack-3.8.0
* boost-1.70.0
* zlib-1.2.11
* hdf5-1.10.5
This is on Mac OS-X 10.14.6. Any help resolving the configure error would be appreciated.
Many thanks,
Jason M. Gates
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190730/f3099e7e/attachment.html>
Desc: config.log
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190730/f3099e7e/attachment.obj>
Desc: config190730074416.log
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190730/f3099e7e/attachment-0001.obj>
More information about the parallel-netcdf
