Parallel NetCDF Configure Error
Wei-keng Liao
wkliao at eecs.northwestern.edu
Wed Jul 31 11:08:16 CDT 2019
Hi, Jason
From your file ‘config.log’, I am seeing the error message below.
/Users/jmgate/toolchain/install/gcc-9.1.0/lib/gcc/x86_64-apple-darwin18.6.0/9.1.0/include-fixed/stdio.h:78:10: fatal error: _stdio.h: No such file or directory
78 | #include <_stdio.h>
compilation terminated.
This indicates your installation of Xcode may not be complete.
Please try command
xcode-select —install
Googling shows the following 2 links related to this problem.
https://stackoverflow.com/questions/52509602/cant-compile-c-program-on-a-mac-after-upgrade-to-mojave/52530212
https://github.com/Microsoft/LightGBM/issues/1420
Wei-keng
> On Jul 30, 2019, at 10:22 AM, Gates, Jason Matthew via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> Good morning,
> I'm trying to build pnetcdf-1.11.2, but I'm running into the following configure error:
> checking whether we are cross compiling... configure: error: in `/Users/jmgate/toolchain/build/pnetcdf-1.11.2':
> configure: error: cannot run C compiled programs.
> If you meant to cross compile, use `--host'.
> See `config.log' for more details
> The config.log file and the full output from the following configure command
> /Users/jmgate/toolchain/src/pnetcdf-1.11.2/configure --prefix=${TOOLCHAIN_INSTALL}/pnetcdf-1.11.2 2>&1 | tee config$(date +%y%m%d%H%M%S).log
> are attached. My compiler/TPL stack so far (and not all these are relevant, but included for the sake of completeness) is
> • gcc-9.1.0
> • openmpi-4.0.1
> • cmake-3.15.0
> • python-3.7.3
> • lapack-3.8.0
> • boost-1.70.0
> • zlib-1.2.11
> • hdf5-1.10.5
> This is on Mac OS-X 10.14.6. Any help resolving the configure error would be appreciated.
> Many thanks,
> Jason M. Gates
> <config.log><config190730074416.log>
More information about the parallel-netcdf
