Problem building
Henrik Uggla Henrik.Uggla at kristianstad.se
Fri Aug 16 10:15:50 CDT 2019
H!
When I try to build Pnetcdf 1.11.2 it fails with the following error:
make[4]: Entering directory '/builddir/pnetcdf-1.11.2/src/drivers/common'
CC utf8proc.lo
CC mem_alloc.lo
CC dtype_decode.lo
CC create_imaptype.lo
CC error_mpi2nc.lo
CC check_name.lo
CC pack_unpack.lo
CC utils.lo
CC error_posix2nc.lo
CC hash_map.lo
CC ncx.lo
ncx.c:28:10: fatal error: nc3dispatch.h: No such file or directory
#include "nc3dispatch.h"
compilation terminated.
When I try to configure Pnetcdf master from git it fails with the following error:
checking for MPI_Comm_rank... yes
checking for MPI_File_open... yes
checking MPI C compiler base... GCC
checking MPI version... 3.1
checking whether MPICH_VERSION is declared... no
checking whether MPICH2_VERSION is declared... no
checking whether OMPI_MAJOR_VERSION is declared... yes
checking whether MVAPICH2_VERSION is declared... no
checking MPI vendor... ./configure: line 1: syntax error: unexpected "&"
Any idea how I can get Pnetcdf to build?
Thanks
/Henrik
