Problem building
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Aug 16 11:17:41 CDT 2019
Hi, Henrik
The error messages indicate some constants set at the configure time
are incorrect. Please send me the file ‘config.log’ of both your configures.
Wei-keng
> On Aug 16, 2019, at 10:15 AM, Henrik Uggla via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> H!
> When I try to build Pnetcdf 1.11.2 it fails with the following error:
> make[4]: Entering directory '/builddir/pnetcdf-1.11.2/src/drivers/common'
> CC utf8proc.lo
> CC mem_alloc.lo
> CC dtype_decode.lo
> CC create_imaptype.lo
> CC error_mpi2nc.lo
> CC check_name.lo
> CC pack_unpack.lo
> CC utils.lo
> CC error_posix2nc.lo
> CC hash_map.lo
> CC ncx.lo
> ncx.c:28:10: fatal error: nc3dispatch.h: No such file or directory
> #include "nc3dispatch.h"
> compilation terminated.
> When I try to configure Pnetcdf master from git it fails with the following error:
> checking for MPI_Comm_rank... yes
> checking for MPI_File_open... yes
> checking MPI C compiler base... GCC
> checking MPI version... 3.1
> checking whether MPICH_VERSION is declared... no
> checking whether MPICH2_VERSION is declared... no
> checking whether OMPI_MAJOR_VERSION is declared... yes
> checking whether MVAPICH2_VERSION is declared... no
> checking MPI vendor... ./configure: line 1: syntax error: unexpected "&"
> Any idea how I can get Pnetcdf to build?
> Thanks
> /Henrik
