CXX test suite failure
Wei-keng Liao
wkliao at eecs.northwestern.edu
Thu Nov 8 16:36:37 CST 2018
From config.log, I am seeing you have environment variable LDFLAGS set to
'-L/mnt/HA/opt/amber18/lib -Wl,-rpath,/mnt/HA/opt/amber18/lib’
that causes the error.
Please unset it before running configure command.
Let me know if that resolves the problem.
Wei-keng
> On Nov 8, 2018, at 4:00 PM, Chin,David <dwc62 at drexel.edu> wrote:
> Hi Wei-Keng:
> The config.log is attached.
> David Chin, PhD Sr. Sys. Admin, URCF, Drexel
> dwc62 at drexel.edu 215.571.4335 (o)
> For URCF support: urcf-support at drexel.edu
> https://proteusmaster.urcf.drexel.edu/urcfwiki
> https://github.com/prehensilecode
> From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
> Sent: Thursday, November 8, 2018 4:34:47 PM
> To: Chin,David
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: CXX test suite failure
> Hi David
> Please send me the file “config.log”.
> I will take a look.
> Wei-keng
>> On Nov 8, 2018, at 10:32 AM, Chin,David via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
>> Compiler: Intel Composer XE 15.1.133 Build 20141023
>> MPI version: Open MPI 1.8.1
>> Mellanox OFED: 2.0.2.6.8.10 (?)
>> Mellanox MXM: 1.5.29b9b47-1
>> Attached is test/CXX/test-suite.log
>> <test-suite.log>
> <config.log>
More information about the parallel-netcdf
