CXX test suite failure
Chin,David
dwc62 at drexel.edu
Thu Nov 8 16:00:02 CST 2018
Hi Wei-Keng:
The config.log is attached.
David Chin, PhD Sr. Sys. Admin, URCF, Drexel
dwc62 at drexel.edu 215.571.4335 (o)
For URCF support: urcf-support at drexel.edu
https://proteusmaster.urcf.drexel.edu/urcfwiki
https://github.com/prehensilecode
From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
Sent: Thursday, November 8, 2018 4:34:47 PM
To: Chin,David
Cc: parallel-netcdf at mcs.anl.gov
Subject: Re: CXX test suite failure
Hi David
Please send me the file “config.log”.
I will take a look.
Wei-keng
On Nov 8, 2018, at 10:32 AM, Chin,David via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov<mailto:parallel-netcdf at lists.mcs.anl.gov>> wrote:
Compiler: Intel Composer XE 15.1.133 Build 20141023
MPI version: Open MPI 1.8.1
Mellanox OFED: 2.0.2.6.8.10 (?)
Mellanox MXM: 1.5.29b9b47-1
Attached is test/CXX/test-suite.log
dwc62 at drexel.edu<mailto:dwc62 at drexel.edu> 215.571.4335 (o)
For URCF support: urcf-support at drexel.edu<mailto:urcf-support at drexel.edu>
https://github.com/prehensilecode<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fprehensilecode&data=02%7C01%7Cdwc62%40drexel.edu%7Cb2602038ecaa4fb7c18508d645c202af%7C3664e6fa47bd45a696708c4f080f8ca6%7C0%7C0%7C636773096906072808&sdata=UWIt1psPKzE7%2FpVAxRn2ELNubjKx9PVIVGbWsCJ7l%2F4%3D&reserved=0>
<test-suite.log>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181108/7fc994ee/attachment-0001.html>
Type: text/x-log
Desc: config.log
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181108/7fc994ee/attachment-0001.bin>
More information about the parallel-netcdf
