CXX test suite failure
Chin,David dwc62 at drexel.edu
Thu Nov 8 18:54:30 CST 2018
Hi, Wei-keng:
That worked.
Thanks very much for the instant response.
    Dave
David Chin, PhD    Sr. Sys. Admin, URCF, Drexel
dwc62 at drexel.edu          215.571.4335 (o)
For URCF support: urcf-support at drexel.edu
https://proteusmaster.urcf.drexel.edu/urcfwiki
https://github.com/prehensilecode
From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
Sent: Thursday, November 8, 2018 5:36:37 PM
To: Chin,David
Cc: parallel-netcdf at mcs.anl.gov
Subject: Re: CXX test suite failure
>From config.log, I am seeing you have environment variable LDFLAGS set to
'-L/mnt/HA/opt/amber18/lib -Wl,-rpath,/mnt/HA/opt/amber18/lib’
that causes the error.
Please unset it before running configure command.
Let me know if that resolves the problem.
Wei-keng
> On Nov 8, 2018, at 4:00 PM, Chin,David <dwc62 at drexel.edu> wrote:
> Hi Wei-Keng:
> The config.log is attached.
> https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fprehensilecode&data=02%7C01%7Cdwc62%40drexel.edu%7Cb289d0b6acd74799d5b108d645caa5fa%7C3664e6fa47bd45a696708c4f080f8ca6%7C0%7C0%7C636773134029570606&sdata=k5hVT90UrIsWYztgFhFAv3ogQvA6Oj3xcWEjrCRamWQ%3D&reserved=0
> Sent: Thursday, November 8, 2018 4:34:47 PM
> To: Chin,David
> Hi David
> Please send me the file “config.log”.
> I will take a look.
> Wei-keng
>> On Nov 8, 2018, at 10:32 AM, Chin,David via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
>> Compiler: Intel Composer XE 15.1.133 Build 20141023
>> MPI version: Open MPI 1.8.1
>> Mellanox OFED: 2.0.2.6.8.10 (?)
>> Mellanox MXM: 1.5.29b9b47-1
>> Attached is test/CXX/test-suite.log
>> <test-suite.log>
> <config.log>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181109/11102840/attachment.html>
