CXX test suite failure
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Nov 8 15:34:47 CST 2018
Hi David
Please send me the file “config.log”.
I will take a look.
Wei-keng
> On Nov 8, 2018, at 10:32 AM, Chin,David via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> Compiler: Intel Composer XE 15.1.133 Build 20141023
> MPI version: Open MPI 1.8.1
> Mellanox OFED: 2.0.2.6.8.10 (?)
> Mellanox MXM: 1.5.29b9b47-1
> Attached is test/CXX/test-suite.log
> David Chin, PhD    Sr. Sys. Admin, URCF, Drexel
> dwc62 at drexel.edu <mailto:dwc62 at drexel.edu>          215.571.4335 (o)
> For URCF support: urcf-support at drexel.edu <mailto:urcf-support at drexel.edu>
> https://proteusmaster.urcf.drexel.edu/urcfwiki <https://proteusmaster.urcf.drexel.edu/urcfwiki>
> https://github.com/prehensilecode <https://github.com/prehensilecode>
> <test-suite.log>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20181108/e9133e33/attachment.html>
