[pnetcdf-devel] [parallel-netcdf] #31: Problem installing pnetcdf on 64 bit Ubuntu machine with intel compilers
Steve Brenner
Steve.Brenner at biu.ac.il
Thu Jun 8 03:13:33 CDT 2017
Wei-keng
Thank you for your prompt reply. As far as I can tell my MPI compiler (mpifort, mpif90 which are ifort) works on other f90 programs. Perhaps the version of mpi is an issue. I am using openmpi rather than mpich.
Best regards
Steve
Steve Brenner, Professor
Department of Geography and Environment
Bar Ilan University
Ramat Gan, Israel
Phone: +972 3 5318973
Secretary: +972 3 531 8340
Fax: +972 3 7384033
E-mail: steve.brenner at biu.ac.il
Web site: geoenv.biu.ac.il/en/Steve_Brenner
From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
Sent: Thursday, June 8, 2017 10:09
To: sbrenner at mail.biu.ac.il
Cc: parallel-netcdf at mcs.anl.gov
Subject: Re: [pnetcdf-devel] [parallel-netcdf] #31: Problem installing pnetcdf on 64 bit Ubuntu machine with intel compilers
I do not have access to the exactly same environment, but just now built
PnetCDF 1.8.1 on an x86_64 with Ubuntu 14.04, using mpich 3.2. built with
icc/ifort 16.0.3 and 17.0.2. The build was successful.
If the build hung at the compile time, then I would guess it most likely
is an issue of the compiler. Can check your MPI fortran compiler to
make sure it compiles other F90 programs without problems.
Wei-keng
> Reporter: sbrenner@… | Owner: robl
> Type: defect/bug | Status: new
> Priority: major | Milestone:
> Component: parallel-netcdf | Version: 1.8.1
> Keywords: |
> I am trying to install pnetcdf on a i7 machine running Ubuntu linux 16.04
> with the intel 2017 c, c++ and fortran compliers. It configues ok but in
> the make step it hangs when trying to compile pnetcdf.f90 (no error is
> returned, it simple is stuck in the compilation step). I have tried both
> versions 1.8.1 and 1.7.0. Any suggestions?
> Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/31>
> parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
Parallel netCDF: A Parallel I/O Library for NetCDF File Access<https://trac.mcs.anl.gov/projects/parallel-netcdf>
trac.mcs.anl.gov
Parallel netCDF: A Parallel I/O Library for NetCDF File Access. Parallel netCDF (PnetCDF) is jointly developed by Northwestern University and Argonne National Laboratory.
> pnetcdf-devel mailing list
> pnetcdf-devel at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/pnetcdf-devel
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20170608/41c2cd86/attachment-0001.html>
More information about the parallel-netcdf
