[pnetcdf-devel] [parallel-netcdf] #31: Problem installing pnetcdf on 64 bit Ubuntu machine with intel compilers
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Jun 8 02:09:33 CDT 2017
I do not have access to the exactly same environment, but just now built
PnetCDF 1.8.1 on an x86_64 with Ubuntu 14.04, using mpich 3.2. built with
icc/ifort 16.0.3 and 17.0.2. The build was successful.
If the build hung at the compile time, then I would guess it most likely
is an issue of the compiler. Can check your MPI fortran compiler to
make sure it compiles other F90 programs without problems.
Wei-keng
> Reporter:  sbrenner@…               |       Owner:  robl
>     Type:  defect/bug               |      Status:  new
> Priority:  major                    |   Milestone:
> Component:  parallel-netcdf          |     Version:  1.8.1
> Keywords:                           |
> I am trying to install pnetcdf on a i7 machine running Ubuntu linux 16.04
> with the intel 2017 c, c++ and fortran compliers. It configues ok but in
> the make step it hangs when trying to compile pnetcdf.f90 (no error is
> returned, it simple is stuck in the compilation step). I have tried both
> versions 1.8.1 and 1.7.0. Any suggestions?
> Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/31>
> parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
> pnetcdf-devel mailing list
> pnetcdf-devel at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/pnetcdf-devel
