pnetcdf and openmpi 2.0.2?
Mark Dixon m.c.dixon at leeds.ac.uk
Fri Feb 3 02:31:56 CST 2017
Hi Wei-keng,
Great! Thanks for that,
On Thu, 2 Feb 2017, Wei-keng Liao wrote:
> Hi, Mark
> After some digging, I found this is related to the file layout alignment
> when file striping info is available (such as using Lustre).
> You can safely ignore this test program.
> I will do more testing, fix the problem and get back to you soon.
> (maybe another minor release 1.8.2 soon.)
> Wei-keng
> On Feb 2, 2017, at 12:14 PM, Wei-keng Liao wrote:
>> Hi, Mark
>> I am puzzled by the debugging print statement from your run.
>> The test program failed to report the first error code NC_EDIMSIZE, but
>> went on to the next error NC_EVARSIZE. This might be something related
>> to the library linking problem.
>> Are you doing VPATH build? If that is the case, could you try a clean build,
>> i.e. run "make clean" on both the source and vpath directories and run "make"
>> in vpath directory to re-build the PnetCDF library?
>> If vpath build was not use, I can only suggest a clean build.
>> I also wonder if you do make check or test for OpenMPI to
>> ensure the OpenMPI is built correctly. Or test it with a small MPI program.
>> Wei-keng
>>>> Could you send me the file config.log from using openmpi 2.0.2 with the 17.0.1 intel compilers?
>>> Hi Wei-keng,
>>> Appended below - thanks.
>>>> Could you also try the followings?
>>>> 1. rebuild PnetCDF by adding "–enable-debug" option on the command line
>>>> 2. set environment variable PNETCDF_VERBOSE_DEBUG_MODE to 1
>>>> 3. cd test/cdf_format and run commands: make dim_cdf12 ; ./dim_cdf12
>>> $ cd test/cdf_format
>>> $ make dim_cdf12
>>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0       -I../../src/lib -I./../common -DHAVE_CONFIG_H  -DPNETCDF_DEBUG -c dim_cdf12.c
>>> set -e; cd ../common && make  all
>>> make[1]: Entering directory `/nobackup/parallel-netcdf-1.8.1/test/common'
>>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0       -I../../src/lib -DHAVE_CONFIG_H  -DPNETCDF_DEBUG -c testutils.c
>>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90  -I../../src/lib   -DPNETCDF_DEBUG -g -O0   -c testutilsf.F90
>>> ar cru libtestutils.a testutils.o testutilsf.o
>>> make[1]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test/common'
>>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0   -o dim_cdf12 dim_cdf12.o  -L../common /nobackup/parallel-netcdf-1.8.1/src/lib/libpnetcdf.a -ltestutils $ ./dim_cdf12
>>> *** TESTING C   dim_cdf12 for defining dim in CDF-1/2 format       ------ Rank 0: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
>>> Rank 0: NC_EVARSIZE error at line 489 of NC_begins in nc.c
>>> Error at line 96: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
>>> Rank 0: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
>>> Rank 0: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
>>> Error at line 97: err=NC_ENOTNC (NetCDF: Unknown file format)
>>> Rank 0: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
>>> Rank 0: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
>>> Error at line 98: err=NC_EBADID (NetCDF: Not a valid ID)
>>> Rank 0: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
>>> Error at line 113: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
>>> fail with 4 mismatches
>>> Cheers,
>>> Mark
>>> And the config.log file...
>>> This file contains any messages produced by compilers while
>>> running configure, to aid debugging if configure makes a mistake.
>>> It was created by parallel-netcdf configure 1.8.1, which was
>>> generated by GNU Autoconf 2.69.  Invocation command line was
>>> $ ./configure --prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1 --enable-debug
>>> ## Platform. ##
>>> hostname = login2.arc3.leeds.ac.uk
>>> uname -m = x86_64
>>> uname -r = 3.10.0-514.6.1.el7.x86_64
>>> uname -s = Linux
>>> uname -v = #1 SMP Wed Jan 18 13:06:36 UTC 2017
>>> /usr/bin/uname -p = x86_64
>>> /bin/uname -X     = unknown
>>> /bin/arch              = x86_64
>>> /usr/bin/arch -k       = unknown
>>> /usr/convex/getsysinfo = unknown
>>> /usr/bin/hostinfo      = unknown
>>> /bin/machine           = unknown
>>> /usr/bin/oslevel       = unknown
>>> /bin/universe          = unknown
>>> PATH: /apps/mpi/bin
>>> PATH: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin
>>> PATH: /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64
>>> PATH: /apps/developers/compilers/intel/17.0.1/1/default/debugger_2017/gdb/intel64_mic/bin
>>> PATH: /usr/lib64/qt-3.3/bin
>>> PATH: /usr/local/bin
>>> PATH: /usr/bin
>>> PATH: /usr/local/sbin
>>> PATH: /usr/sbin
>>> PATH: /opt/puppetlabs/bin
>>> PATH: /apps/bin
>>> PATH: /home/ufaserv1_a/issmcd/bin
>>> ## Core tests. ##
>>> configure:3421: checking for gcc
>>> configure:3448: result: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>>> configure:3677: checking for C compiler version
>>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc --version >&5
>>> icc (ICC) 17.0.1 20161005
>>> Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
>>> configure:3697: $? = 0
>>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -v >&5
>>> icc version 17.0.1 (gcc version 4.8.5 compatibility)
>>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -V >&5
>>> Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -qversion >&5
>>> icc: command line warning #10006: ignoring unknown option '-qversion'
>>> icc: command line error: no files specified; for help type "icc -help"
>>> configure:3697: $? = 1
>>> configure:3717: checking whether the C compiler works
>>> configure:3739: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc    conftest.c  >&5
>>> configure:3743: $? = 0
>>> configure:3791: result: yes
>>> configure:3794: checking for C compiler default output file name
>>> configure:3796: result: a.out
>>> configure:3802: checking for suffix of executables
>>> configure:3809: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest    conftest.c  >&5
>>> configure:3813: $? = 0
>>> configure:3835: result: configure:3857: checking whether we are cross compiling
>>> configure:3865: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest    conftest.c  >&5
>>> configure:3869: $? = 0
>>> configure:3876: ./conftest
>>> configure:3880: $? = 0
>>> configure:3895: result: no
>>> configure:3900: checking for suffix of object files
>>> configure:3922: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c   conftest.c >&5
>>> configure:3926: $? = 0
>>> configure:3947: result: o
>>> configure:3951: checking whether we are using the GNU C compiler
>>> configure:3970: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c   conftest.c >&5
>>> configure:3970: $? = 0
>>> configure:3979: result: yes
>>> configure:3988: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc accepts -g
>>> configure:4008: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g  conftest.c >&5
>>> configure:4008: $? = 0
>>> configure:4049: result: yes
>>> configure:4066: checking for /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc option to accept ISO C89
>>> configure:4129: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -c -g -O2  conftest.c >&5
>>> configure:4129: $? = 0
>>> configure:4142: result: none needed
>>> configure:4172: checking for special C compiler options needed for large files
>>> configure:4217: result: no
>>> configure:4223: checking for _FILE_OFFSET_BITS value needed for large files
>>> configure:4248: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:4248: $? = 0
>>> configure:4280: result: no
>>> configure:4367: checking how to make dependencies
>>> configure:4402: result: false
>>> configure:4409: checking for MPI_Comm_rank
>>> configure:4409: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:4409: $? = 0
>>> configure:4409: result: yes
>>> configure:4492: checking for MPI_File_open
>>> configure:4492: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:4492: $? = 0
>>> configure:4492: result: yes
>>> configure:4976: checking for C++ compiler version
>>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx --version >&5
>>> icpc (ICC) 17.0.1 20161005
>>> configure:4996: $? = 0
>>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -v >&5
>>> icpc version 17.0.1 (gcc version 4.8.5 compatibility)
>>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -V >&5
>>> Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -qversion >&5
>>> icpc: command line warning #10006: ignoring unknown option '-qversion'
>>> icpc: command line error: no files specified; for help type "icpc -help"
>>> configure:4996: $? = 1
>>> configure:5000: checking whether we are using the GNU C++ compiler
>>> configure:5019: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c   conftest.cpp >&5
>>> configure:5019: $? = 0
>>> configure:5028: result: yes
>>> configure:5037: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx accepts -g
>>> configure:5057: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g  conftest.cpp >&5
>>> configure:5057: $? = 0
>>> configure:5098: result: yes
>>> configure:5130: checking for MPI_File_close
>>> configure:5130: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -o conftest -g -O2   conftest.cpp  >&5
>>> configure:5130: $? = 0
>>> configure:5130: result: yes
>>> configure:5216: checking if MPI C++ compiler redefines SEEK_SET configure:5233: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>>> configure:5233: $? = 0
>>> configure:5240: result: no
>>> configure:5972: checking for Fortran compiler version
>>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 --version >&5
>>> ifort (IFORT) 17.0.1 20161005
>>> configure:5992: $? = 0
>>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -v >&5
>>> ifort version 17.0.1
>>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -V >&5
>>> Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -qversion >&5
>>> ifort: command line warning #10006: ignoring unknown option '-qversion'
>>> ifort: command line error: no files specified; for help type "ifort -help"
>>> configure:5992: $? = 1
>>> configure:6001: checking whether we are using the GNU Fortran compiler
>>> configure:6014: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c   conftest.F >&5
>>> conftest.F(3): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>>>      choke me
>>> compilation aborted for conftest.F (code 1)
>>> configure:6014: $? = 1
>>> configure: failed program was:
>>> |       program main
>>> | #ifndef __GNUC__
>>> |        choke me
>>> | #endif
>>> | |       end
>>> configure:6023: result: no
>>> configure:6029: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 accepts -g
>>> configure:6040: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> configure:6040: $? = 0
>>> configure:6048: result: yes
>>> configure:6084: checking build system type
>>> configure:6098: result: x86_64-unknown-linux-gnu
>>> configure:6118: checking host system type
>>> configure:6131: result: x86_64-unknown-linux-gnu
>>> configure:6156: checking how to get verbose linking output from /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> configure:6166: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> configure:6166: $? = 0
>>> configure:6184: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
>>> /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/fortcom    -D__INTEL_COMPILER=1700 -D__INTEL_COMPILER_UPDATE=1 -D__unix__ -D__unix -D__linux__ -D__linux -D__gnu_linux__ -Dunix -Dlinux -D__ELF__ -D__x86_64 -D__x86_64__ -D__amd64 -D__amd64__ -D__INTEL_COMPILER_BUILD_DATE=20161005 -D__INTEL_OFFLOAD -D__i686 -D__i686__ -D__pentiumpro -D__pentiumpro__ -D__pentium4 -D__pentium4__ -D__tune_pentium4__ -D__SSE2__ -D__SSE2_MATH__ -D__SSE__ -D__SSE_MATH__ -D__MMX__ -mGLOB_pack_sort_init_list -I. -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/include -I/apps/developers/compilers/intel/1!
 7.0.!
>>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/iforts8OIo9.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/de!
 vel!
>>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortUEEBPwas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_!
 use!
>>> _base_pointer=1 -mCG_bnl_movbe=T -mGLOB_extended_instructions=0x8 -mP3O!
>>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort0709387709De25UH -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/iforts8OIo9.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchAnCxhU -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfileTg0G0A -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS !
 -mG!
>>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/iforts8OIo9.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>>> #include "..." search starts here:
>>> #include <...> search starts here:
>>> /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include
>>> /usr/local/include
>>> /usr/include/
>>> /usr/include
>>> End of search list.
>>> ld    /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtbegin.o --eh-frame-hdr --build-id -dynamic-linker /lib64/ld-linux-x86-64.so.2 -m elf_x86_64 -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/for_main.o -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_l!
 in -!
>>> L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daa!
 l/l!
>>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/iforts8OIo9.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>>> configure:6267: result: -v
>>> configure:6269: checking for Fortran libraries of /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> configure:6292: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
 7.0.!
>>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/ifortFvK4TU.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/de!
 vel!
>>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortLXRBSkas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_!
 use!
>>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort1771009391GShk4m -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/ifortFvK4TU.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchfcWcSK -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfileM3LbSs -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS !
 -mG!
>>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/ifortFvK4TU.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>>> /usr/local/include
>>> /usr/include/
>>> /usr/include
>>> End of search list.
 in -!
 l/l!
>>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/ifortFvK4TU.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>>> configure:6488: result:  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/develop!
 ers/!
>>> compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
>>> configure:6507: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc links with FCLIBS found by autoconf
>>> configure:6532: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/li!
 b/..!
>>> /lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  >&5
>>> configure:6532: $? = 0
>>> configure:6534: result: yes
>>> configure:6598: checking if mpi.mod is available
>>> configure:6605: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> configure:6605: $? = 0
>>> configure:6612: result: yes
>>> configure:6614: checking if MPIF90 is valid
>>> configure:6624: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> configure:6624: $? = 0
>>> configure:6647: result: yes
>>> configure:6796: checking for Fortran 77 compiler version
>>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 --version >&5
>>> configure:6816: $? = 0
>>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -v >&5
>>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -V >&5
>>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -qversion >&5
>>> configure:6816: $? = 1
>>> configure:6825: checking whether we are using the GNU Fortran 77 compiler
>>> configure:6838: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c  conftest.F >&5
>>>      choke me
>>> configure:6838: $? = 1
>>> |       program main
>>> | #ifndef __GNUC__
>>> |        choke me
>>> | #endif
>>> | |       end
>>> configure:6847: result: no
>>> configure:6853: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 accepts -g
>>> configure:6864: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:6864: $? = 0
>>> configure:6872: result: yes
>>> configure:6907: checking how to get verbose linking output from /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> configure:6917: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:6917: $? = 0
>>> configure:6935: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
 7.0.!
>>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/ifortuvU6OS.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/de!
 vel!
>>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortyW3KXAas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_!
 use!
>>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort0880525677IBUZzB -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/ifortuvU6OS.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchqxls7i -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfilekQWtca -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS !
 -mG!
>>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/ifortuvU6OS.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>>> /usr/local/include
>>> /usr/include/
>>> /usr/include
>>> End of search list.
 in -!
 l/l!
>>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/ifortuvU6OS.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>>> configure:7018: result: -v
>>> configure:7020: checking for Fortran 77 libraries of /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> configure:7239: result:  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/develop!
 ers/!
>>> configure:7260: checking for Fortran flag needed to accept free-form source
>>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> conftest.f(2): error #5149: Illegal character in statement label field  [p]
>>> program freeform
>>> conftest.f(2): error #5149: Illegal character in statement label field  [r]
>>> program freeform
>>> conftest.f(2): error #5149: Illegal character in statement label field  [o]
>>> program freeform
>>> conftest.f(2): error #5118: First statement in file must not be continued
>>> program freeform
>>> conftest.f(2): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>>> program freeform
>>> conftest.f(4): error #5082: Syntax error, found '&' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
>>>      print *, 'Hello ', &
>>> conftest.f(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
>>>         'world.'
>>> compilation aborted for conftest.f (code 1)
>>> configure:7279: $? = 1
>>> | |   program freeform
>>> |        ! FIXME: how to best confuse non-freeform compilers?
>>> |           'world.'
>>> |        end
>>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ffree-form  conftest.f >&5
>>> ifort: command line warning #10006: ignoring unknown option '-ffree-form'
>>> program freeform
>>> program freeform
>>> program freeform
>>> program freeform
>>> program freeform
>>>         'world.'
>>> | |   program freeform
>>> |           'world.'
>>> |        end
>>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -FR  conftest.f >&5
>>> configure:7279: $? = 0
>>> configure:7288: result: -FR
>>> configure:7323: checking if MPIF77 is valid
>>> configure:7332: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:7332: $? = 0
>>> configure:7339: result: yes
>>> configure:7399: checking for Fortran flag to compile preprocessed .f files
>>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> conftest.f(3): warning #5117: Bad # preprocessor line
>>> #if 0
>>> conftest.f(4): warning #5117: Bad # preprocessor line
>>> #include <ac_nonexistent.h>
>>> conftest.f(6): warning #5117: Bad # preprocessor line
>>> #endif
>>> conftest.f(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>>>     choke me
>>> configure:7427: $? = 1
>>> |       program main
>>> | | #if 0
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ftpp conftest.f >&5
>>> ifort: command line warning #10006: ignoring unknown option '-ftpp'
>>> #if 0
>>> #endif
>>>     choke me
>>> |       program main
>>> | | #if 0
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f >&5
>>> configure:7427: $? = 0
>>> configure:7437: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f >&5
>>> conftest.f(4): #error: can't find include file: ac_nonexistent.h
>>> configure:7437: $? = 1
>>> |       program main
>>> | | #if 1
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7451: result: -fpp
>>> configure:7474: checking for Fortran flag to compile preprocessed .F files
>>> configure:7502: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>>> configure:7502: $? = 0
>>> configure:7512: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>>> conftest.F(4): #error: can't find include file: ac_nonexistent.h
>>> configure:7512: $? = 1
>>> |       program main
>>> | | #if 1
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7526: result: none
>>> configure:7549: checking for Fortran flag to compile preprocessed .f90 files
>>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f90 >&5
>>> conftest.f90(3): warning #5117: Bad # preprocessor line
>>> #if 0
>>> conftest.f90(4): warning #5117: Bad # preprocessor line
>>> conftest.f90(6): warning #5117: Bad # preprocessor line
>>> #endif
>>> conftest.f90(5): error #5082: Syntax error, found IDENTIFIER 'ME' when expecting one of: => = . [ % ( :
>>>     choke me
>>> compilation aborted for conftest.f90 (code 1)
>>> configure:7577: $? = 1
>>> |       program main
>>> | | #if 0
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ftpp conftest.f90 >&5
>>> #if 0
>>> #endif
>>>     choke me
>>> |       program main
>>> | | #if 0
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f90 >&5
>>> configure:7577: $? = 0
>>> configure:7587: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f90 >&5
>>> conftest.f90(4): #error: can't find include file: ac_nonexistent.h
>>> configure:7587: $? = 1
>>> |       program main
>>> | | #if 1
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7601: result: -fpp
>>> configure:7624: checking for Fortran flag to compile preprocessed .F90 files
>>> configure:7652: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:7652: $? = 0
>>> configure:7662: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> conftest.F90(4): #error: can't find include file: ac_nonexistent.h
>>> configure:7662: $? = 1
>>> |       program main
>>> | | #if 1
>>> |       choke me
>>> | #endif
>>> |       end
>>> configure:7676: result: none
>>> configure:7719: checking for Fortran flag to compile preprocessed .F files
>>> configure:7771: result: configure:7791: checking how to define symbols for preprocessed Fortran
>>> configure:7813: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -DFOOBAR -DZORK=42  conftest.F >&5
>>> configure:7813: $? = 0
>>> configure:7822: result: -D
>>> configure:7849: checking for Fortran flag to compile .f files
>>> configure:7869: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>>> configure:7869: $? = 0
>>> configure:7878: result: none
>>> configure:7903: checking for Fortran flag to compile .F files
>>> configure:7923: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>>> configure:7923: $? = 0
>>> configure:7932: result: none
>>> configure:7957: checking for Fortran flag to compile .f90 files
>>> configure:7977: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f90 >&5
>>> configure:7977: $? = 0
>>> configure:7986: result: none
>>> configure:8011: checking for Fortran flag to compile .F90 files
>>> configure:8031: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:8031: $? = 0
>>> configure:8040: result: none
>>> configure:8076: checking for Fortran flag needed to accept fixed-form source
>>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> conftest.F90(2): error #5082: Syntax error, found IDENTIFIER 'THIS' when expecting one of: => = . [ % ( :
>>> C     This comment should confuse free-form compilers.
>>> compilation aborted for conftest.F90 (code 1)
>>> configure:8093: $? = 1
>>> |       program main
>>> |       end
>>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ffixed-form  conftest.F90 >&5
>>> ifort: command line warning #10006: ignoring unknown option '-ffixed-form'
>>> |       program main
>>> |       end
>>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fixed  conftest.F90 >&5
>>> configure:8093: $? = 0
>>> configure:8102: result: -fixed
>>> configure:8137: checking for dummy main to link with Fortran libraries
>>> configure:8171: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/l!
 ib/.!
>>> ./lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl >&5
>>> configure:8171: $? = 0
>>> configure:8216: result: none
>>> configure:8249: checking for Fortran name-mangling scheme
>>> configure:8262: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:8262: $? = 0
>>> configure:8303: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c cfortran_test.o   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/.!
 ./li!
>>> b64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl >&5
>>> /tmp/iccl8ejIz.o: In function `main':
>>> /nobackup/parallel-netcdf-1.8.1/conftest.c:28: undefined reference to `foobar'
>>> configure:8303: $? = 1
>>> | /* confdefs.h */
>>> | #define PACKAGE_NAME "parallel-netcdf"
>>> | #define PACKAGE_TARNAME "parallel-netcdf"
>>> | #define PACKAGE_VERSION "1.8.1"
>>> | #define PACKAGE_STRING "parallel-netcdf 1.8.1"
>>> | #define PACKAGE_BUGREPORT "parallel-netcdf at mcs.anl.gov"
>>> | #define PACKAGE_URL ""
>>> | /* end confdefs.h.  */
>>> | | /* Override any GCC internal prototype to avoid an error.
>>> |    Use char because int might match the return type of a GCC
>>> |    builtin and then its argument prototype would still apply.  */
>>> | #ifdef __cplusplus
>>> | extern "C"
>>> | #endif
>>> | char foobar ();
>>> | #ifdef FC_DUMMY_MAIN
>>> | #ifndef FC_DUMMY_MAIN_EQ_F77
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> |    int FC_DUMMY_MAIN() { return 1; }
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | return foobar ();
>>> |   return 0;
 ./li!
>>> configure:8303: $? = 0
>>> configure:8361: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c cfortran_test.o   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/.!
 ./li!
>>> configure:8361: $? = 0
>>> configure:8403: result: lower case, underscore, no extra underscore
>>> configure:8444: checking for C-equivalent to Fortran routine "SUB_A"
>>> configure:8466: result: sub_a_
>>> configure:8498: checking if Fortran compiler is NAG
>>> configure:8513: result: no
>>> configure:8524: checking Fortran compiler treating constant modifier
>>> configure:8543: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:8543: $? = 0
>>> configure:8582: result: 8
>>> configure:8645: checking for a BSD-compatible install
>>> configure:8713: result: /usr/bin/install -c
>>> configure:8728: checking whether ln -s works
>>> configure:8732: result: yes
>>> configure:8739: checking whether make sets $(MAKE)
>>> configure:8761: result: yes
>>> configure:8771: checking for grep that handles long lines and -e
>>> configure:8829: result: /usr/bin/grep
>>> configure:8834: checking for egrep
>>> configure:8896: result: /usr/bin/grep -E
>>> configure:8910: checking for m4
>>> configure:8926: found /usr/bin/m4
>>> configure:8937: result: m4
>>> configure:8993: checking m4 flags
>>> configure:9005: result: "none"
>>> configure:9021: checking for ar
>>> configure:9037: found /usr/bin/ar
>>> configure:9048: result: ar
>>> configure:9104: checking ar flags
>>> configure:9109: result: cru
>>> configure:9119: checking for nm
>>> configure:9135: found /usr/bin/nm
>>> configure:9146: result: nm
>>> configure:9202: checking nm flags
>>> configure:9207: result: configure:9257: checking for ranlib
>>> configure:9273: found /usr/bin/ranlib
>>> configure:9284: result: ranlib
>>> configure:9312: checking how to run the C preprocessor
>>> configure:9343: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>>> configure:9343: $? = 0
>>> configure:9357: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>>> conftest.c(10): error #2379: cannot open source file "ac_nonexistent.h"
>>> configure:9357: $? = 2
>>> | /* confdefs.h */
>>> | #define F77_NAME_LOWER_USCORE /**/
>>> configure:9382: result: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E
>>> configure:9402: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>>> configure:9402: $? = 0
>>> configure:9416: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>>> configure:9416: $? = 2
>>> | /* confdefs.h */
>>> configure:9445: checking for ANSI C header files
>>> configure:9473: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9473: $? = 0
>>> configure:9546: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9546: $? = 0
>>> configure:9546: ./conftest
>>> configure:9557: result: yes
>>> configure:9570: checking for sys/types.h
>>> configure:9570: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9570: $? = 0
>>> configure:9570: result: yes
>>> configure:9570: checking for sys/stat.h
>>> configure:9570: checking for stdlib.h
>>> configure:9570: checking for string.h
>>> configure:9570: checking for memory.h
>>> configure:9570: checking for strings.h
>>> configure:9570: checking for inttypes.h
>>> configure:9570: checking for stdint.h
>>> configure:9570: checking for unistd.h
>>> configure:9582: checking for stdbool.h that conforms to C99
>>> configure:9657: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9657: $? = 0
>>> configure:9664: result: yes
>>> configure:9666: checking for _Bool
>>> configure:9666: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9666: $? = 0
>>> conftest.c(64): error: expected an expression
>>> if (sizeof ((_Bool)))
>>> compilation aborted for conftest.c (code 2)
>>> configure:9666: $? = 2
>>> | /* confdefs.h */
>>> | #define STDC_HEADERS 1
>>> | #define HAVE_SYS_TYPES_H 1
>>> | #define HAVE_SYS_STAT_H 1
>>> | #define HAVE_STDLIB_H 1
>>> | #define HAVE_STRING_H 1
>>> | #define HAVE_MEMORY_H 1
>>> | #define HAVE_STRINGS_H 1
>>> | #define HAVE_INTTYPES_H 1
>>> | #define HAVE_STDINT_H 1
>>> | #define HAVE_UNISTD_H 1
>>> | #include <stdio.h>
>>> | #ifdef HAVE_SYS_TYPES_H
>>> | # include <sys/types.h>
>>> | #endif
>>> | #ifdef HAVE_SYS_STAT_H
>>> | # include <sys/stat.h>
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | # include <stdlib.h>
>>> | # include <stddef.h>
>>> | #else
>>> | # ifdef HAVE_STDLIB_H
>>> | # endif
>>> | #endif
>>> | #ifdef HAVE_STRING_H
>>> | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
>>> | #  include <memory.h>
>>> | # endif
>>> | # include <string.h>
>>> | #endif
>>> | #ifdef HAVE_STRINGS_H
>>> | # include <strings.h>
>>> | #endif
>>> | #ifdef HAVE_INTTYPES_H
>>> | # include <inttypes.h>
>>> | #endif
>>> | #ifdef HAVE_STDINT_H
>>> | # include <stdint.h>
>>> | #endif
>>> | #ifdef HAVE_UNISTD_H
>>> | # include <unistd.h>
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:9666: result: yes
>>> configure:9684: checking for inline
>>> configure:9700: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9700: $? = 0
>>> configure:9708: result: inline
>>> configure:9729: checking for IEEE floating point format
>>> configure:9767: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9767: $? = 0
>>> configure:9767: ./conftest
>>> configure:9776: result: yes
>>> configure:9788: checking for strerror
>>> configure:9788: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9788: $? = 0
>>> configure:9788: result: yes
>>> configure:9788: checking for access
>>> configure:9788: checking for unlink
>>> configure:9811: checking search.h usability
>>> configure:9811: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9811: $? = 0
>>> configure:9811: result: yes
>>> configure:9811: checking search.h presence
>>> configure:9811: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>>> configure:9811: checking for search.h
>>> configure:9824: checking for tsearch
>>> configure:9824: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9824: $? = 0
>>> configure:9824: result: yes
>>> configure:9824: checking for tdelete
>>> configure:9843: checking for MPI_Offset
>>> configure:9843: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9843: $? = 0
>>> conftest.c(42): error: expected an expression
>>> if (sizeof ((MPI_Offset)))
>>> configure:9843: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE__BOOL 1
>>> | #define HAVE_STDBOOL_H 1
>>> | #define HAVE_STRERROR 1
>>> | #define HAVE_ACCESS 1
>>> | #define HAVE_UNLINK 1
>>> | #define HAVE_SEARCH_H 1
>>> | #define HAVE_TSEARCH 1
>>> | #define HAVE_TDELETE 1
>>> | #define PNC_MALLOC_TRACE 1
>>> | #include <mpi.h>
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:9843: result: yes
>>> configure:9854: checking size of MPI_Offset
>>> configure:9859: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9859: $? = 0
>>> configure:9859: ./conftest
>>> configure:9874: result: 8
>>> configure:9891: checking size of MPI_Aint
>>> configure:9896: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9896: $? = 0
>>> configure:9896: ./conftest
>>> configure:9911: result: 8
>>> configure:9954: checking for MPI_Info_dup
>>> configure:9954: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9954: $? = 0
>>> configure:9954: result: yes
>>> configure:9954: checking for MPI_Info_free
>>> configure:9954: checking for MPI_Get_address
>>> configure:9966: checking for MPI_Type_create_subarray
>>> configure:9966: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:9966: $? = 0
>>> configure:9966: result: yes
>>> configure:9966: checking for MPI_Type_create_hvector
>>> configure:9966: checking for MPI_Type_create_hindexed
>>> configure:9966: checking for MPI_Type_create_struct
>>> configure:9966: checking for MPI_Type_create_resized
>>> configure:9966: checking for MPI_Type_get_extent
>>> configure:9977: checking if MPI constant MPI_COMBINER_DUP is defined configure:9986: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:9986: $? = 0
>>> configure:9987: result: yes
>>> configure:10001: checking if MPI constant MPI_COMBINER_HVECTOR_INTEGER is defined configure:10010: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10010: $? = 0
>>> configure:10011: result: yes
>>> configure:10025: checking if MPI constant MPI_COMBINER_HINDEXED_INTEGER is defined configure:10034: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10034: $? = 0
>>> configure:10035: result: yes
>>> configure:10049: checking if MPI constant MPI_COMBINER_SUBARRAY is defined configure:10058: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10058: $? = 0
>>> configure:10059: result: yes
>>> configure:10073: checking if MPI constant MPI_COMBINER_DARRAY is defined configure:10082: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10082: $? = 0
>>> configure:10083: result: yes
>>> configure:10097: checking if MPI constant MPI_COMBINER_RESIZED is defined configure:10106: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10106: $? = 0
>>> configure:10107: result: yes
>>> configure:10121: checking if MPI constant MPI_COMBINER_STRUCT_INTEGER is defined configure:10130: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10130: $? = 0
>>> configure:10131: result: yes
>>> configure:10145: checking if MPI constant MPI_COMBINER_INDEXED_BLOCK is defined configure:10154: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10154: $? = 0
>>> configure:10155: result: yes
>>> configure:10169: checking if MPI constant MPI_COMBINER_F90_REAL is defined configure:10178: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10178: $? = 0
>>> configure:10179: result: yes
>>> configure:10193: checking if MPI constant MPI_COMBINER_F90_INTEGER is defined configure:10202: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10202: $? = 0
>>> configure:10203: result: yes
>>> configure:10217: checking if MPI constant MPI_COMBINER_F90_COMPLEX is defined configure:10226: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10226: $? = 0
>>> configure:10227: result: yes
>>> configure:10242: checking if MPI constant MPI_ERR_FILE_EXISTS is defined configure:10251: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10251: $? = 0
>>> configure:10252: result: yes
>>> configure:10266: checking if MPI constant MPI_ERR_NO_SUCH_FILE is defined configure:10275: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10275: $? = 0
>>> configure:10276: result: yes
>>> configure:10290: checking if MPI constant MPI_ERR_AMODE is defined configure:10299: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10299: $? = 0
>>> configure:10300: result: yes
>>> configure:10314: checking if MPI constant MPI_ERR_NOT_SAME is defined configure:10323: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10323: $? = 0
>>> configure:10324: result: yes
>>> configure:10338: checking if MPI constant MPI_ERR_BAD_FILE is defined configure:10347: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10347: $? = 0
>>> configure:10348: result: yes
>>> configure:10362: checking if MPI constant MPI_ERR_READ_ONLY is defined configure:10371: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10371: $? = 0
>>> configure:10372: result: yes
>>> configure:10386: checking if MPI constant MPI_ERR_ACCESS is defined configure:10395: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10395: $? = 0
>>> configure:10396: result: yes
>>> configure:10410: checking if MPI constant MPI_ERR_NO_SPACE is defined configure:10419: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10419: $? = 0
>>> configure:10420: result: yes
>>> configure:10434: checking if MPI constant MPI_ERR_QUOTA is defined configure:10443: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10443: $? = 0
>>> configure:10444: result: yes
>>> configure:10459: checking if MPI datatype MPI_CHAR is defined configure:10468: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10468: $? = 0
>>> configure:10469: result: yes
>>> configure:10483: checking if MPI datatype MPI_BYTE is defined configure:10492: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10492: $? = 0
>>> configure:10493: result: yes
>>> configure:10507: checking if MPI datatype MPI_SIGNED_CHAR is defined configure:10516: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10516: $? = 0
>>> configure:10517: result: yes
>>> configure:10531: checking if MPI datatype MPI_UNSIGNED_CHAR is defined configure:10540: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10540: $? = 0
>>> configure:10541: result: yes
>>> configure:10555: checking if MPI datatype MPI_SHORT is defined configure:10564: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10564: $? = 0
>>> configure:10565: result: yes
>>> configure:10579: checking if MPI datatype MPI_UNSIGNED_SHORT is defined configure:10588: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10588: $? = 0
>>> configure:10589: result: yes
>>> configure:10603: checking if MPI datatype MPI_INT is defined configure:10612: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10612: $? = 0
>>> configure:10613: result: yes
>>> configure:10627: checking if MPI datatype MPI_UNSIGNED is defined configure:10636: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10636: $? = 0
>>> configure:10637: result: yes
>>> configure:10651: checking if MPI datatype MPI_LONG is defined configure:10660: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10660: $? = 0
>>> configure:10661: result: yes
>>> configure:10675: checking if MPI datatype MPI_FLOAT is defined configure:10684: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10684: $? = 0
>>> configure:10685: result: yes
>>> configure:10699: checking if MPI datatype MPI_DOUBLE is defined configure:10708: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10708: $? = 0
>>> configure:10709: result: yes
>>> configure:10723: checking if MPI datatype MPI_LONG_LONG_INT is defined configure:10732: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10732: $? = 0
>>> configure:10733: result: yes
>>> configure:10747: checking if MPI datatype MPI_UNSIGNED_LONG_LONG is defined configure:10756: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10756: $? = 0
>>> configure:10757: result: yes
>>> configure:10771: checking if MPI datatype MPI_UB is defined configure:10780: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(77): warning #1786: variable "ompi_mpi_ub" (declared at line 926 of "/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include/mpi.h") was declared deprecated ("MPI_UB is deprecated in MPI-2.0")
>>>           MPI_Datatype dummy = MPI_UB;
>>> configure:10780: $? = 0
>>> configure:10781: result: yes
>>> configure:10795: checking if MPI datatype MPI_LB is defined configure:10804: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(78): warning #1786: variable "ompi_mpi_lb" (declared at line 925 of "/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include/mpi.h") was declared deprecated ("MPI_LB is deprecated in MPI-2.0")
>>>           MPI_Datatype dummy = MPI_LB;
>>> configure:10804: $? = 0
>>> configure:10805: result: yes
>>> configure:10819: checking if MPI datatype MPI_OFFSET is defined configure:10828: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10828: $? = 0
>>> configure:10829: result: yes
>>> configure:10845: checking if MPI datatype MPI_CHARACTER is defined configure:10854: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10854: $? = 0
>>> configure:10855: result: yes
>>> configure:10869: checking if MPI datatype MPI_REAL is defined configure:10878: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10878: $? = 0
>>> configure:10879: result: yes
>>> configure:10893: checking if MPI datatype MPI_INTEGER is defined configure:10902: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10902: $? = 0
>>> configure:10903: result: yes
>>> configure:10917: checking if MPI datatype MPI_DOUBLE_PRECISION is defined configure:10926: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10926: $? = 0
>>> configure:10927: result: yes
>>> configure:10941: checking if MPI datatype MPI_INTEGER1 is defined configure:10950: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10950: $? = 0
>>> configure:10951: result: yes
>>> configure:10965: checking if MPI datatype MPI_INTEGER2 is defined configure:10974: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10974: $? = 0
>>> configure:10975: result: yes
>>> configure:10989: checking if MPI datatype MPI_INTEGER4 is defined configure:10998: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:10998: $? = 0
>>> configure:10999: result: yes
>>> configure:11013: checking if MPI datatype MPI_INTEGER8 is defined configure:11022: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11022: $? = 0
>>> configure:11023: result: yes
>>> configure:11037: checking if MPI datatype MPI_INTEGER16 is defined configure:11046: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(88): error: identifier "MPI_INTEGER16" is undefined
>>>           MPI_Datatype dummy = MPI_INTEGER16;
>>> configure:11046: $? = 2
>>> | /* confdefs.h */
>>> | #define SIZEOF_MPI_OFFSET 8
>>> | #define SIZEOF_MPI_AINT 8
>>> | #define ENABLE_CDF5 /**/
>>> | #define ENABLE_REQ_AGGREGATION /**/
>>> | #define HAVE_MPI_INFO_DUP 1
>>> | #define HAVE_MPI_INFO_FREE 1
>>> | #define HAVE_MPI_GET_ADDRESS 1
>>> | #define HAVE_MPI_TYPE_CREATE_SUBARRAY 1
>>> | #define HAVE_MPI_TYPE_CREATE_HVECTOR 1
>>> | #define HAVE_MPI_TYPE_CREATE_HINDEXED 1
>>> | #define HAVE_MPI_TYPE_CREATE_STRUCT 1
>>> | #define HAVE_MPI_TYPE_CREATE_RESIZED 1
>>> | #define HAVE_MPI_TYPE_GET_EXTENT 1
>>> | #define HAVE_MPI_COMBINER_DUP 1
>>> | #define HAVE_MPI_COMBINER_HVECTOR_INTEGER 1
>>> | #define HAVE_MPI_COMBINER_HINDEXED_INTEGER 1
>>> | #define HAVE_MPI_COMBINER_SUBARRAY 1
>>> | #define HAVE_MPI_COMBINER_DARRAY 1
>>> | #define HAVE_MPI_COMBINER_RESIZED 1
>>> | #define HAVE_MPI_COMBINER_STRUCT_INTEGER 1
>>> | #define HAVE_MPI_COMBINER_INDEXED_BLOCK 1
>>> | #define HAVE_MPI_COMBINER_F90_REAL 1
>>> | #define HAVE_MPI_COMBINER_F90_INTEGER 1
>>> | #define HAVE_MPI_COMBINER_F90_COMPLEX 1
>>> | #define HAVE_MPI_ERR_FILE_EXISTS 1
>>> | #define HAVE_MPI_ERR_NO_SUCH_FILE 1
>>> | #define HAVE_MPI_ERR_AMODE 1
>>> | #define HAVE_MPI_ERR_NOT_SAME 1
>>> | #define HAVE_MPI_ERR_BAD_FILE 1
>>> | #define HAVE_MPI_ERR_READ_ONLY 1
>>> | #define HAVE_MPI_ERR_ACCESS 1
>>> | #define HAVE_MPI_ERR_NO_SPACE 1
>>> | #define HAVE_MPI_ERR_QUOTA 1
>>> | #define HAVE_MPI_CHAR 1
>>> | #define HAVE_MPI_BYTE 1
>>> | #define HAVE_MPI_SIGNED_CHAR 1
>>> | #define HAVE_MPI_UNSIGNED_CHAR 1
>>> | #define HAVE_MPI_SHORT 1
>>> | #define HAVE_MPI_UNSIGNED_SHORT 1
>>> | #define HAVE_MPI_INT 1
>>> | #define HAVE_MPI_UNSIGNED 1
>>> | #define HAVE_MPI_LONG 1
>>> | #define HAVE_MPI_FLOAT 1
>>> | #define HAVE_MPI_DOUBLE 1
>>> | #define HAVE_MPI_LONG_LONG_INT 1
>>> | #define HAVE_MPI_UNSIGNED_LONG_LONG 1
>>> | #define HAVE_MPI_UB 1
>>> | #define HAVE_MPI_LB 1
>>> | #define HAVE_MPI_OFFSET_DATATYPE 1
>>> | #define HAVE_MPI_CHARACTER 1
>>> | #define HAVE_MPI_REAL 1
>>> | #define HAVE_MPI_INTEGER 1
>>> | #define HAVE_MPI_DOUBLE_PRECISION 1
>>> | #define HAVE_MPI_INTEGER1 1
>>> | #define HAVE_MPI_INTEGER2 1
>>> | #define HAVE_MPI_INTEGER4 1
>>> | #define HAVE_MPI_INTEGER8 1
>>> | |           #include <mpi.h>
>>> | configure:11054: result: no
>>> configure:11061: checking if MPI datatype MPI_REAL4 is defined configure:11070: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11070: $? = 0
>>> configure:11071: result: yes
>>> configure:11085: checking if MPI datatype MPI_REAL8 is defined configure:11094: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11094: $? = 0
>>> configure:11095: result: yes
>>> configure:11109: checking if MPI datatype MPI_REAL16 is defined configure:11118: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11118: $? = 0
>>> configure:11119: result: yes
>>> configure:11133: checking if MPI datatype MPI_COMPLEX8 is defined configure:11142: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11142: $? = 0
>>> configure:11143: result: yes
>>> configure:11157: checking if MPI datatype MPI_COMPLEX16 is defined configure:11166: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11166: $? = 0
>>> configure:11167: result: yes
>>> configure:11181: checking if MPI datatype MPI_COMPLEX32 is defined configure:11190: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11190: $? = 0
>>> configure:11191: result: yes
>>> configure:11221: checking whether char is unsigned
>>> configure:11248: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11248: $? = 0
>>> configure:11255: result: no
>>> configure:11262: checking whether byte ordering is bigendian
>>> configure:11277: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(93): error: identifier "not" is undefined
>>> 	       not a universal capable compiler
>>> conftest.c(93): error: expected a ";"
>>> configure:11277: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_MPI_REAL4 1
>>> | #define HAVE_MPI_REAL8 1
>>> | #define HAVE_MPI_REAL16 1
>>> | #define HAVE_MPI_COMPLEX8 1
>>> | #define HAVE_MPI_COMPLEX16 1
>>> | #define HAVE_MPI_COMPLEX32 1
>>> | #ifndef __APPLE_CC__
>>> | 	     #endif
>>> | 	     typedef int dummy;
>>> | configure:11330: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11330: $? = 0
>>> configure:11356: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(107): error: identifier "not" is undefined
>>> 		 not big endian
>>> conftest.c(107): error: expected a ";"
>>> 		 not big endian
>>> conftest.c(110): warning #12: parsing restarts here after previous syntax error
>>> configure:11356: $? = 2
>>> | /* confdefs.h */
>>> | #include <sys/types.h>
>>> | 		#include <sys/param.h>
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | #if BYTE_ORDER != BIG_ENDIAN
>>> | 		 not big endian
>>> | 		#endif
>>> |   return 0;
>>> configure:11516: result: no
>>> configure:11547: checking for size_t
>>> configure:11547: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11547: $? = 0
>>> conftest.c(136): error: expected an expression
>>> if (sizeof ((size_t)))
>>> configure:11547: $? = 2
>>> | /* confdefs.h */
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11547: result: yes
>>> configure:11558: checking for off_t
>>> configure:11558: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11558: $? = 0
>>> if (sizeof ((off_t)))
>>> configure:11558: $? = 2
>>> configure: failed program was:
>>> | /* confdefs.h */
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11558: result: yes
>>> configure:11569: checking for ssize_t
>>> configure:11569: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11569: $? = 0
>>> if (sizeof ((ssize_t)))
>>> configure:11569: $? = 2
>>> | /* confdefs.h */
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11569: result: yes
>>> configure:11578: checking for ptrdiff_t
>>> configure:11578: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11578: $? = 0
>>> conftest.c(137): error: expected an expression
>>> if (sizeof ((ptrdiff_t)))
>>> configure:11578: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_SSIZE_T 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11578: result: yes
>>> configure:11587: checking for uchar
>>> configure:11587: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(138): error: identifier "uchar" is undefined
>>> if (sizeof (uchar))
>>> configure:11587: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_PTRDIFF_T 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | if (sizeof (uchar))
>>> | 	 return 0;
>>> |   return 0;
>>> configure:11587: result: no
>>> configure:11596: checking for ushort
>>> configure:11596: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11596: $? = 0
>>> conftest.c(138): error: expected an expression
>>> if (sizeof ((ushort)))
>>> configure:11596: $? = 2
>>> | /* confdefs.h */
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11596: result: yes
>>> configure:11605: checking for uint
>>> configure:11605: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> configure:11605: $? = 0
>>> conftest.c(139): error: expected an expression
>>> if (sizeof ((uint)))
>>> configure:11605: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_USHORT 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	    return 0;
>>> |   return 0;
>>> configure:11605: result: yes
>>> configure:11614: checking for longlong
>>> configure:11614: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(140): error: identifier "longlong" is undefined
>>> if (sizeof (longlong))
>>> configure:11614: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_UINT 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	 return 0;
>>> |   return 0;
>>> configure:11614: result: no
>>> configure:11623: checking for ulonglong
>>> configure:11623: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(140): error: identifier "ulonglong" is undefined
>>> if (sizeof (ulonglong))
>>> configure:11623: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_UINT 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	 return 0;
>>> |   return 0;
>>> configure:11623: result: no
>>> configure:11632: checking for int64
>>> configure:11632: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(140): error: identifier "int64" is undefined
>>> if (sizeof (int64))
>>> configure:11632: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_UINT 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | if (sizeof (int64))
>>> | 	 return 0;
>>> |   return 0;
>>> configure:11632: result: no
>>> configure:11641: checking for uint64
>>> configure:11641: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>>> conftest.c(140): error: identifier "uint64" is undefined
>>> if (sizeof (uint64))
>>> configure:11641: $? = 2
>>> | /* confdefs.h */
>>> | #define HAVE_UINT 1
>>> | #include <stdio.h>
>>> | #endif
>>> | #endif
>>> | #ifdef STDC_HEADERS
>>> | #else
>>> | # endif
>>> | #endif
>>> | # endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #endif
>>> | #  ifdef __cplusplus
>>> |      extern "C"
>>> | #  endif
>>> | #endif
>>> | #endif
>>> | int
>>> | main ()
>>> | 	 return 0;
>>> |   return 0;
>>> configure:11641: result: no
>>> configure:11656: checking size of size_t
>>> configure:11661: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11661: $? = 0
>>> configure:11661: ./conftest
>>> configure:11675: result: 8
>>> configure:11689: checking size of off_t
>>> configure:11694: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11694: $? = 0
>>> configure:11694: ./conftest
>>> configure:11708: result: 8
>>> configure:11722: checking size of signed char
>>> configure:11727: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11727: $? = 0
>>> configure:11727: ./conftest
>>> configure:11741: result: 1
>>> configure:11755: checking size of unsigned char
>>> configure:11760: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11760: $? = 0
>>> configure:11760: ./conftest
>>> configure:11774: result: 1
>>> configure:11788: checking size of short
>>> configure:11793: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11793: $? = 0
>>> configure:11793: ./conftest
>>> configure:11807: result: 2
>>> configure:11821: checking size of unsigned short int
>>> configure:11826: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11826: $? = 0
>>> configure:11826: ./conftest
>>> configure:11840: result: 2
>>> configure:11854: checking size of unsigned short
>>> configure:11859: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11859: $? = 0
>>> configure:11859: ./conftest
>>> configure:11873: result: 2
>>> configure:11887: checking size of int
>>> configure:11892: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11892: $? = 0
>>> configure:11892: ./conftest
>>> configure:11906: result: 4
>>> configure:11920: checking size of unsigned int
>>> configure:11925: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11925: $? = 0
>>> configure:11925: ./conftest
>>> configure:11939: result: 4
>>> configure:11953: checking size of long
>>> configure:11958: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11958: $? = 0
>>> configure:11958: ./conftest
>>> configure:11972: result: 8
>>> configure:11986: checking size of float
>>> configure:11991: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:11991: $? = 0
>>> configure:11991: ./conftest
>>> configure:12005: result: 4
>>> configure:12019: checking size of double
>>> configure:12024: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:12024: $? = 0
>>> configure:12024: ./conftest
>>> configure:12038: result: 8
>>> configure:12052: checking size of long long
>>> configure:12057: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:12057: $? = 0
>>> configure:12057: ./conftest
>>> configure:12071: result: 8
>>> configure:12085: checking size of unsigned long long
>>> configure:12090: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:12090: $? = 0
>>> configure:12090: ./conftest
>>> configure:12104: result: 8
>>> configure:12120: checking size of ushort
>>> configure:12125: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:12125: $? = 0
>>> configure:12125: ./conftest
>>> configure:12139: result: 2
>>> configure:12155: checking size of uint
>>> configure:12160: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>>> configure:12160: $? = 0
>>> configure:12160: ./conftest
>>> configure:12174: result: 4
>>> configure:12383: checking for C-equivalent to Fortran routine "SUB"
>>> configure:12404: result: sub_
>>> configure:12422: checking for Fortran "integer*1"
>>> configure:12431: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:12431: $? = 0
>>> configure:12432: result: yes
>>> configure:12461: checking for Fortran "integer*2"
>>> configure:12470: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:12470: $? = 0
>>> configure:12471: result: yes
>>> configure:12500: checking for Fortran "integer*8"
>>> configure:12509: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:12509: $? = 0
>>> configure:12510: result: yes
>>> configure:12544: checking if Fortran "integer*1" is configure:12554: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12557: $? = 0
>>> configure:12560: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12563: $? = 0
>>> configure:12566: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12569: $? = 0
>>> configure:12572: ./conftest
>>> configure:12575: $? = 0
>>> configure:12577: result: "signed char" in C
>>> configure:12619: checking if Fortran "integer*2" is configure:12629: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12632: $? = 0
>>> configure:12635: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12638: $? = 0
>>> configure:12641: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12644: $? = 0
>>> configure:12647: ./conftest
>>> configure:12650: $? = 0
>>> configure:12652: result: "short" in C
>>> configure:12694: checking if Fortran "integer*8" is configure:12704: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12707: $? = 0
>>> configure:12710: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12713: $? = 0
>>> configure:12716: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12719: $? = 0
>>> configure:12722: ./conftest
>>> configure:12725: $? = 0
>>> configure:12727: result: "int" in C
>>> configure:12767: checking if Fortran "integer" is configure:12777: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12780: $? = 0
>>> configure:12783: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12786: $? = 0
>>> configure:12789: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12792: $? = 0
>>> configure:12795: ./conftest
>>> configure:12798: $? = 0
>>> configure:12800: result: "int" in C
>>> configure:12838: checking if Fortran "real" is configure:12848: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12851: $? = 0
>>> configure:12854: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12857: $? = 0
>>> configure:12860: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12863: $? = 0
>>> configure:12866: ./conftest
>>> configure:12869: $? = 0
>>> configure:12871: result: "float" in C
>>> configure:12909: checking if Fortran "doubleprecision" is configure:12919: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>>> configure:12922: $? = 0
>>> configure:12925: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>>> configure:12928: $? = 0
>>> configure:12931: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12934: $? = 0
>>> configure:12937: ./conftest
>>> configure:12940: $? = 0
>>> configure:12942: result: "double" in C
>>> configure:12973: checking for Fortran-equivalent to netCDF "byte"
>>> configure:12988: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:12988: $? = 0
>>> configure:13004: result: byte
>>> configure:13010: checking for Fortran-equivalent to netCDF "short"
>>> configure:13025: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:13025: $? = 0
>>> configure:13041: result: integer*2
>>> configure:13054: checking for Fortran NFMPI_OFFSET "integer*8"
>>> configure:13068: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:13068: $? = 0
>>> configure:13082: result: yes
>>> configure:13097: checking Fortran 90 module extension
>>> configure:13119: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:13119: $? = 0
>>> configure:13136: result: mod
>>> configure:13154: checking Fortran 90 module inclusion flag
>>> configure:13176: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:13176: $? = 0
>>> configure:13190: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Iconftest.dir -Iconftest.dir  conftest.F90 >&5
>>> configure:13190: $? = 0
>>> configure:13211: result: -I
>>> configure:13233: checking Fortran 90 module output flag
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Jsub  conftest.F90 >&5
>>> ifort: command line warning #10006: ignoring unknown option '-Jsub'
>>> configure:13261: $? = 0
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Jsub  conftest.F90 >&5
>>> conftest.F90(3): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [CONFTEST_MODULE]
>>>     use conftest_module
>>> configure:13270: $? = 1
>>> | |       program main
>>> |       use conftest_module
>>> |       call conftest_routine
>>> |       end
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -J sub  conftest.F90 >&5
>>> ifort: command line warning #10006: ignoring unknown option '-J'
>>> ifort: warning #10145: no action performed for file 'sub'
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -J sub  conftest.F90 >&5
>>> ifort: error #10236: File not found:  'sub'
>>>     use conftest_module
>>> | |       program main
>>> |       use conftest_module
>>> |       end
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fmod=sub  conftest.F90 >&5
>>> ifort: command line warning #10006: ignoring unknown option '-fmod=sub'
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fmod=sub  conftest.F90 >&5
>>>     use conftest_module
>>> | |       program main
>>> |       use conftest_module
>>> |       end
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -moddir=sub  conftest.F90 >&5
>>> ifort: command line warning #10159: invalid argument for option '-m'
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -moddir=sub  conftest.F90 >&5
>>>     use conftest_module
>>> | |       program main
>>> |       use conftest_module
>>> |       end
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g +moddir=sub  conftest.F90 >&5
>>> ifort: error #10236: File not found:  '+moddir=sub'
>>> configure:13261: $? = 1
>>> | |       module conftest_module
>>> |       contains
>>> |       subroutine conftest_routine
>>> |       write(*,'(a)') 'gotcha!'
>>> |       end subroutine
>>> |       end module
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -qmoddir=sub  conftest.F90 >&5
>>> ifort: command line warning #10006: ignoring unknown option '-qmoddir=sub'
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -qmoddir=sub  conftest.F90 >&5
>>>     use conftest_module
>>> | |       program main
>>> |       use conftest_module
>>> |       end
>>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -mod sub  conftest.F90 >&5
>>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -mod sub  conftest.F90 >&5
>>> configure:13270: $? = 0
>>> configure:13292: result: -mod configure:13320: checking for Fortran 77 GNU intrinsic INT
>>> configure:13344: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:13344: $? = 0
>>> configure:13357: result: yes
>>> configure:13370: checking for Fortran 77 intrinsic INT1
>>> configure:13388: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:13388: $? = 0
>>> configure:13401: result: yes
>>> configure:13413: checking for Fortran 77 intrinsic INT2
>>> configure:13431: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:13431: $? = 0
>>> configure:13444: result: yes
>>> configure:13456: checking for Fortran 77 intrinsic INT8
>>> configure:13474: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>>> configure:13474: $? = 0
>>> configure:13487: result: yes
>>> configure:13508: checking if Fortran 90 compiler capitalizes .mod filenames
>>> configure:13517: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>>> configure:13517: $? = 0
>>> configure:13527: result: no
>>> configure:13647: checking for manual-page index command
>>> configure:13649: result: configure:13685: checking if C++ macro __func__ or __FUNCTION__ is defined
>>> configure:13717: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>>> configure:13717: $? = 0
>>> configure:13740: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>>> configure:13740: $? = 0
>>> configure:13752: result: yes
>>> configure:13854: checking for latex
>>> configure:13872: found /usr/bin/latex
>>> configure:13884: result: /usr/bin/latex
>>> configure:13894: checking for dvipdf
>>> configure:13912: found /usr/bin/dvipdf
>>> configure:13924: result: /usr/bin/dvipdf
>>> configure:13986: checking for gcc
>>> configure:14004: found /usr/bin/gcc
>>> configure:14017: result: /usr/bin/gcc
>>> configure:14170: creating ./config.status
>>> ## Running config.status. ##
>>> This file was extended by parallel-netcdf config.status 1.8.1, which was
>>> generated by GNU Autoconf 2.69.  Invocation command line was
>>> CONFIG_FILES    =
>>> CONFIG_HEADERS  =
>>> CONFIG_LINKS    =
>>> CONFIG_COMMANDS =
>>> $ ./config.status
>>> on login2.arc3.leeds.ac.uk
>>> config.status:1111: creating macros.make
>>> config.status:1111: creating Makefile
>>> config.status:1111: creating pnetcdf_pc
>>> config.status:1111: creating src/Makefile
>>> config.status:1111: creating src/lib/Makefile
>>> config.status:1111: creating src/lib/pnetcdf.h
>>> config.status:1111: creating src/utils/Makefile
>>> config.status:1111: creating src/utils/ncmpidump/Makefile
>>> config.status:1111: creating src/utils/ncmpidiff/Makefile
>>> config.status:1111: creating src/utils/ncmpigen/Makefile
>>> config.status:1111: creating src/utils/ncmpivalid/Makefile
>>> config.status:1111: creating src/utils/pnetcdf_version/Makefile
>>> config.status:1111: creating src/utils/ncoffsets/Makefile
>>> config.status:1111: creating test/Makefile
>>> config.status:1111: creating test/common/Makefile
>>> config.status:1111: creating test/nc_test/Makefile
>>> config.status:1111: creating test/C/Makefile
>>> config.status:1111: creating test/fandc/Makefile
>>> config.status:1111: creating test/testcases/Makefile
>>> config.status:1111: creating test/nonblocking/Makefile
>>> config.status:1111: creating test/header/Makefile
>>> config.status:1111: creating test/cdf_format/Makefile
>>> config.status:1111: creating test/largefile/Makefile
>>> config.status:1111: creating examples/C/Makefile
>>> config.status:1111: creating examples/tutorial/Makefile
>>> config.status:1111: creating examples/Makefile
>>> config.status:1111: creating doc/Makefile
>>> config.status:1111: creating man/Makefile
>>> config.status:1111: creating scripts/Makefile
>>> config.status:1111: creating benchmarks/Makefile
>>> config.status:1111: creating benchmarks/C/Makefile
>>> config.status:1111: creating test/nf_test/Makefile
>>> config.status:1111: creating test/nf_test/tests.inc
>>> config.status:1111: creating test/nf90_test/Makefile
>>> config.status:1111: creating test/F90/Makefile
>>> config.status:1111: creating examples/F77/Makefile
>>> config.status:1111: creating examples/F90/Makefile
>>> config.status:1111: creating src/libf90/Makefile
>>> config.status:1111: creating src/libf90/pnetcdf.f90
>>> config.status:1111: creating src/libf90/api.f90
>>> config.status:1111: creating src/libf90/nfmpi_constants.f90
>>> config.status:1111: creating src/libf/Makefile
>>> config.status:1111: creating src/libf/pnetcdf.inc
>>> config.status:1111: creating src/libcxx/Makefile
>>> config.status:1111: creating examples/CXX/Makefile
>>> config.status:1111: creating test/CXX/Makefile
>>> config.status:1111: creating benchmarks/FLASH-IO/Makefile
>>> config.status:1111: creating test/subfile/Makefile
>>> config.status:1111: creating stamp-h
>>> config.status:1111: creating pnetcdf-config
>>> config.status:1111: creating check_install
>>> config.status:1111: creating src/lib/ncconfig.h
>>> config.status:1111: creating src/libf/nfconfig_inc
>>> ## Cache variables. ##
>>> ac_cv_CHECK_MPI_CPP_SEEK_SET=no
>>> ac_cv_NFMPI_OFFSET=yes
>>> ac_cv_build=x86_64-unknown-linux-gnu
>>> ac_cv_c_bigendian=no
>>> ac_cv_c_char_unsigned=no
>>> ac_cv_c_compiler_gnu=yes
>>> ac_cv_c_ieeefloat=yes
>>> ac_cv_c_inline=inline
>>> ac_cv_cxx_compiler_gnu=yes
>>> ac_cv_cxx_macro_func=yes
>>> ac_cv_cxx_macro_function=yes
>>> ac_cv_env_CCC_set=
>>> ac_cv_env_CCC_value=
>>> ac_cv_env_CC_set=set
>>> ac_cv_env_CC_value=icc
>>> ac_cv_env_CFLAGS_set=
>>> ac_cv_env_CFLAGS_value=
>>> ac_cv_env_CPPFLAGS_set=
>>> ac_cv_env_CPPFLAGS_value=
>>> ac_cv_env_CPP_set=
>>> ac_cv_env_CPP_value=
>>> ac_cv_env_CXXFLAGS_set=
>>> ac_cv_env_CXXFLAGS_value=
>>> ac_cv_env_CXX_set=set
>>> ac_cv_env_CXX_value=icpc
>>> ac_cv_env_F77_set=set
>>> ac_cv_env_F77_value=ifort
>>> ac_cv_env_FCFLAGS_set=
>>> ac_cv_env_FCFLAGS_value=
>>> ac_cv_env_FC_set=set
>>> ac_cv_env_FC_value=ifort
>>> ac_cv_env_FFLAGS_set=
>>> ac_cv_env_FFLAGS_value=
>>> ac_cv_env_FPPFLAGS_set=
>>> ac_cv_env_FPPFLAGS_value=
>>> ac_cv_env_LDFLAGS_set=
>>> ac_cv_env_LDFLAGS_value=
>>> ac_cv_env_LIBS_set=
>>> ac_cv_env_LIBS_value=
>>> ac_cv_env_MPICC_set=set
>>> ac_cv_env_MPICC_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>>> ac_cv_env_MPICXX_set=set
>>> ac_cv_env_MPICXX_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx
>>> ac_cv_env_MPIF77_set=set
>>> ac_cv_env_MPIF77_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> ac_cv_env_MPIF90_set=set
>>> ac_cv_env_MPIF90_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>>> ac_cv_env_RM_set=
>>> ac_cv_env_RM_value=
>>> ac_cv_env_TEST_MPIRUN_set=
>>> ac_cv_env_TEST_MPIRUN_value=
>>> ac_cv_env_TEST_OUTDIR_set=
>>> ac_cv_env_TEST_OUTDIR_value=
>>> ac_cv_env_TEST_SEQRUN_set=
>>> ac_cv_env_TEST_SEQRUN_value=
>>> ac_cv_env_build_alias_set=
>>> ac_cv_env_build_alias_value=
>>> ac_cv_env_host_alias_set=
>>> ac_cv_env_host_alias_value=
>>> ac_cv_env_target_alias_set=
>>> ac_cv_env_target_alias_value=
>>> ac_cv_f77_compiler_gnu=no
>>> ac_cv_f77_gnu_int=yes
>>> ac_cv_f77_int1=yes
>>> ac_cv_f77_int2=yes
>>> ac_cv_f77_int8=yes
>>> ac_cv_f77_libs=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/comp!
 iler!
>>> s/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl'
>>> ac_cv_fc_compiler_gnu=no
>>> ac_cv_fc_compiler_nag=no
>>> ac_cv_fc_constant_modifier=8
>>> ac_cv_fc_dummy_main=none
>>> ac_cv_fc_fixedform=-fixed
>>> ac_cv_fc_freeform=-FR
>>> ac_cv_fc_libs=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compi!
 lers!
>>> ac_cv_fc_mangling='lower case, underscore, no extra underscore'
>>> ac_cv_fc_module_ext=mod
>>> ac_cv_fc_module_flag=-I
>>> ac_cv_fc_module_output_flag='-mod '
>>> ac_cv_fc_pp_define=-D
>>> ac_cv_fc_pp_srcext_F90=
>>> ac_cv_fc_pp_srcext_F=
>>> ac_cv_fc_pp_srcext_f90=-fpp
>>> ac_cv_fc_pp_srcext_f=-fpp
>>> ac_cv_fc_srcext_F90=none
>>> ac_cv_fc_srcext_F=none
>>> ac_cv_fc_srcext_f90=none
>>> ac_cv_fc_srcext_f=none
>>> ac_cv_fortran_dummy_main=none
>>> ac_cv_func_MPI_Comm_rank=yes
>>> ac_cv_func_MPI_File_close=yes
>>> ac_cv_func_MPI_File_open=yes
>>> ac_cv_func_MPI_Get_address=yes
>>> ac_cv_func_MPI_Info_dup=yes
>>> ac_cv_func_MPI_Info_free=yes
>>> ac_cv_func_MPI_Type_create_hindexed=yes
>>> ac_cv_func_MPI_Type_create_hvector=yes
>>> ac_cv_func_MPI_Type_create_resized=yes
>>> ac_cv_func_MPI_Type_create_struct=yes
>>> ac_cv_func_MPI_Type_create_subarray=yes
>>> ac_cv_func_MPI_Type_get_extent=yes
>>> ac_cv_func_access=yes
>>> ac_cv_func_strerror=yes
>>> ac_cv_func_tdelete=yes
>>> ac_cv_func_tsearch=yes
>>> ac_cv_func_unlink=yes
>>> ac_cv_header_inttypes_h=yes
>>> ac_cv_header_memory_h=yes
>>> ac_cv_header_search_h=yes
>>> ac_cv_header_stdbool_h=yes
>>> ac_cv_header_stdc=yes
>>> ac_cv_header_stdint_h=yes
>>> ac_cv_header_stdlib_h=yes
>>> ac_cv_header_string_h=yes
>>> ac_cv_header_strings_h=yes
>>> ac_cv_header_sys_stat_h=yes
>>> ac_cv_header_sys_types_h=yes
>>> ac_cv_header_unistd_h=yes
>>> ac_cv_host=x86_64-unknown-linux-gnu
>>> ac_cv_m4_stdout=
>>> ac_cv_objext=o
>>> ac_cv_path_DVIPDF=/usr/bin/dvipdf
>>> ac_cv_path_EGREP='/usr/bin/grep -E'
>>> ac_cv_path_GREP=/usr/bin/grep
>>> ac_cv_path_LATEX=/usr/bin/latex
>>> ac_cv_path_SEQ_CC=/usr/bin/gcc
>>> ac_cv_path_install='/usr/bin/install -c'
>>> ac_cv_prog_AR=ar
>>> ac_cv_prog_CPP='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E'
>>> ac_cv_prog_M4=m4
>>> ac_cv_prog_NM=nm
>>> ac_cv_prog_ac_ct_CC=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>>> ac_cv_prog_ac_ct_RANLIB=ranlib
>>> ac_cv_prog_cc_c89=
>>> ac_cv_prog_cc_g=yes
>>> ac_cv_prog_cxx_g=yes
>>> ac_cv_prog_f77_g=yes
>>> ac_cv_prog_f77_v=-v
>>> ac_cv_prog_f90_uppercase_mod=no
>>> ac_cv_prog_fc_g=yes
>>> ac_cv_prog_fc_v=-v
>>> ac_cv_prog_make_make_set=yes
>>> ac_cv_sizeof_MPI_Aint=8
>>> ac_cv_sizeof_MPI_Offset=8
>>> ac_cv_sizeof_double=8
>>> ac_cv_sizeof_float=4
>>> ac_cv_sizeof_int=4
>>> ac_cv_sizeof_long=8
>>> ac_cv_sizeof_long_long=8
>>> ac_cv_sizeof_off_t=8
>>> ac_cv_sizeof_short=2
>>> ac_cv_sizeof_signed_char=1
>>> ac_cv_sizeof_size_t=8
>>> ac_cv_sizeof_uint=4
>>> ac_cv_sizeof_unsigned_char=1
>>> ac_cv_sizeof_unsigned_int=4
>>> ac_cv_sizeof_unsigned_long_long=8
>>> ac_cv_sizeof_unsigned_short=2
>>> ac_cv_sizeof_unsigned_short_int=2
>>> ac_cv_sizeof_ushort=2
>>> ac_cv_sys_file_offset_bits=no
>>> ac_cv_sys_largefile_CC=no
>>> ac_cv_type_MPI_Offset=yes
>>> ac_cv_type__Bool=yes
>>> ac_cv_type_int64=no
>>> ac_cv_type_longlong=no
>>> ac_cv_type_off_t=yes
>>> ac_cv_type_ptrdiff_t=yes
>>> ac_cv_type_size_t=yes
>>> ac_cv_type_ssize_t=yes
>>> ac_cv_type_uchar=no
>>> ac_cv_type_uint64=no
>>> ac_cv_type_uint=yes
>>> ac_cv_type_ulonglong=no
>>> ac_cv_type_ushort=yes
>>> ## Output variables. ##
>>> AR='ar'
>>> ARFLAGS='cru'
>>> BUILDDIR='/nobackup/parallel-netcdf-1.8.1'
>>> CC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>>> CC_MAKEDEPEND='false'
>>> CFLAGS='-g  -O0'
>>> CONFIGURE_ARGS_CLEAN='--prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1 --enable-debug'
>>> CONFIG_DATE='Thu Feb  2 16:22:34 GMT 2017'
>>> CPPFLAGS=''
>>> CXX='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx'
>>> CXXCPPFLAGS=''
>>> CXXFLAGS='-g  -O0'
>>> DEFS='-DHAVE_CONFIG_H'
>>> DVIPDF='/usr/bin/dvipdf'
>>> ECHO_C=''
>>> ECHO_N='-n'
>>> ECHO_T=''
>>> ENABLE_ERANGE_FILL='1'
>>> ENABLE_SUBFILING='0'
>>> EXEEXT=''
>>> F77='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>>> F77FLAGS='-g -O0'
>>> F77FLAGS_F=''
>>> F77FLAGS_f=''
>>> F77PPFLAGS_F=''
>>> F77PPFLAGS_f='-fpp'
>>> F77_SUPPORT_FREEFORM='yes'
>>> F90FLAGS='-g -O0'
>>> F90FLAGS_F90=''
>>> F90FLAGS_f90=''
>>> F90LDFLAGS=''
>>> F90LIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/i!
 ntel!
>>> F90PPFLAGS_F90=''
>>> F90PPFLAGS_f90='-fpp'
>>> FC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>>> FCFLAGS='-g  -O0'
>>> FCFLAGS_F90=''
>>> FCFLAGS_F=''
>>> FCFLAGS_f90=''
>>> FCFLAGS_f=''
>>> FCLIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/in!
 tel/!
>>> FC_DEFINE='-D'
>>> FC_MODEXT='mod'
>>> FC_MODINC='-I'
>>> FC_MODOUT='-mod ${ac_empty}'
>>> FFIXEDFORMFLAG='-fixed'
>>> FFLAGS='-g'
>>> FFREEFORMFLAG='-FR'
>>> FLDFLAGS=''
>>> FLIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/int!
 el/1!
>>> FPP=''
>>> FPPFLAGS=''
>>> GREP='/usr/bin/grep'
>>> HAVE_F77_GNU_INT='yes'
>>> HAVE_F77_INT1='yes'
>>> HAVE_F77_INT2='yes'
>>> HAVE_F77_INT8='yes'
>>> INSTALL_DATA='${INSTALL} -m 644'
>>> INSTALL_PROGRAM='${INSTALL}'
>>> INSTALL_SCRIPT='${INSTALL}'
>>> INTENTV='INOUT'
>>> LATEX='/usr/bin/latex'
>>> LCOV_LIB=''
>>> LDFLAGS=''
>>> LIBOBJS=''
>>> LIBS=''
>>> LN_S='ln -s'
>>> LTLIBOBJS=''
>>> M4='m4'
>>> M4FFLAGS=''
>>> M4FLAGS=''
>>> MAKEWHATIS_CMD=''
>>> MPICC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>>> MPICXX='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx'
>>> MPIF77='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>>> MPIF90='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>>> NAG_FCFLAGS=''
>>> NAGf90FPPFLAGS=''
>>> NM='nm'
>>> NMFLAGS=''
>>> OBJEXT='o'
>>> PACKAGE_BUGREPORT='parallel-netcdf at mcs.anl.gov'
>>> PACKAGE_NAME='parallel-netcdf'
>>> PACKAGE_STRING='parallel-netcdf 1.8.1'
>>> PACKAGE_TARNAME='parallel-netcdf'
>>> PACKAGE_URL=''
>>> PACKAGE_VERSION='1.8.1'
>>> PATH_SEPARATOR=':'
>>> PNETCDF_DEBUG='1'
>>> PNETCDF_INC='/nobackup/parallel-netcdf-1.8.1/src/libf90'
>>> PNETCDF_LIB='-L/nobackup/parallel-netcdf-1.8.1/src/lib'
>>> PNETCDF_RELEASE_DATE2='2017-01-28'
>>> PNETCDF_RELEASE_DATE='28 Jan 2017'
>>> PNETCDF_VERSION='1.8.1'
>>> PNETCDF_VERSION_MAJOR='1'
>>> PNETCDF_VERSION_MINOR='8'
>>> PNETCDF_VERSION_PRE=''
>>> PNETCDF_VERSION_SUB='1'
>>> PNF_FILL_INT64='-9223372036854775806_8'
>>> PNF_FILL_UINT64='18446744073709551614_8'
>>> PNF_FILL_UINT='4294967295_8'
>>> PNF_INT8_MODIFIER=''
>>> PNF_X_INT8_MAX='9223372036854775807_8'
>>> PNF_X_INT8_MIN='-9223372036854775807_8'
>>> PNF_X_UINT8_MAX='18446744073709551615_8'
>>> PNF_X_UINT_MAX='4294967295_8'
>>> RANLIB='ranlib'
>>> RELAX_COORD_BOUND='0'
>>> RM='rm'
>>> SEQ_CC='/usr/bin/gcc'
>>> SET_MAKE=''
>>> SHELL='/bin/sh'
>>> SIZEOF_MPI_AINT_IS_4='no'
>>> SIZEOF_MPI_OFFSET='8'
>>> TEST_MPIRUN='mpiexec -n NP'
>>> TEST_OUTDIR='.'
>>> TEST_SEQRUN=''
>>> UPPER_CASE_MOD='no'
>>> USE_MPIF_HEADER='use mpi, only: MPI_OFFSET_KIND'
>>> WHATIS='whatis'
>>> ac_ct_CC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>>> ac_ct_CXX=''
>>> ac_ct_F77=''
>>> ac_ct_FC=''
>>> ac_empty=''
>>> bindir='${exec_prefix}/bin'
>>> build='x86_64-unknown-linux-gnu'
>>> build_alias=''
>>> build_cpu='x86_64'
>>> build_os='linux-gnu'
>>> build_vendor='unknown'
>>> datadir='${datarootdir}'
>>> datarootdir='${prefix}/share'
>>> docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>> dvidir='${docdir}'
>>> enable_coverage='no'
>>> enable_erange_fill='yes'
>>> enable_subfiling='no'
>>> exec_prefix='${prefix}'
>>> has_fortran='yes'
>>> has_latex='yes'
>>> has_mpicxx='yes'
>>> have_yacc_lex='no'
>>> host='x86_64-unknown-linux-gnu'
>>> host_alias=''
>>> host_cpu='x86_64'
>>> host_os='linux-gnu'
>>> host_vendor='unknown'
>>> htmldir='${docdir}'
>>> in_place_swap='yes'
>>> includedir='${prefix}/include'
>>> infodir='${datarootdir}/info'
>>> is_bigendian='no'
>>> large_file_test='no'
>>> libdir='${exec_prefix}/lib'
>>> libexecdir='${exec_prefix}/libexec'
>>> localedir='${datarootdir}/locale'
>>> localstatedir='${prefix}/var'
>>> mandir='${datarootdir}/man'
>>> mpi_mod='yes'
>>> oldincludedir='/usr/include'
>>> pdfdir='${docdir}'
>>> prefix='/nobackup/issmcd/n/build'
>>> prog=''
>>> program_transform_name='s,x,x,'
>>> psdir='${docdir}'
>>> rm_cmd=''
>>> sbindir='${exec_prefix}/sbin'
>>> sharedstatedir='${prefix}/com'
>>> sysconfdir='${prefix}/etc'
>>> target_alias=''
>>> ## confdefs.h. ##
>>> /* confdefs.h */
>>> #define PACKAGE_NAME "parallel-netcdf"
>>> #define PACKAGE_TARNAME "parallel-netcdf"
>>> #define PACKAGE_VERSION "1.8.1"
>>> #define PACKAGE_STRING "parallel-netcdf 1.8.1"
>>> #define PACKAGE_BUGREPORT "parallel-netcdf at mcs.anl.gov"
>>> #define PACKAGE_URL ""
>>> #define HAVE_UINT 1
>>> #define SIZEOF_SIZE_T 8
>>> #define SIZEOF_OFF_T 8
>>> #define SIZEOF_SIGNED_CHAR 1
>>> #define SIZEOF_UNSIGNED_CHAR 1
>>> #define SIZEOF_SHORT 2
>>> #define SIZEOF_UNSIGNED_SHORT_INT 2
>>> #define SIZEOF_UNSIGNED_SHORT 2
>>> #define SIZEOF_INT 4
>>> #define SIZEOF_UNSIGNED_INT 4
>>> #define SIZEOF_LONG 8
>>> #define SIZEOF_FLOAT 4
>>> #define SIZEOF_DOUBLE 8
>>> #define SIZEOF_LONG_LONG 8
>>> #define SIZEOF_UNSIGNED_LONG_LONG 8
>>> #define SIZEOF_USHORT 2
>>> #define SIZEOF_UINT 4
>>> #define NF_INT1_T integer*1
>>> #define NF_INT2_T integer*2
>>> #define NF_INT8_T integer*8
>>> #define NF_INT1_IS_C_SIGNED_CHAR 1
>>> #define NF_INT2_IS_C_SHORT 1
>>> #define NF_INT8_IS_C_INT 1
>>> #define NF_INT_IS_C_INT 1
>>> #define NF_REAL_IS_C_FLOAT 1
>>> #define NF_DOUBLEPRECISION_IS_C_DOUBLE 1
>>> #define NCBYTE_T byte
>>> #define NCSHORT_T integer*2
>>> #define HAVE_FUNC_MACRO 1
>>> #define HAVE_FUNCTION_MACRO 1
>>> configure: exit 0
Mark Dixon                         Email    : m.c.dixon at leeds.ac.uk
Advanced Research Computing (ARC)  Tel (int): 35429
IT Services building               Tel (ext): +44(0)113 343 5429
University of Leeds, LS2 9JT, UK
