pnetcdf and mvapich2 2.2
Mark Dixon
m.c.dixon at leeds.ac.uk
Fri Feb 3 03:31:09 CST 2017
Me again - sorry!
Now trying to build mvapich2 2.2 on centos7 with pnetcdf 1.8.1 with the
copy of GCC bundled with the OS. mvapich2 was built with configure options
--enable-shared --enable-romio --with-file-system=lustre+ufs
As with openmpi, I am able to pass tests if the build directory is on an
ext4 filesystem but not if it is on a Lustre (2.7.19.8) filesystem.
I've done a clean build with:
MPICC=`which mpicc` MPIF77=`which mpif90` MPIF90=`which mpif90` MPICXX=`which mpicxx` ./configure --prefix="$prefix" --with-mpi=$MPI_HOME --enable-debug
make
export PNETCDF_VERBOSE_DEBUG_MODE=1
make check
This is the first failure:
rm -f ./scratch.nc
rm -f ./testfile.nc
rm -f ./tooth-fairy.nc
./nc_test -c -d .
Rank 0: NC_ERANGE error at line 987 of ncmpix_put_NC_SHORT_double in ncx.c
Rank 0: NC_ERANGE error at line 1933 of ncmpix_put_NC_INT_double in ncx.c
Rank 0: NC_ERANGE error at line 3081 of ncmpix_put_NC_FLOAT_double in ncx.c
Rank 0: NC_ERANGE error at line 5470 of ncmpix_putn_NC_BYTE_double in ncx.c
./nc_test -d .
*** TESTING C nc_test for format CDF-1 ------ Rank 0: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
Rank 0: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
FAILURE at line 122 of test_ncmpi_open in test_read.c: expecting NC_ENOENT or NC_EFILE but got NC_ENOTNCRank 0: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
Rank 0: NC_EPERM error at line 839 of ncmpi_redef in mpinetcdf.c
### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
./nc_test: expects 0 failures ... fail with 1 mismatches
make[2]: *** [testing] Error 1
make[2]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test/nc_test'
make[1]: *** [check-nc_test] Error 2
make[1]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test'
make: *** [check] Error 2
Is this a similar problem as the one for openmpi?
If I run "make ptest", which doesn't seem to halt on errors, it fails on:
*** TESTING C dim_cdf12 for defining dim in CDF-1/2 format ------ Rank 1: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
Rank 2: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
Rank 3: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
Rank 0: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
Rank 0: NC_EVARSIZE error at line 489 of NC_begins in nc.c
Rank 1: NC_EVARSIZE error at line 489 of NC_begins in nc.c
Rank 2: NC_EVARSIZE error at line 489 of NC_begins in nc.c
Rank 3: NC_EVARSIZE error at line 489 of NC_begins in nc.c
Error at line 96: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
Rank 1: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
Rank 2: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
Rank 3: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
Error at line 97: err=NC_ENOTNC (NetCDF: Unknown file format)
Rank 1: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
Rank 2: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
Rank 2: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
Rank 2: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
Error at line 98: err=NC_EBADID (NetCDF: Not a valid ID)
Rank 0: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
Rank 0: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
Rank 1: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
Rank 1: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
Rank 3: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
Rank 3: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
Rank 3: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
Rank 0: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
Rank 1: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
Rank 2: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
Rank 3: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
Error at line 113: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
fail with 16 mismatches
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 84444 RUNNING AT login2.arc3.leeds.ac.uk
= EXIT CODE: 2
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
make[2]: *** [ptest4] Error 2
make[2]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test/cdf_format'
And also:
*** TESTING C modes for file create/open modes ------ Rank 0: NC_EINVAL_CMODE error at line 283 of ncmpi_create in mpinetcdf.c
Rank 1: NC_EINVAL_CMODE error at line 283 of ncmpi_create in mpinetcdf.c
Rank 2: NC_EINVAL_CMODE error at line 283 of ncmpi_create in mpinetcdf.c
Rank 3: NC_EINVAL_CMODE error at line 283 of ncmpi_create in mpinetcdf.c
Error at line 83: expect error code NC_ENOENT but got NC_ENOTNC
Error at line 89: file (./testfile.nc) should not be created
Error at line 103: expect error code NC_ENOENT but got NC_ENOTNC
Error at line 109: file (./testfile.nc) should not be created
fail with 20 mismatches
I've included my config.log below.
Any ideas, please?
Cheers,
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by parallel-netcdf configure 1.8.1, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ ./configure --prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/mvapich2/2.2/1/gnu-native --enable-debug
## Platform. ##
hostname = login2.arc3.leeds.ac.uk
uname -m = x86_64
uname -r = 3.10.0-514.6.1.el7.x86_64
uname -s = Linux
uname -v = #1 SMP Wed Jan 18 13:06:36 UTC 2017
/usr/bin/uname -p = x86_64
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /apps/mpi/bin
PATH: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin
PATH: /apps/developers/compilers/gnu/native/1/default/bin
PATH: /usr/lib64/qt-3.3/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /usr/local/sbin
PATH: /usr/sbin
PATH: /opt/puppetlabs/bin
PATH: /apps/bin
PATH: /home/ufaserv1_a/issmcd/bin
## Core tests. ##
configure:3421: checking for gcc
configure:3448: result: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc
configure:3677: checking for C compiler version
configure:3686: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc --version >&5
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-11)
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3697: $? = 0
configure:3686: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -v >&5
mpicc for MVAPICH2 version 2.2
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-initfini-array --disable-libgcj --with-isl=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/cloog-install --enable-gnu-indirect-function --with-tune=generic --with-arch_32=x86-64 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.8.5 20150623 (Red Hat 4.8.5-11) (GCC)
configure:3686: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -V >&5
gcc: error: unrecognized command line option '-V'
configure:3697: $? = 1
configure:3686: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:3717: checking whether the C compiler works
configure:3739: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc conftest.c >&5
configure:3743: $? = 0
configure:3791: result: yes
configure:3794: checking for C compiler default output file name
configure:3796: result: a.out
configure:3802: checking for suffix of executables
configure:3809: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest conftest.c >&5
configure:3813: $? = 0
configure:3835: result:
configure:3857: checking whether we are cross compiling
configure:3865: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest conftest.c >&5
configure:3869: $? = 0
configure:3876: ./conftest
configure:3880: $? = 0
configure:3895: result: no
configure:3900: checking for suffix of object files
configure:3922: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c conftest.c >&5
configure:3926: $? = 0
configure:3947: result: o
configure:3951: checking whether we are using the GNU C compiler
configure:3970: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c conftest.c >&5
configure:3970: $? = 0
configure:3979: result: yes
configure:3988: checking whether /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc accepts -g
configure:4008: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g conftest.c >&5
configure:4008: $? = 0
configure:4049: result: yes
configure:4066: checking for /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc option to accept ISO C89
configure:4129: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:4129: $? = 0
configure:4142: result: none needed
configure:4172: checking for special C compiler options needed for large files
configure:4217: result: no
configure:4223: checking for _FILE_OFFSET_BITS value needed for large files
configure:4248: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:4248: $? = 0
configure:4280: result: no
configure:4367: checking how to make dependencies
configure:4402: result: false
configure:4409: checking for MPI_Comm_rank
configure:4409: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:4409: $? = 0
configure:4409: result: yes
configure:4492: checking for MPI_File_open
configure:4492: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:4492: $? = 0
configure:4492: result: yes
configure:4976: checking for C++ compiler version
configure:4985: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx --version >&5
g++ (GCC) 4.8.5 20150623 (Red Hat 4.8.5-11)
configure:4996: $? = 0
configure:4985: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -v >&5
mpicxx for MVAPICH2 version 2.2
COLLECT_GCC=g++
Thread model: posix
configure:4985: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -V >&5
g++: error: unrecognized command line option '-V'
configure:4996: $? = 1
configure:4985: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:5000: checking whether we are using the GNU C++ compiler
configure:5019: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -c conftest.cpp >&5
configure:5019: $? = 0
configure:5028: result: yes
configure:5037: checking whether /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx accepts -g
configure:5057: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -c -g conftest.cpp >&5
configure:5057: $? = 0
configure:5098: result: yes
configure:5130: checking for MPI_File_close
configure:5130: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -o conftest -g -O2 conftest.cpp >&5
configure:5130: $? = 0
configure:5130: result: yes
configure:5216: checking if MPI C++ compiler redefines SEEK_SET
configure:5233: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -c -g -O2 conftest.cpp >&5
configure:5233: $? = 0
configure:5240: result: no
configure:5972: checking for Fortran compiler version
configure:5981: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 --version >&5
GNU Fortran (GCC) 4.8.5 20150623 (Red Hat 4.8.5-11)
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:5992: $? = 0
configure:5981: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -v >&5
mpifort for MVAPICH2 version 2.2
COLLECT_GCC=/bin/gfortran
Thread model: posix
configure:5981: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -V >&5
gfortran: error: unrecognized command line option '-V'
configure:5992: $? = 1
configure:5981: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -qversion >&5
gfortran: error: unrecognized command line option '-qversion'
configure:6001: checking whether we are using the GNU Fortran compiler
configure:6014: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c conftest.F >&5
configure:6014: $? = 0
configure:6023: result: yes
configure:6029: checking whether /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 accepts -g
configure:6040: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g conftest.f >&5
configure:6040: $? = 0
configure:6048: result: yes
configure:6084: checking build system type
configure:6098: result: x86_64-unknown-linux-gnu
configure:6118: checking host system type
configure:6131: result: x86_64-unknown-linux-gnu
configure:6156: checking how to get verbose linking output from /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
configure:6166: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:6166: $? = 0
configure:6184: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 -v conftest.f
Thread model: posix
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/f951 conftest.f -ffixed-form -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -quiet -dumpbase conftest.f -mtune=generic -march=x86-64 -auxbase conftest -g -O2 -version -fintrinsic-modules-path /usr/lib/gcc/x86_64-redhat-linux/4.8.5/finclude -o /tmp/ccpmlXE0.s
GNU Fortran (GCC) version 4.8.5 20150623 (Red Hat 4.8.5-11) (x86_64-redhat-linux)
compiled by GNU C version 4.8.5 20150623 (Red Hat 4.8.5-11), GMP version 6.0.0, MPFR version 3.1.1, MPC version 1.0.1
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
as -v -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include --64 -o /tmp/cc8t0mMz.o /tmp/ccpmlXE0.s
GNU assembler version 2.25.1 (x86_64-redhat-linux) using BFD version version 2.25.1-22.base.el7
Reading specs from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/libgfortran.spec
rename spec lib to liborig
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/collect2 --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o conftest /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtbegin.o -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. /tmp/cc8t0mMz.o -lmpifort -rpath /apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib --enable-new-dtags -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
configure:6267: result: -v
configure:6269: checking for Fortran libraries of /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
configure:6292: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 -v conftest.f
Thread model: posix
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/f951 conftest.f -ffixed-form -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -quiet -dumpbase conftest.f -mtune=generic -march=x86-64 -auxbase conftest -g -O2 -version -fintrinsic-modules-path /usr/lib/gcc/x86_64-redhat-linux/4.8.5/finclude -o /tmp/ccPUH1T9.s
as -v -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include --64 -o /tmp/cc0LBTjJ.o /tmp/ccPUH1T9.s
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/collect2 --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o conftest /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtbegin.o -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. /tmp/cc0LBTjJ.o -lmpifort -rpath /apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib --enable-new-dtags -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
configure:6488: result: -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath
configure:6507: checking whether /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc links with FCLIBS found by autoconf
configure:6532: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath >&5
configure:6532: $? = 0
configure:6534: result: yes
configure:6598: checking if mpi.mod is available
configure:6605: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:6605: $? = 0
configure:6612: result: yes
configure:6614: checking if MPIF90 is valid
configure:6624: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:6624: $? = 0
configure:6647: result: yes
configure:6796: checking for Fortran 77 compiler version
configure:6805: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 --version >&5
configure:6816: $? = 0
configure:6805: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -v >&5
Thread model: posix
configure:6805: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -V >&5
configure:6816: $? = 1
configure:6805: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -qversion >&5
configure:6825: checking whether we are using the GNU Fortran 77 compiler
configure:6838: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c conftest.F >&5
configure:6838: $? = 0
configure:6847: result: yes
configure:6853: checking whether /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 accepts -g
configure:6864: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g conftest.f >&5
configure:6864: $? = 0
configure:6872: result: yes
configure:6907: checking how to get verbose linking output from /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
configure:6917: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:6917: $? = 0
configure:6935: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 -v conftest.f
Thread model: posix
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/f951 conftest.f -ffixed-form -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -quiet -dumpbase conftest.f -mtune=generic -march=x86-64 -auxbase conftest -g -O2 -version -fintrinsic-modules-path /usr/lib/gcc/x86_64-redhat-linux/4.8.5/finclude -o /tmp/ccGv020S.s
as -v -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include -I /apps/developers/libraries/mvapich2/2.2/1/gnu-native/include --64 -o /tmp/ccXCAOeu.o /tmp/ccGv020S.s
/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/collect2 --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o conftest /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtbegin.o -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. /tmp/ccXCAOeu.o -lmpifort -rpath /apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib --enable-new-dtags -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
configure:7018: result: -v
configure:7020: checking for Fortran 77 libraries of /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
configure:7239: result: -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath
configure:7260: checking for Fortran flag needed to accept free-form source
configure:7279: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
conftest.f:2.3:
program freeform
1
Error: Non-numeric character in statement label at (1)
conftest.f:2.3:
program freeform
1
Error: Unclassifiable statement at (1)
conftest.f:4.26:
print *, 'Hello ', &
1
Error: Expected expression in PRINT statement at (1)
conftest.f:5.11:
'world.'
1
Error: Invalid character in name at (1)
configure:7279: $? = 1
configure: failed program was:
| program freeform
| ! FIXME: how to best confuse non-freeform compilers?
| 'world.'
| end
configure:7279: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -ffree-form conftest.f >&5
configure:7279: $? = 0
configure:7288: result: -ffree-form
configure:7323: checking if MPIF77 is valid
configure:7332: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:7332: $? = 0
configure:7339: result: yes
configure:7399: checking for Fortran flag to compile preprocessed .f files
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
Warning: conftest.f:3: Illegal preprocessor directive
Warning: conftest.f:4: Illegal preprocessor directive
Warning: conftest.f:6: Illegal preprocessor directive
conftest.f:5.6:
choke me
1
configure:7427: $? = 1
| program main
| #if 0
| #include <ac_nonexistent.h>
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -ftpp conftest.f >&5
gfortran: error: unrecognized command line option '-ftpp'
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -fpp conftest.f >&5
gfortran: error: unrecognized command line option '-fpp'
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Tf conftest.f >&5
conftest.f:5.6:
choke me
1
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -fpp -Tf conftest.f >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -xpp=fpp conftest.f >&5
gfortran: error: language pp=fpp not recognized
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Mpreprocess conftest.f >&5
gfortran: error: unrecognized command line option '-Mpreprocess'
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -e Z conftest.f >&5
conftest.f:5.6:
choke me
1
| program main
| #if 0
| choke me
| #endif
| end
configure:7427: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -cpp conftest.f >&5
configure:7427: $? = 0
configure:7437: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -cpp conftest.f >&5
conftest.f:4:0: fatal error: ac_nonexistent.h: No such file or directory
compilation terminated.
configure:7437: $? = 1
| program main
| #if 1
| choke me
| #endif
| end
configure:7451: result: -cpp
configure:7474: checking for Fortran flag to compile preprocessed .F files
configure:7502: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F >&5
configure:7502: $? = 0
configure:7512: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F >&5
conftest.F:4:0: fatal error: ac_nonexistent.h: No such file or directory
configure:7512: $? = 1
| program main
| #if 1
| choke me
| #endif
| end
configure:7526: result: none
configure:7549: checking for Fortran flag to compile preprocessed .f90 files
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f90 >&5
Warning: conftest.f90:3: Illegal preprocessor directive
Warning: conftest.f90:4: Illegal preprocessor directive
Warning: conftest.f90:6: Illegal preprocessor directive
conftest.f90:5.6:
choke me
1
configure:7577: $? = 1
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -ftpp conftest.f90 >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -fpp conftest.f90 >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Tf conftest.f90 >&5
conftest.f90:5.6:
choke me
1
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -fpp -Tf conftest.f90 >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -xpp=fpp conftest.f90 >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Mpreprocess conftest.f90 >&5
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -e Z conftest.f90 >&5
conftest.f90:5.6:
choke me
1
| program main
| #if 0
| choke me
| #endif
| end
configure:7577: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -cpp conftest.f90 >&5
configure:7577: $? = 0
configure:7587: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -cpp conftest.f90 >&5
conftest.f90:4:0: fatal error: ac_nonexistent.h: No such file or directory
configure:7587: $? = 1
| program main
| #if 1
| choke me
| #endif
| end
configure:7601: result: -cpp
configure:7624: checking for Fortran flag to compile preprocessed .F90 files
configure:7652: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:7652: $? = 0
configure:7662: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
conftest.F90:4:0: fatal error: ac_nonexistent.h: No such file or directory
configure:7662: $? = 1
| program main
| #if 1
| choke me
| #endif
| end
configure:7676: result: none
configure:7719: checking for Fortran flag to compile preprocessed .F files
configure:7771: result:
configure:7791: checking how to define symbols for preprocessed Fortran
configure:7813: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -DFOOBAR -DZORK=42 conftest.F >&5
configure:7813: $? = 0
configure:7822: result: -D
configure:7849: checking for Fortran flag to compile .f files
configure:7869: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:7869: $? = 0
configure:7878: result: none
configure:7903: checking for Fortran flag to compile .F files
configure:7923: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F >&5
configure:7923: $? = 0
configure:7932: result: none
configure:7957: checking for Fortran flag to compile .f90 files
configure:7977: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f90 >&5
configure:7977: $? = 0
configure:7986: result: none
configure:8011: checking for Fortran flag to compile .F90 files
configure:8031: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:8031: $? = 0
configure:8040: result: none
configure:8076: checking for Fortran flag needed to accept fixed-form source
configure:8093: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
conftest.F90:2:
C This comment should confuse free-form compilers.
1
configure:8093: $? = 1
| program main
| end
configure:8093: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -ffixed-form conftest.F90 >&5
configure:8093: $? = 0
configure:8102: result: -ffixed-form
configure:8137: checking for dummy main to link with Fortran libraries
configure:8171: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath >&5
configure:8171: $? = 0
configure:8216: result: none
configure:8249: checking for Fortran name-mangling scheme
configure:8262: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:8262: $? = 0
configure:8303: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c cfortran_test.o -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath >&5
/tmp/ccjp24QW.o: In function `main':
/nobackup/parallel-netcdf-1.8.1/conftest.c:28: undefined reference to `foobar'
collect2: error: ld returned 1 exit status
configure:8303: $? = 1
| /* confdefs.h */
| #define PACKAGE_NAME "parallel-netcdf"
| #define PACKAGE_TARNAME "parallel-netcdf"
| #define PACKAGE_VERSION "1.8.1"
| #define PACKAGE_STRING "parallel-netcdf 1.8.1"
| #define PACKAGE_BUGREPORT "parallel-netcdf at mcs.anl.gov"
| #define PACKAGE_URL ""
| /* end confdefs.h. */
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char foobar ();
| #ifdef FC_DUMMY_MAIN
| #ifndef FC_DUMMY_MAIN_EQ_F77
| # ifdef __cplusplus
| extern "C"
| # endif
| int FC_DUMMY_MAIN() { return 1; }
| #endif
| #endif
| int
| main ()
| return foobar ();
| return 0;
configure:8303: $? = 0
configure:8361: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c cfortran_test.o -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath >&5
configure:8361: $? = 0
configure:8403: result: lower case, underscore, no extra underscore
configure:8444: checking for C-equivalent to Fortran routine "SUB_A"
configure:8466: result: sub_a_
configure:8498: checking if Fortran compiler is NAG
configure:8513: result: no
configure:8524: checking Fortran compiler treating constant modifier
configure:8543: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:8543: $? = 0
configure:8582: result: 8
configure:8645: checking for a BSD-compatible install
configure:8713: result: /usr/bin/install -c
configure:8728: checking whether ln -s works
configure:8732: result: yes
configure:8739: checking whether make sets $(MAKE)
configure:8761: result: yes
configure:8771: checking for grep that handles long lines and -e
configure:8829: result: /usr/bin/grep
configure:8834: checking for egrep
configure:8896: result: /usr/bin/grep -E
configure:8910: checking for m4
configure:8926: found /usr/bin/m4
configure:8937: result: m4
configure:8993: checking m4 flags
configure:9005: result: "none"
configure:9021: checking for ar
configure:9037: found /usr/bin/ar
configure:9048: result: ar
configure:9104: checking ar flags
configure:9109: result: cru
configure:9119: checking for nm
configure:9135: found /usr/bin/nm
configure:9146: result: nm
configure:9202: checking nm flags
configure:9207: result:
configure:9257: checking for ranlib
configure:9273: found /usr/bin/ranlib
configure:9284: result: ranlib
configure:9312: checking how to run the C preprocessor
configure:9343: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E conftest.c
configure:9343: $? = 0
configure:9357: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E conftest.c
conftest.c:10:28: fatal error: ac_nonexistent.h: No such file or directory
configure:9357: $? = 1
| /* confdefs.h */
| #define F77_NAME_LOWER_USCORE /**/
configure:9382: result: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E
configure:9402: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E conftest.c
configure:9402: $? = 0
configure:9416: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E conftest.c
configure:9416: $? = 1
| /* confdefs.h */
configure:9445: checking for ANSI C header files
configure:9473: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9473: $? = 0
configure:9546: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9546: $? = 0
configure:9546: ./conftest
configure:9557: result: yes
configure:9570: checking for sys/types.h
configure:9570: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9570: $? = 0
configure:9570: result: yes
configure:9570: checking for sys/stat.h
configure:9570: checking for stdlib.h
configure:9570: checking for string.h
configure:9570: checking for memory.h
configure:9570: checking for strings.h
configure:9570: checking for inttypes.h
configure:9570: checking for stdint.h
configure:9570: checking for unistd.h
configure:9582: checking for stdbool.h that conforms to C99
configure:9657: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9657: $? = 0
configure:9664: result: yes
configure:9666: checking for _Bool
configure:9666: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9666: $? = 0
conftest.c: In function 'main':
conftest.c:64:20: error: expected expression before ')' token
if (sizeof ((_Bool)))
configure:9666: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:9666: result: yes
configure:9684: checking for inline
configure:9700: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9700: $? = 0
configure:9708: result: inline
configure:9729: checking for IEEE floating point format
configure:9767: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9767: $? = 0
configure:9767: ./conftest
configure:9776: result: yes
configure:9788: checking for strerror
configure:9788: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9788: $? = 0
configure:9788: result: yes
configure:9788: checking for access
configure:9788: checking for unlink
configure:9811: checking search.h usability
configure:9811: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9811: $? = 0
configure:9811: result: yes
configure:9811: checking search.h presence
configure:9811: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E conftest.c
configure:9811: checking for search.h
configure:9824: checking for tsearch
configure:9824: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9824: $? = 0
configure:9824: result: yes
configure:9824: checking for tdelete
configure:9843: checking for MPI_Offset
configure:9843: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9843: $? = 0
conftest.c:42:25: error: expected expression before ')' token
if (sizeof ((MPI_Offset)))
configure:9843: $? = 1
| /* confdefs.h */
| #define HAVE__BOOL 1
| #define HAVE_STDBOOL_H 1
| #define HAVE_STRERROR 1
| #define HAVE_ACCESS 1
| #define HAVE_UNLINK 1
| #define HAVE_SEARCH_H 1
| #define HAVE_TSEARCH 1
| #define HAVE_TDELETE 1
| #define PNC_MALLOC_TRACE 1
| #include <mpi.h>
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:9843: result: yes
configure:9854: checking size of MPI_Offset
configure:9859: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9859: $? = 0
configure:9859: ./conftest
configure:9874: result: 8
configure:9891: checking size of MPI_Aint
configure:9896: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9896: $? = 0
configure:9896: ./conftest
configure:9911: result: 8
configure:9954: checking for MPI_Info_dup
configure:9954: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9954: $? = 0
configure:9954: result: yes
configure:9954: checking for MPI_Info_free
configure:9954: checking for MPI_Get_address
configure:9966: checking for MPI_Type_create_subarray
configure:9966: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:9966: $? = 0
configure:9966: result: yes
configure:9966: checking for MPI_Type_create_hvector
configure:9966: checking for MPI_Type_create_hindexed
configure:9966: checking for MPI_Type_create_struct
configure:9966: checking for MPI_Type_create_resized
configure:9966: checking for MPI_Type_get_extent
configure:9977: checking if MPI constant MPI_COMBINER_DUP is defined
configure:9986: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:9986: $? = 0
configure:9987: result: yes
configure:10001: checking if MPI constant MPI_COMBINER_HVECTOR_INTEGER is defined
configure:10010: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10010: $? = 0
configure:10011: result: yes
configure:10025: checking if MPI constant MPI_COMBINER_HINDEXED_INTEGER is defined
configure:10034: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10034: $? = 0
configure:10035: result: yes
configure:10049: checking if MPI constant MPI_COMBINER_SUBARRAY is defined
configure:10058: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10058: $? = 0
configure:10059: result: yes
configure:10073: checking if MPI constant MPI_COMBINER_DARRAY is defined
configure:10082: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10082: $? = 0
configure:10083: result: yes
configure:10097: checking if MPI constant MPI_COMBINER_RESIZED is defined
configure:10106: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10106: $? = 0
configure:10107: result: yes
configure:10121: checking if MPI constant MPI_COMBINER_STRUCT_INTEGER is defined
configure:10130: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10130: $? = 0
configure:10131: result: yes
configure:10145: checking if MPI constant MPI_COMBINER_INDEXED_BLOCK is defined
configure:10154: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10154: $? = 0
configure:10155: result: yes
configure:10169: checking if MPI constant MPI_COMBINER_F90_REAL is defined
configure:10178: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10178: $? = 0
configure:10179: result: yes
configure:10193: checking if MPI constant MPI_COMBINER_F90_INTEGER is defined
configure:10202: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10202: $? = 0
configure:10203: result: yes
configure:10217: checking if MPI constant MPI_COMBINER_F90_COMPLEX is defined
configure:10226: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10226: $? = 0
configure:10227: result: yes
configure:10242: checking if MPI constant MPI_ERR_FILE_EXISTS is defined
configure:10251: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10251: $? = 0
configure:10252: result: yes
configure:10266: checking if MPI constant MPI_ERR_NO_SUCH_FILE is defined
configure:10275: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10275: $? = 0
configure:10276: result: yes
configure:10290: checking if MPI constant MPI_ERR_AMODE is defined
configure:10299: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10299: $? = 0
configure:10300: result: yes
configure:10314: checking if MPI constant MPI_ERR_NOT_SAME is defined
configure:10323: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10323: $? = 0
configure:10324: result: yes
configure:10338: checking if MPI constant MPI_ERR_BAD_FILE is defined
configure:10347: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10347: $? = 0
configure:10348: result: yes
configure:10362: checking if MPI constant MPI_ERR_READ_ONLY is defined
configure:10371: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10371: $? = 0
configure:10372: result: yes
configure:10386: checking if MPI constant MPI_ERR_ACCESS is defined
configure:10395: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10395: $? = 0
configure:10396: result: yes
configure:10410: checking if MPI constant MPI_ERR_NO_SPACE is defined
configure:10419: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10419: $? = 0
configure:10420: result: yes
configure:10434: checking if MPI constant MPI_ERR_QUOTA is defined
configure:10443: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10443: $? = 0
configure:10444: result: yes
configure:10459: checking if MPI datatype MPI_CHAR is defined
configure:10468: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10468: $? = 0
configure:10469: result: yes
configure:10483: checking if MPI datatype MPI_BYTE is defined
configure:10492: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10492: $? = 0
configure:10493: result: yes
configure:10507: checking if MPI datatype MPI_SIGNED_CHAR is defined
configure:10516: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10516: $? = 0
configure:10517: result: yes
configure:10531: checking if MPI datatype MPI_UNSIGNED_CHAR is defined
configure:10540: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10540: $? = 0
configure:10541: result: yes
configure:10555: checking if MPI datatype MPI_SHORT is defined
configure:10564: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10564: $? = 0
configure:10565: result: yes
configure:10579: checking if MPI datatype MPI_UNSIGNED_SHORT is defined
configure:10588: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10588: $? = 0
configure:10589: result: yes
configure:10603: checking if MPI datatype MPI_INT is defined
configure:10612: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10612: $? = 0
configure:10613: result: yes
configure:10627: checking if MPI datatype MPI_UNSIGNED is defined
configure:10636: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10636: $? = 0
configure:10637: result: yes
configure:10651: checking if MPI datatype MPI_LONG is defined
configure:10660: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10660: $? = 0
configure:10661: result: yes
configure:10675: checking if MPI datatype MPI_FLOAT is defined
configure:10684: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10684: $? = 0
configure:10685: result: yes
configure:10699: checking if MPI datatype MPI_DOUBLE is defined
configure:10708: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10708: $? = 0
configure:10709: result: yes
configure:10723: checking if MPI datatype MPI_LONG_LONG_INT is defined
configure:10732: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10732: $? = 0
configure:10733: result: yes
configure:10747: checking if MPI datatype MPI_UNSIGNED_LONG_LONG is defined
configure:10756: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10756: $? = 0
configure:10757: result: yes
configure:10771: checking if MPI datatype MPI_UB is defined
configure:10780: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10780: $? = 0
configure:10781: result: yes
configure:10795: checking if MPI datatype MPI_LB is defined
configure:10804: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10804: $? = 0
configure:10805: result: yes
configure:10819: checking if MPI datatype MPI_OFFSET is defined
configure:10828: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10828: $? = 0
configure:10829: result: yes
configure:10845: checking if MPI datatype MPI_CHARACTER is defined
configure:10854: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10854: $? = 0
configure:10855: result: yes
configure:10869: checking if MPI datatype MPI_REAL is defined
configure:10878: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10878: $? = 0
configure:10879: result: yes
configure:10893: checking if MPI datatype MPI_INTEGER is defined
configure:10902: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10902: $? = 0
configure:10903: result: yes
configure:10917: checking if MPI datatype MPI_DOUBLE_PRECISION is defined
configure:10926: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10926: $? = 0
configure:10927: result: yes
configure:10941: checking if MPI datatype MPI_INTEGER1 is defined
configure:10950: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10950: $? = 0
configure:10951: result: yes
configure:10965: checking if MPI datatype MPI_INTEGER2 is defined
configure:10974: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10974: $? = 0
configure:10975: result: yes
configure:10989: checking if MPI datatype MPI_INTEGER4 is defined
configure:10998: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:10998: $? = 0
configure:10999: result: yes
configure:11013: checking if MPI datatype MPI_INTEGER8 is defined
configure:11022: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11022: $? = 0
configure:11023: result: yes
configure:11037: checking if MPI datatype MPI_INTEGER16 is defined
configure:11046: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11046: $? = 0
configure:11047: result: yes
configure:11061: checking if MPI datatype MPI_REAL4 is defined
configure:11070: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11070: $? = 0
configure:11071: result: yes
configure:11085: checking if MPI datatype MPI_REAL8 is defined
configure:11094: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11094: $? = 0
configure:11095: result: yes
configure:11109: checking if MPI datatype MPI_REAL16 is defined
configure:11118: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11118: $? = 0
configure:11119: result: yes
configure:11133: checking if MPI datatype MPI_COMPLEX8 is defined
configure:11142: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11142: $? = 0
configure:11143: result: yes
configure:11157: checking if MPI datatype MPI_COMPLEX16 is defined
configure:11166: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11166: $? = 0
configure:11167: result: yes
configure:11181: checking if MPI datatype MPI_COMPLEX32 is defined
configure:11190: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11190: $? = 0
configure:11191: result: yes
configure:11221: checking whether char is unsigned
configure:11248: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11248: $? = 0
configure:11255: result: no
configure:11262: checking whether byte ordering is bigendian
configure:11277: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:94:9: error: unknown type name 'not'
not a universal capable compiler
conftest.c:94:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'universal'
conftest.c:94:15: error: unknown type name 'universal'
configure:11277: $? = 1
| /* confdefs.h */
| #define SIZEOF_MPI_OFFSET 8
| #define SIZEOF_MPI_AINT 8
| #define ENABLE_CDF5 /**/
| #define ENABLE_REQ_AGGREGATION /**/
| #define HAVE_MPI_INFO_DUP 1
| #define HAVE_MPI_INFO_FREE 1
| #define HAVE_MPI_GET_ADDRESS 1
| #define HAVE_MPI_TYPE_CREATE_SUBARRAY 1
| #define HAVE_MPI_TYPE_CREATE_HVECTOR 1
| #define HAVE_MPI_TYPE_CREATE_HINDEXED 1
| #define HAVE_MPI_TYPE_CREATE_STRUCT 1
| #define HAVE_MPI_TYPE_CREATE_RESIZED 1
| #define HAVE_MPI_TYPE_GET_EXTENT 1
| #define HAVE_MPI_COMBINER_DUP 1
| #define HAVE_MPI_COMBINER_HVECTOR_INTEGER 1
| #define HAVE_MPI_COMBINER_HINDEXED_INTEGER 1
| #define HAVE_MPI_COMBINER_SUBARRAY 1
| #define HAVE_MPI_COMBINER_DARRAY 1
| #define HAVE_MPI_COMBINER_RESIZED 1
| #define HAVE_MPI_COMBINER_STRUCT_INTEGER 1
| #define HAVE_MPI_COMBINER_INDEXED_BLOCK 1
| #define HAVE_MPI_COMBINER_F90_REAL 1
| #define HAVE_MPI_COMBINER_F90_INTEGER 1
| #define HAVE_MPI_COMBINER_F90_COMPLEX 1
| #define HAVE_MPI_ERR_FILE_EXISTS 1
| #define HAVE_MPI_ERR_NO_SUCH_FILE 1
| #define HAVE_MPI_ERR_AMODE 1
| #define HAVE_MPI_ERR_NOT_SAME 1
| #define HAVE_MPI_ERR_BAD_FILE 1
| #define HAVE_MPI_ERR_READ_ONLY 1
| #define HAVE_MPI_ERR_ACCESS 1
| #define HAVE_MPI_ERR_NO_SPACE 1
| #define HAVE_MPI_ERR_QUOTA 1
| #define HAVE_MPI_CHAR 1
| #define HAVE_MPI_BYTE 1
| #define HAVE_MPI_SIGNED_CHAR 1
| #define HAVE_MPI_UNSIGNED_CHAR 1
| #define HAVE_MPI_SHORT 1
| #define HAVE_MPI_UNSIGNED_SHORT 1
| #define HAVE_MPI_INT 1
| #define HAVE_MPI_UNSIGNED 1
| #define HAVE_MPI_LONG 1
| #define HAVE_MPI_FLOAT 1
| #define HAVE_MPI_DOUBLE 1
| #define HAVE_MPI_LONG_LONG_INT 1
| #define HAVE_MPI_UNSIGNED_LONG_LONG 1
| #define HAVE_MPI_UB 1
| #define HAVE_MPI_LB 1
| #define HAVE_MPI_OFFSET_DATATYPE 1
| #define HAVE_MPI_CHARACTER 1
| #define HAVE_MPI_REAL 1
| #define HAVE_MPI_INTEGER 1
| #define HAVE_MPI_DOUBLE_PRECISION 1
| #define HAVE_MPI_INTEGER1 1
| #define HAVE_MPI_INTEGER2 1
| #define HAVE_MPI_INTEGER4 1
| #define HAVE_MPI_INTEGER8 1
| #define HAVE_MPI_INTEGER16 1
| #define HAVE_MPI_REAL4 1
| #define HAVE_MPI_REAL8 1
| #define HAVE_MPI_REAL16 1
| #define HAVE_MPI_COMPLEX8 1
| #define HAVE_MPI_COMPLEX16 1
| #define HAVE_MPI_COMPLEX32 1
| #ifndef __APPLE_CC__
| #endif
| typedef int dummy;
configure:11330: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11330: $? = 0
configure:11356: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:108:4: error: unknown type name 'not'
not big endian
conftest.c:108:12: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'endian'
not big endian
configure:11356: $? = 1
| /* confdefs.h */
| #include <sys/types.h>
| #include <sys/param.h>
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
| not big endian
| #endif
| return 0;
configure:11516: result: no
configure:11547: checking for size_t
configure:11547: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11547: $? = 0
conftest.c:137:21: error: expected expression before ')' token
if (sizeof ((size_t)))
configure:11547: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11547: result: yes
configure:11558: checking for off_t
configure:11558: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11558: $? = 0
conftest.c:137:20: error: expected expression before ')' token
if (sizeof ((off_t)))
configure:11558: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11558: result: yes
configure:11569: checking for ssize_t
configure:11569: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11569: $? = 0
conftest.c:137:22: error: expected expression before ')' token
if (sizeof ((ssize_t)))
configure:11569: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11569: result: yes
configure:11578: checking for ptrdiff_t
configure:11578: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11578: $? = 0
conftest.c:138:24: error: expected expression before ')' token
if (sizeof ((ptrdiff_t)))
configure:11578: $? = 1
| /* confdefs.h */
| #define HAVE_SSIZE_T 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11578: result: yes
configure:11587: checking for uchar
configure:11587: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:139:13: error: 'uchar' undeclared (first use in this function)
if (sizeof (uchar))
conftest.c:139:13: note: each undeclared identifier is reported only once for each function it appears in
configure:11587: $? = 1
| /* confdefs.h */
| #define HAVE_PTRDIFF_T 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| if (sizeof (uchar))
| return 0;
| return 0;
configure:11587: result: no
configure:11596: checking for ushort
configure:11596: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11596: $? = 0
conftest.c:139:21: error: expected expression before ')' token
if (sizeof ((ushort)))
configure:11596: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11596: result: yes
configure:11605: checking for uint
configure:11605: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
configure:11605: $? = 0
conftest.c:140:19: error: expected expression before ')' token
if (sizeof ((uint)))
configure:11605: $? = 1
| /* confdefs.h */
| #define HAVE_USHORT 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11605: result: yes
configure:11614: checking for longlong
configure:11614: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:141:13: error: 'longlong' undeclared (first use in this function)
if (sizeof (longlong))
conftest.c:141:13: note: each undeclared identifier is reported only once for each function it appears in
configure:11614: $? = 1
| /* confdefs.h */
| #define HAVE_UINT 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11614: result: no
configure:11623: checking for ulonglong
configure:11623: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:141:13: error: 'ulonglong' undeclared (first use in this function)
if (sizeof (ulonglong))
configure:11623: $? = 1
| /* confdefs.h */
| #define HAVE_UINT 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11623: result: no
configure:11632: checking for int64
configure:11632: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:141:13: error: 'int64' undeclared (first use in this function)
if (sizeof (int64))
configure:11632: $? = 1
| /* confdefs.h */
| #define HAVE_UINT 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| if (sizeof (int64))
| return 0;
| return 0;
configure:11632: result: no
configure:11641: checking for uint64
configure:11641: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c >&5
conftest.c:141:13: error: 'uint64' undeclared (first use in this function)
if (sizeof (uint64))
configure:11641: $? = 1
| /* confdefs.h */
| #define HAVE_UINT 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| # ifdef __cplusplus
| extern "C"
| # endif
| #endif
| #endif
| int
| main ()
| return 0;
| return 0;
configure:11641: result: no
configure:11656: checking size of size_t
configure:11661: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11661: $? = 0
configure:11661: ./conftest
configure:11675: result: 8
configure:11689: checking size of off_t
configure:11694: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11694: $? = 0
configure:11694: ./conftest
configure:11708: result: 8
configure:11722: checking size of signed char
configure:11727: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11727: $? = 0
configure:11727: ./conftest
configure:11741: result: 1
configure:11755: checking size of unsigned char
configure:11760: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11760: $? = 0
configure:11760: ./conftest
configure:11774: result: 1
configure:11788: checking size of short
configure:11793: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11793: $? = 0
configure:11793: ./conftest
configure:11807: result: 2
configure:11821: checking size of unsigned short int
configure:11826: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11826: $? = 0
configure:11826: ./conftest
configure:11840: result: 2
configure:11854: checking size of unsigned short
configure:11859: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11859: $? = 0
configure:11859: ./conftest
configure:11873: result: 2
configure:11887: checking size of int
configure:11892: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11892: $? = 0
configure:11892: ./conftest
configure:11906: result: 4
configure:11920: checking size of unsigned int
configure:11925: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11925: $? = 0
configure:11925: ./conftest
configure:11939: result: 4
configure:11953: checking size of long
configure:11958: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11958: $? = 0
configure:11958: ./conftest
configure:11972: result: 8
configure:11986: checking size of float
configure:11991: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:11991: $? = 0
configure:11991: ./conftest
configure:12005: result: 4
configure:12019: checking size of double
configure:12024: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:12024: $? = 0
configure:12024: ./conftest
configure:12038: result: 8
configure:12052: checking size of long long
configure:12057: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:12057: $? = 0
configure:12057: ./conftest
configure:12071: result: 8
configure:12085: checking size of unsigned long long
configure:12090: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:12090: $? = 0
configure:12090: ./conftest
configure:12104: result: 8
configure:12120: checking size of ushort
configure:12125: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:12125: $? = 0
configure:12125: ./conftest
configure:12139: result: 2
configure:12155: checking size of uint
configure:12160: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -o conftest -g -O2 conftest.c >&5
configure:12160: $? = 0
configure:12160: ./conftest
configure:12174: result: 4
configure:12383: checking for C-equivalent to Fortran routine "SUB"
configure:12404: result: sub_
configure:12422: checking for Fortran "integer*1"
configure:12431: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:12431: $? = 0
configure:12432: result: yes
configure:12461: checking for Fortran "integer*2"
configure:12470: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:12470: $? = 0
configure:12471: result: yes
configure:12500: checking for Fortran "integer*8"
configure:12509: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:12509: $? = 0
configure:12510: result: yes
configure:12544: checking if Fortran "integer*1" is
configure:12554: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12557: $? = 0
configure:12560: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12563: $? = 0
configure:12566: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12569: $? = 0
configure:12572: ./conftest
configure:12575: $? = 0
configure:12577: result: "signed char" in C
configure:12619: checking if Fortran "integer*2" is
configure:12629: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12632: $? = 0
configure:12635: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12638: $? = 0
configure:12641: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12644: $? = 0
configure:12647: ./conftest
configure:12650: $? = 0
configure:12652: result: "short" in C
configure:12694: checking if Fortran "integer*8" is
configure:12704: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12707: $? = 0
configure:12710: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12713: $? = 0
configure:12716: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12719: $? = 0
configure:12722: ./conftest
configure:12725: $? = 0
configure:12727: result: "int" in C
configure:12767: checking if Fortran "integer" is
configure:12777: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12780: $? = 0
configure:12783: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12786: $? = 0
configure:12789: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12792: $? = 0
configure:12795: ./conftest
configure:12798: $? = 0
configure:12800: result: "int" in C
configure:12838: checking if Fortran "real" is
configure:12848: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12851: $? = 0
configure:12854: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12857: $? = 0
configure:12860: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12863: $? = 0
configure:12866: ./conftest
configure:12869: $? = 0
configure:12871: result: "float" in C
configure:12909: checking if Fortran "doubleprecision" is
configure:12919: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -c -g -O2 conftest.c
configure:12922: $? = 0
configure:12925: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -g -O2 -c conftestf.f
configure:12928: $? = 0
configure:12931: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -o conftest -g -O2 conftestf.o conftest.o
configure:12934: $? = 0
configure:12937: ./conftest
configure:12940: $? = 0
configure:12942: result: "double" in C
configure:12973: checking for Fortran-equivalent to netCDF "byte"
configure:12988: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:12988: $? = 0
configure:13004: result: byte
configure:13010: checking for Fortran-equivalent to netCDF "short"
configure:13025: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:13025: $? = 0
configure:13041: result: integer*2
configure:13054: checking for Fortran NFMPI_OFFSET "integer*8"
configure:13068: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:13068: $? = 0
configure:13082: result: yes
configure:13097: checking Fortran 90 module extension
configure:13119: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:13119: $? = 0
configure:13136: result: mod
configure:13154: checking Fortran 90 module inclusion flag
configure:13176: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:13176: $? = 0
configure:13190: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Iconftest.dir -Iconftest.dir conftest.F90 >&5
configure:13190: $? = 0
configure:13211: result: -I
configure:13233: checking Fortran 90 module output flag
configure:13261: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Jsub conftest.F90 >&5
configure:13261: $? = 0
configure:13270: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 -Jsub conftest.F90 >&5
Warning: Nonexistent include directory "sub"
configure:13270: $? = 0
configure:13292: result: -J
configure:13320: checking for Fortran 77 GNU intrinsic INT
configure:13344: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:13344: $? = 0
configure:13357: result: yes
configure:13370: checking for Fortran 77 intrinsic INT1
configure:13388: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
conftest.f:7.16:
i1 = INT1(r)
1
Error: Function 'int1' at (1) has no IMPLICIT type
configure:13388: $? = 1
| program main
| implicit none
| real r
| integer*1 i1
| r = 12.34
| i1 = INT1(r)
| end
configure:13401: result: no
configure:13413: checking for Fortran 77 intrinsic INT2
configure:13431: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:13431: $? = 0
configure:13444: result: yes
configure:13456: checking for Fortran 77 intrinsic INT8
configure:13474: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.f >&5
configure:13474: $? = 0
configure:13487: result: yes
configure:13508: checking if Fortran 90 compiler capitalizes .mod filenames
configure:13517: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90 -c -g -O2 conftest.F90 >&5
configure:13517: $? = 0
configure:13527: result: no
configure:13647: checking for manual-page index command
configure:13649: result:
configure:13685: checking if C++ macro __func__ or __FUNCTION__ is defined
configure:13717: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -c -g -O2 conftest.cpp >&5
configure:13717: $? = 0
configure:13740: /apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx -c -g -O2 conftest.cpp >&5
configure:13740: $? = 0
configure:13752: result: yes
configure:13854: checking for latex
configure:13872: found /usr/bin/latex
configure:13884: result: /usr/bin/latex
configure:13894: checking for dvipdf
configure:13912: found /usr/bin/dvipdf
configure:13924: result: /usr/bin/dvipdf
configure:13986: checking for gcc
configure:14004: found /usr/bin/gcc
configure:14017: result: /usr/bin/gcc
configure:14170: creating ./config.status
## Running config.status. ##
This file was extended by parallel-netcdf config.status 1.8.1, which was
generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on login2.arc3.leeds.ac.uk
config.status:1082: creating macros.make
config.status:1082: creating Makefile
config.status:1082: creating pnetcdf_pc
config.status:1082: creating src/Makefile
config.status:1082: creating src/lib/Makefile
config.status:1082: creating src/lib/pnetcdf.h
config.status:1082: creating src/utils/Makefile
config.status:1082: creating src/utils/ncmpidump/Makefile
config.status:1082: creating src/utils/ncmpidiff/Makefile
config.status:1082: creating src/utils/ncmpigen/Makefile
config.status:1082: creating src/utils/ncmpivalid/Makefile
config.status:1082: creating src/utils/pnetcdf_version/Makefile
config.status:1082: creating src/utils/ncoffsets/Makefile
config.status:1082: creating test/Makefile
config.status:1082: creating test/common/Makefile
config.status:1082: creating test/nc_test/Makefile
config.status:1082: creating test/C/Makefile
config.status:1082: creating test/fandc/Makefile
config.status:1082: creating test/testcases/Makefile
config.status:1082: creating test/nonblocking/Makefile
config.status:1082: creating test/header/Makefile
config.status:1082: creating test/cdf_format/Makefile
config.status:1082: creating test/largefile/Makefile
config.status:1082: creating examples/C/Makefile
config.status:1082: creating examples/tutorial/Makefile
config.status:1082: creating examples/Makefile
config.status:1082: creating doc/Makefile
config.status:1082: creating man/Makefile
config.status:1082: creating scripts/Makefile
config.status:1082: creating benchmarks/Makefile
config.status:1082: creating benchmarks/C/Makefile
config.status:1082: creating test/nf_test/Makefile
config.status:1082: creating test/nf_test/tests.inc
config.status:1082: creating test/nf90_test/Makefile
config.status:1082: creating test/F90/Makefile
config.status:1082: creating examples/F77/Makefile
config.status:1082: creating examples/F90/Makefile
config.status:1082: creating src/libf90/Makefile
config.status:1082: creating src/libf90/pnetcdf.f90
config.status:1082: creating src/libf90/api.f90
config.status:1082: creating src/libf90/nfmpi_constants.f90
config.status:1082: creating src/libf/Makefile
config.status:1082: creating src/libf/pnetcdf.inc
config.status:1082: creating src/libcxx/Makefile
config.status:1082: creating examples/CXX/Makefile
config.status:1082: creating test/CXX/Makefile
config.status:1082: creating benchmarks/FLASH-IO/Makefile
config.status:1082: creating test/subfile/Makefile
config.status:1082: creating stamp-h
config.status:1082: creating pnetcdf-config
config.status:1082: creating check_install
config.status:1082: creating src/lib/ncconfig.h
config.status:1082: creating src/libf/nfconfig_inc
## Cache variables. ##
ac_cv_CHECK_MPI_CPP_SEEK_SET=no
ac_cv_NFMPI_OFFSET=yes
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_bigendian=no
ac_cv_c_char_unsigned=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_ieeefloat=yes
ac_cv_c_inline=inline
ac_cv_cxx_compiler_gnu=yes
ac_cv_cxx_macro_func=yes
ac_cv_cxx_macro_function=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=gcc
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=g++
ac_cv_env_F77_set=set
ac_cv_env_F77_value=gfortran
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=set
ac_cv_env_FC_value=gfortran
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FPPFLAGS_set=
ac_cv_env_FPPFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MPICC_set=set
ac_cv_env_MPICC_value=/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc
ac_cv_env_MPICXX_set=set
ac_cv_env_MPICXX_value=/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx
ac_cv_env_MPIF77_set=set
ac_cv_env_MPIF77_value=/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
ac_cv_env_MPIF90_set=set
ac_cv_env_MPIF90_value=/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90
ac_cv_env_RM_set=
ac_cv_env_RM_value=
ac_cv_env_TEST_MPIRUN_set=
ac_cv_env_TEST_MPIRUN_value=
ac_cv_env_TEST_OUTDIR_set=
ac_cv_env_TEST_OUTDIR_value=
ac_cv_env_TEST_SEQRUN_set=
ac_cv_env_TEST_SEQRUN_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=yes
ac_cv_f77_gnu_int=yes
ac_cv_f77_int1=no
ac_cv_f77_int2=yes
ac_cv_f77_int8=yes
ac_cv_f77_libs=' -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath'
ac_cv_fc_compiler_gnu=yes
ac_cv_fc_compiler_nag=no
ac_cv_fc_constant_modifier=8
ac_cv_fc_dummy_main=none
ac_cv_fc_fixedform=-ffixed-form
ac_cv_fc_freeform=-ffree-form
ac_cv_fc_libs=' -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath'
ac_cv_fc_mangling='lower case, underscore, no extra underscore'
ac_cv_fc_module_ext=mod
ac_cv_fc_module_flag=-I
ac_cv_fc_module_output_flag=-J
ac_cv_fc_pp_define=-D
ac_cv_fc_pp_srcext_F90=
ac_cv_fc_pp_srcext_F=
ac_cv_fc_pp_srcext_f90=-cpp
ac_cv_fc_pp_srcext_f=-cpp
ac_cv_fc_srcext_F90=none
ac_cv_fc_srcext_F=none
ac_cv_fc_srcext_f90=none
ac_cv_fc_srcext_f=none
ac_cv_fortran_dummy_main=none
ac_cv_func_MPI_Comm_rank=yes
ac_cv_func_MPI_File_close=yes
ac_cv_func_MPI_File_open=yes
ac_cv_func_MPI_Get_address=yes
ac_cv_func_MPI_Info_dup=yes
ac_cv_func_MPI_Info_free=yes
ac_cv_func_MPI_Type_create_hindexed=yes
ac_cv_func_MPI_Type_create_hvector=yes
ac_cv_func_MPI_Type_create_resized=yes
ac_cv_func_MPI_Type_create_struct=yes
ac_cv_func_MPI_Type_create_subarray=yes
ac_cv_func_MPI_Type_get_extent=yes
ac_cv_func_access=yes
ac_cv_func_strerror=yes
ac_cv_func_tdelete=yes
ac_cv_func_tsearch=yes
ac_cv_func_unlink=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_search_h=yes
ac_cv_header_stdbool_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_m4_stdout=
ac_cv_objext=o
ac_cv_path_DVIPDF=/usr/bin/dvipdf
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_LATEX=/usr/bin/latex
ac_cv_path_SEQ_CC=/usr/bin/gcc
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AR=ar
ac_cv_prog_CPP='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc -E'
ac_cv_prog_M4=m4
ac_cv_prog_NM=nm
ac_cv_prog_ac_ct_CC=/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_f77_v=-v
ac_cv_prog_f90_uppercase_mod=no
ac_cv_prog_fc_g=yes
ac_cv_prog_fc_v=-v
ac_cv_prog_make_make_set=yes
ac_cv_sizeof_MPI_Aint=8
ac_cv_sizeof_MPI_Offset=8
ac_cv_sizeof_double=8
ac_cv_sizeof_float=4
ac_cv_sizeof_int=4
ac_cv_sizeof_long=8
ac_cv_sizeof_long_long=8
ac_cv_sizeof_off_t=8
ac_cv_sizeof_short=2
ac_cv_sizeof_signed_char=1
ac_cv_sizeof_size_t=8
ac_cv_sizeof_uint=4
ac_cv_sizeof_unsigned_char=1
ac_cv_sizeof_unsigned_int=4
ac_cv_sizeof_unsigned_long_long=8
ac_cv_sizeof_unsigned_short=2
ac_cv_sizeof_unsigned_short_int=2
ac_cv_sizeof_ushort=2
ac_cv_sys_file_offset_bits=no
ac_cv_sys_largefile_CC=no
ac_cv_type_MPI_Offset=yes
ac_cv_type__Bool=yes
ac_cv_type_int64=no
ac_cv_type_longlong=no
ac_cv_type_off_t=yes
ac_cv_type_ptrdiff_t=yes
ac_cv_type_size_t=yes
ac_cv_type_ssize_t=yes
ac_cv_type_uchar=no
ac_cv_type_uint64=no
ac_cv_type_uint=yes
ac_cv_type_ulonglong=no
ac_cv_type_ushort=yes
## Output variables. ##
AR='ar'
ARFLAGS='cru'
BUILDDIR='/nobackup/parallel-netcdf-1.8.1'
CC='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc'
CC_MAKEDEPEND='false'
CFLAGS='-g -O0'
CONFIGURE_ARGS_CLEAN='--prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/mvapich2/2.2/1/gnu-native --enable-debug'
CONFIG_DATE='Fri Feb 3 09:06:12 GMT 2017'
CPPFLAGS=''
CXX='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx'
CXXCPPFLAGS=''
CXXFLAGS='-g -O0'
DEFS='-DHAVE_CONFIG_H'
DVIPDF='/usr/bin/dvipdf'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_ERANGE_FILL='1'
ENABLE_SUBFILING='0'
EXEEXT=''
F77='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90'
F77FLAGS='-g -O0'
F77FLAGS_F=''
F77FLAGS_f=''
F77PPFLAGS_F=''
F77PPFLAGS_f='-cpp'
F77_SUPPORT_FREEFORM='yes'
F90FLAGS='-g -O0'
F90FLAGS_F90=''
F90FLAGS_f90=''
F90LDFLAGS=''
F90LIBS=' -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath'
F90PPFLAGS_F90=''
F90PPFLAGS_f90='-cpp'
FC='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90'
FCFLAGS='-g -O0'
FCFLAGS_F90=''
FCFLAGS_F=''
FCFLAGS_f90=''
FCFLAGS_f=''
FCLIBS=' -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath'
FC_DEFINE='-D'
FC_MODEXT='mod'
FC_MODINC='-I'
FC_MODOUT='-J'
FFIXEDFORMFLAG='-ffixed-form'
FFLAGS='-g -O2'
FFREEFORMFLAG='-ffree-form'
FLDFLAGS=''
FLIBS=' -L/apps/developers/libraries/mvapich2/2.2/1/gnu-native/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../.. -lmpifort -lmpi -lgfortran -lm -lquadmath'
FPP=''
FPPFLAGS=''
GREP='/usr/bin/grep'
HAVE_F77_GNU_INT='yes'
HAVE_F77_INT1='no'
HAVE_F77_INT2='yes'
HAVE_F77_INT8='yes'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INTENTV='INOUT'
LATEX='/usr/bin/latex'
LCOV_LIB=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LN_S='ln -s'
LTLIBOBJS=''
M4='m4'
M4FFLAGS=''
M4FLAGS=''
MAKEWHATIS_CMD=''
MPICC='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc'
MPICXX='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicxx'
MPIF77='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90'
MPIF90='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpif90'
NAG_FCFLAGS=''
NAGf90FPPFLAGS=''
NM='nm'
NMFLAGS=''
OBJEXT='o'
PACKAGE_BUGREPORT='parallel-netcdf at mcs.anl.gov'
PACKAGE_NAME='parallel-netcdf'
PACKAGE_STRING='parallel-netcdf 1.8.1'
PACKAGE_TARNAME='parallel-netcdf'
PACKAGE_URL=''
PACKAGE_VERSION='1.8.1'
PATH_SEPARATOR=':'
PNETCDF_DEBUG='1'
PNETCDF_INC='/nobackup/parallel-netcdf-1.8.1/src/libf90'
PNETCDF_LIB='-L/nobackup/parallel-netcdf-1.8.1/src/lib'
PNETCDF_RELEASE_DATE2='2017-01-28'
PNETCDF_RELEASE_DATE='28 Jan 2017'
PNETCDF_VERSION='1.8.1'
PNETCDF_VERSION_MAJOR='1'
PNETCDF_VERSION_MINOR='8'
PNETCDF_VERSION_PRE=''
PNETCDF_VERSION_SUB='1'
PNF_FILL_INT64='-9223372036854775806_8'
PNF_FILL_UINT64='18446744073709551614_8'
PNF_FILL_UINT='4294967295_8'
PNF_INT8_MODIFIER=''
PNF_X_INT8_MAX='9223372036854775807_8'
PNF_X_INT8_MIN='-9223372036854775807_8'
PNF_X_UINT8_MAX='18446744073709551615_8'
PNF_X_UINT_MAX='4294967295_8'
RANLIB='ranlib'
RELAX_COORD_BOUND='0'
RM='rm'
SEQ_CC='/usr/bin/gcc'
SET_MAKE=''
SHELL='/bin/sh'
SIZEOF_MPI_AINT_IS_4='no'
SIZEOF_MPI_OFFSET='8'
TEST_MPIRUN='mpiexec -n NP'
TEST_OUTDIR='.'
TEST_SEQRUN=''
UPPER_CASE_MOD='no'
USE_MPIF_HEADER='use mpi, only: MPI_OFFSET_KIND'
WHATIS='whatis'
ac_ct_CC='/apps/developers/libraries/mvapich2/2.2/1/gnu-native/bin/mpicc'
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_FC=''
ac_empty=''
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
enable_coverage='no'
enable_erange_fill='yes'
enable_subfiling='no'
exec_prefix='${prefix}'
has_fortran='yes'
has_latex='yes'
has_mpicxx='yes'
have_yacc_lex='no'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
in_place_swap='yes'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
is_bigendian='no'
large_file_test='no'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mpi_mod='yes'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/nobackup/issmcd/n/build'
prog=''
program_transform_name='s,x,x,'
psdir='${docdir}'
rm_cmd=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
#define HAVE_UINT 1
#define SIZEOF_SIZE_T 8
#define SIZEOF_OFF_T 8
#define SIZEOF_SIGNED_CHAR 1
#define SIZEOF_UNSIGNED_CHAR 1
#define SIZEOF_SHORT 2
#define SIZEOF_UNSIGNED_SHORT_INT 2
#define SIZEOF_UNSIGNED_SHORT 2
#define SIZEOF_INT 4
#define SIZEOF_UNSIGNED_INT 4
#define SIZEOF_LONG 8
#define SIZEOF_FLOAT 4
#define SIZEOF_DOUBLE 8
#define SIZEOF_LONG_LONG 8
#define SIZEOF_UNSIGNED_LONG_LONG 8
#define SIZEOF_USHORT 2
#define SIZEOF_UINT 4
#define NF_INT1_T integer*1
#define NF_INT2_T integer*2
#define NF_INT8_T integer*8
#define NF_INT1_IS_C_SIGNED_CHAR 1
#define NF_INT2_IS_C_SHORT 1
#define NF_INT8_IS_C_INT 1
#define NF_INT_IS_C_INT 1
#define NF_REAL_IS_C_FLOAT 1
#define NF_DOUBLEPRECISION_IS_C_DOUBLE 1
#define NCBYTE_T byte
#define NCSHORT_T integer*2
#define HAVE_FUNC_MACRO 1
#define HAVE_FUNCTION_MACRO 1
configure: exit 0
More information about the parallel-netcdf
