pnetcdf and openmpi 2.0.2?
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Feb 2 13:17:27 CST 2017
Hi, Mark
After some digging, I found this is related to the file layout alignment
when file striping info is available (such as using Lustre).
You can safely ignore this test program.
I will do more testing, fix the problem and get back to you soon.
(maybe another minor release 1.8.2 soon.)
Wei-keng
On Feb 2, 2017, at 12:14 PM, Wei-keng Liao wrote:
> Hi, Mark
> I am puzzled by the debugging print statement from your run.
> The test program failed to report the first error code NC_EDIMSIZE, but
> went on to the next error NC_EVARSIZE. This might be something related
> to the library linking problem.
> Are you doing VPATH build? If that is the case, could you try a clean build,
> i.e. run "make clean" on both the source and vpath directories and run "make"
> in vpath directory to re-build the PnetCDF library?
> If vpath build was not use, I can only suggest a clean build.
> I also wonder if you do make check or test for OpenMPI to
> ensure the OpenMPI is built correctly. Or test it with a small MPI program.
> Wei-keng
> On Feb 2, 2017, at 10:28 AM, Mark Dixon wrote:
>> On Thu, 2 Feb 2017, Wei-keng Liao wrote:
>>> Could you send me the file config.log from using openmpi 2.0.2 with the 17.0.1 intel compilers?
>> Hi Wei-keng,
>> Appended below - thanks.
>>> Could you also try the followings?
>>> 1. rebuild PnetCDF by adding "–enable-debug" option on the command line
>>> 2. set environment variable PNETCDF_VERBOSE_DEBUG_MODE to 1
>>> 3. cd test/cdf_format and run commands: make dim_cdf12 ; ./dim_cdf12
>> $ cd test/cdf_format
>> $ make dim_cdf12
>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0       -I../../src/lib -I./../common -DHAVE_CONFIG_H  -DPNETCDF_DEBUG -c dim_cdf12.c
>> set -e; cd ../common && make  all
>> make[1]: Entering directory `/nobackup/parallel-netcdf-1.8.1/test/common'
>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0       -I../../src/lib -DHAVE_CONFIG_H  -DPNETCDF_DEBUG -c testutils.c
>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90  -I../../src/lib   -DPNETCDF_DEBUG -g -O0   -c testutilsf.F90
>> ar cru libtestutils.a testutils.o testutilsf.o
>> make[1]: Leaving directory `/nobackup/parallel-netcdf-1.8.1/test/common'
>> /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -g  -O0   -o dim_cdf12 dim_cdf12.o  -L../common /nobackup/parallel-netcdf-1.8.1/src/lib/libpnetcdf.a -ltestutils $ ./dim_cdf12
>> *** TESTING C   dim_cdf12 for defining dim in CDF-1/2 format       ------ Rank 0: NC_EDIMSIZE error at line 407 of ncmpi_def_dim in dim.c
>> Rank 0: NC_EVARSIZE error at line 489 of NC_begins in nc.c
>> Error at line 96: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
>> Rank 0: NC_ENOTNC error at line 1805 of ncmpii_hdr_get_NC in header.c
>> Rank 0: NC_ENOTNC error at line 576 of ncmpi_open in mpinetcdf.c
>> Error at line 97: err=NC_ENOTNC (NetCDF: Unknown file format)
>> Rank 0: NC_EBADID error at line 233 of ncmpii_NC_check_id in nc.c
>> Rank 0: NC_EBADID error at line 1177 of ncmpi_close in mpinetcdf.c
>> Error at line 98: err=NC_EBADID (NetCDF: Not a valid ID)
>> Rank 0: NC_EVARSIZE error at line 1055 of ncmpii_NC_check_vlens in nc.c
>> Error at line 113: err=NC_EVARSIZE (NetCDF: One or more variable sizes violate format constraints)
>> fail with 4 mismatches
>> Cheers,
>> Mark
>> And the config.log file...
>> This file contains any messages produced by compilers while
>> running configure, to aid debugging if configure makes a mistake.
>> It was created by parallel-netcdf configure 1.8.1, which was
>> generated by GNU Autoconf 2.69.  Invocation command line was
>> $ ./configure --prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1 --enable-debug
>> ## Platform. ##
>> hostname = login2.arc3.leeds.ac.uk
>> uname -m = x86_64
>> uname -r = 3.10.0-514.6.1.el7.x86_64
>> uname -s = Linux
>> uname -v = #1 SMP Wed Jan 18 13:06:36 UTC 2017
>> /usr/bin/uname -p = x86_64
>> /bin/uname -X     = unknown
>> /bin/arch              = x86_64
>> /usr/bin/arch -k       = unknown
>> /usr/convex/getsysinfo = unknown
>> /usr/bin/hostinfo      = unknown
>> /bin/machine           = unknown
>> /usr/bin/oslevel       = unknown
>> /bin/universe          = unknown
>> PATH: /apps/mpi/bin
>> PATH: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin
>> PATH: /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64
>> PATH: /apps/developers/compilers/intel/17.0.1/1/default/debugger_2017/gdb/intel64_mic/bin
>> PATH: /usr/lib64/qt-3.3/bin
>> PATH: /usr/local/bin
>> PATH: /usr/bin
>> PATH: /usr/local/sbin
>> PATH: /usr/sbin
>> PATH: /opt/puppetlabs/bin
>> PATH: /apps/bin
>> PATH: /home/ufaserv1_a/issmcd/bin
>> ## Core tests. ##
>> configure:3421: checking for gcc
>> configure:3448: result: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>> configure:3677: checking for C compiler version
>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc --version >&5
>> icc (ICC) 17.0.1 20161005
>> Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
>> configure:3697: $? = 0
>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -v >&5
>> icc version 17.0.1 (gcc version 4.8.5 compatibility)
>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -V >&5
>> Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>> configure:3686: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -qversion >&5
>> icc: command line warning #10006: ignoring unknown option '-qversion'
>> icc: command line error: no files specified; for help type "icc -help"
>> configure:3697: $? = 1
>> configure:3717: checking whether the C compiler works
>> configure:3739: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc    conftest.c  >&5
>> configure:3743: $? = 0
>> configure:3791: result: yes
>> configure:3794: checking for C compiler default output file name
>> configure:3796: result: a.out
>> configure:3802: checking for suffix of executables
>> configure:3809: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest    conftest.c  >&5
>> configure:3813: $? = 0
>> configure:3835: result: configure:3857: checking whether we are cross compiling
>> configure:3865: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest    conftest.c  >&5
>> configure:3869: $? = 0
>> configure:3876: ./conftest
>> configure:3880: $? = 0
>> configure:3895: result: no
>> configure:3900: checking for suffix of object files
>> configure:3922: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c   conftest.c >&5
>> configure:3926: $? = 0
>> configure:3947: result: o
>> configure:3951: checking whether we are using the GNU C compiler
>> configure:3970: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c   conftest.c >&5
>> configure:3970: $? = 0
>> configure:3979: result: yes
>> configure:3988: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc accepts -g
>> configure:4008: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g  conftest.c >&5
>> configure:4008: $? = 0
>> configure:4049: result: yes
>> configure:4066: checking for /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc option to accept ISO C89
>> configure:4129: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc  -c -g -O2  conftest.c >&5
>> configure:4129: $? = 0
>> configure:4142: result: none needed
>> configure:4172: checking for special C compiler options needed for large files
>> configure:4217: result: no
>> configure:4223: checking for _FILE_OFFSET_BITS value needed for large files
>> configure:4248: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:4248: $? = 0
>> configure:4280: result: no
>> configure:4367: checking how to make dependencies
>> configure:4402: result: false
>> configure:4409: checking for MPI_Comm_rank
>> configure:4409: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:4409: $? = 0
>> configure:4409: result: yes
>> configure:4492: checking for MPI_File_open
>> configure:4492: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:4492: $? = 0
>> configure:4492: result: yes
>> configure:4976: checking for C++ compiler version
>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx --version >&5
>> icpc (ICC) 17.0.1 20161005
>> configure:4996: $? = 0
>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -v >&5
>> icpc version 17.0.1 (gcc version 4.8.5 compatibility)
>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -V >&5
>> Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>> configure:4985: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -qversion >&5
>> icpc: command line warning #10006: ignoring unknown option '-qversion'
>> icpc: command line error: no files specified; for help type "icpc -help"
>> configure:4996: $? = 1
>> configure:5000: checking whether we are using the GNU C++ compiler
>> configure:5019: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c   conftest.cpp >&5
>> configure:5019: $? = 0
>> configure:5028: result: yes
>> configure:5037: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx accepts -g
>> configure:5057: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g  conftest.cpp >&5
>> configure:5057: $? = 0
>> configure:5098: result: yes
>> configure:5130: checking for MPI_File_close
>> configure:5130: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -o conftest -g -O2   conftest.cpp  >&5
>> configure:5130: $? = 0
>> configure:5130: result: yes
>> configure:5216: checking if MPI C++ compiler redefines SEEK_SET configure:5233: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>> configure:5233: $? = 0
>> configure:5240: result: no
>> configure:5972: checking for Fortran compiler version
>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 --version >&5
>> ifort (IFORT) 17.0.1 20161005
>> configure:5992: $? = 0
>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -v >&5
>> ifort version 17.0.1
>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -V >&5
>> Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.1.132 Build 20161005
>> configure:5981: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -qversion >&5
>> ifort: command line warning #10006: ignoring unknown option '-qversion'
>> ifort: command line error: no files specified; for help type "ifort -help"
>> configure:5992: $? = 1
>> configure:6001: checking whether we are using the GNU Fortran compiler
>> configure:6014: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c   conftest.F >&5
>> conftest.F(3): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>>      choke me
>> compilation aborted for conftest.F (code 1)
>> configure:6014: $? = 1
>> configure: failed program was:
>> |       program main
>> | #ifndef __GNUC__
>> |        choke me
>> | #endif
>> | |       end
>> configure:6023: result: no
>> configure:6029: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 accepts -g
>> configure:6040: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> configure:6040: $? = 0
>> configure:6048: result: yes
>> configure:6084: checking build system type
>> configure:6098: result: x86_64-unknown-linux-gnu
>> configure:6118: checking host system type
>> configure:6131: result: x86_64-unknown-linux-gnu
>> configure:6156: checking how to get verbose linking output from /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> configure:6166: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> configure:6166: $? = 0
>> configure:6184: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
>> /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/fortcom    -D__INTEL_COMPILER=1700 -D__INTEL_COMPILER_UPDATE=1 -D__unix__ -D__unix -D__linux__ -D__linux -D__gnu_linux__ -Dunix -Dlinux -D__ELF__ -D__x86_64 -D__x86_64__ -D__amd64 -D__amd64__ -D__INTEL_COMPILER_BUILD_DATE=20161005 -D__INTEL_OFFLOAD -D__i686 -D__i686__ -D__pentiumpro -D__pentiumpro__ -D__pentium4 -D__pentium4__ -D__tune_pentium4__ -D__SSE2__ -D__SSE2_MATH__ -D__SSE__ -D__SSE_MATH__ -D__MMX__ -mGLOB_pack_sort_init_list -I. -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/include -I/apps/developers/compilers/intel/17.0.!
>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/iforts8OIo9.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/devel!
>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortUEEBPwas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_use!
>> _base_pointer=1 -mCG_bnl_movbe=T -mGLOB_extended_instructions=0x8 -mP3O!
>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort0709387709De25UH -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/iforts8OIo9.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchAnCxhU -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfileTg0G0A -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS -mG!
>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/iforts8OIo9.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>> #include "..." search starts here:
>> #include <...> search starts here:
>> /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include
>> /usr/local/include
>> /usr/include/
>> /usr/include
>> End of search list.
>> ld    /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtbegin.o --eh-frame-hdr --build-id -dynamic-linker /lib64/ld-linux-x86-64.so.2 -m elf_x86_64 -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest /apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/for_main.o -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -!
>> L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/l!
>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/iforts8OIo9.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>> configure:6267: result: -v
>> configure:6269: checking for Fortran libraries of /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> configure:6292: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/ifortFvK4TU.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/devel!
>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortLXRBSkas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_use!
>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort1771009391GShk4m -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/ifortFvK4TU.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchfcWcSK -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfileM3LbSs -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS -mG!
>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/ifortFvK4TU.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>> /usr/local/include
>> /usr/include/
>> /usr/include
>> End of search list.
>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/ifortFvK4TU.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>> configure:6488: result:  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/!
>> compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
>> configure:6507: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc links with FCLIBS found by autoconf
>> configure:6532: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/..!
>> /lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  >&5
>> configure:6532: $? = 0
>> configure:6534: result: yes
>> configure:6598: checking if mpi.mod is available
>> configure:6605: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> configure:6605: $? = 0
>> configure:6612: result: yes
>> configure:6614: checking if MPIF90 is valid
>> configure:6624: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> configure:6624: $? = 0
>> configure:6647: result: yes
>> configure:6796: checking for Fortran 77 compiler version
>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 --version >&5
>> configure:6816: $? = 0
>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -v >&5
>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -V >&5
>> configure:6805: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -qversion >&5
>> configure:6816: $? = 1
>> configure:6825: checking whether we are using the GNU Fortran 77 compiler
>> configure:6838: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c  conftest.F >&5
>>      choke me
>> configure:6838: $? = 1
>> |       program main
>> | #ifndef __GNUC__
>> |        choke me
>> | #endif
>> | |       end
>> configure:6847: result: no
>> configure:6853: checking whether /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 accepts -g
>> configure:6864: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:6864: $? = 0
>> configure:6872: result: yes
>> configure:6907: checking how to get verbose linking output from /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> configure:6917: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:6917: $? = 0
>> configure:6935: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g -v conftest.f
>> 1/1/default/compilers_and_libraries_2017.1.132/linux/daal/include -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/intel64 -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include/icc -I/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/include -I/usr/local/include -I/usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/include/ -I/usr/include "-fp_modbits honor_f32_conversion" "-fp_modbits honor_f64_conversion" -O0 -g2 "-reentrancy threaded" -simd -offload_host -mGLOB_em64t=TRUE -mP1OPT_version=17.0-intel64 -mGLOB_diag_file=/tmp/ifortuvU6OS.diag -mGLOB_long_size_64 -mGLOB_routine_pointer_size_64 -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE -mGLOB_gcc_version=485 "-mGLOB_options_string=-I/apps/devel!
>> opers/libraries/openmpi/2.0.2/1/intel-17.0.1/include -I/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -o conftest -g -v -Wl,-rpath -Wl,/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -Wl,--enable-new-dtags -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" -mGLOB_cxx_limited_range=FALSE -mCG_extend_parms=FALSE -mGLOB_compiler_bin_directory=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64 -mP3OPT_emit_line_numbers -mP2OPT_suppress_unreferenced_locals=FALSE -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL -mDEBUG_info_level=2 -mDEBUG_use_indirect_strings=TRUE -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF40 -mGLOB_as_output_backup_file_name=/tmp/ifortyW3KXAas_.s -mGLOB_dashboard_use_source_name -mGLOB_instruction_tuning=0x0 -mGLOB_uarch_tuning=0x0 -mGLOB_product_id_code=0x22006d8f -mGLOB_maintain_errno -mGLOB_noinline_intrinsics -mGLOB_use!
>> PT_use_mspp_call_convention -mP2OPT_subs_out_of_bound=FALSE -mP2OPT_disam_type_based_disam=2 -mGLOB_ansi_alias -mIPOPT_ninl_limit=0 -mIPOPT_ninl_user_level=0 -mPGOPTI_value_profile_use=T -mGLOB_opt_report_use_source_name -mP2OPT_gen_linux_const_pooling=FALSE -mP2OPT_il0_array_sections=TRUE -mGLOB_offload_mode=1 -mP2OPT_offload_unique_var_string=ifort0880525677IBUZzB -mGLOB_opt_level=0 -mIPOPT_args_in_regs=0 -mP2OPT_disam_assume_nonstd_intent_in=FALSE -mGLOB_imf_mapping_library=/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/bin/intel64/libiml_attr.so -mIPOPT_single_file_compile_and_link=TRUE -mP2OPT_hlo_embed_loopinfo -mPGOPTI_gen_threadsafe_level=0 -mIPOPT_lto_object_enabled -mIPOPT_lto_object_value=1 -mIPOPT_obj_output_file_name=/tmp/ifortuvU6OS.o -mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchqxls7i -mGLOB_linker_version=2.25.1 -mGLOB_driver_tempfile_name=/tmp/iforttempfilekQWtca -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS -mG!
>> LOB_async_unwind_tables=TRUE -mGLOB_obj_output_file=/tmp/ifortuvU6OS.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=conftest.f -mP1OPT_full_source_file_name=/nobackup/parallel-netcdf-1.8.1/conftest.f -mP2OPT_symtab_type_copy=true conftest.f
>> /usr/local/include
>> /usr/include/
>> /usr/include
>> End of search list.
>> ib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib /tmp/ifortuvU6OS.o -rpath /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib --enable-new-dtags -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -Bdynamic -Bstatic -lifport -lifcoremt -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -lirc -Bdynamic -lpthread -Bstatic -lsvml -Bdynamic -lc -lgcc -lgcc_s -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/x86_64-redhat-linux/4.8.5/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crtn.o
>> configure:7018: result: -v
>> configure:7020: checking for Fortran 77 libraries of /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> configure:7239: result:  -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/!
>> configure:7260: checking for Fortran flag needed to accept free-form source
>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> conftest.f(2): error #5149: Illegal character in statement label field  [p]
>> program freeform
>> conftest.f(2): error #5149: Illegal character in statement label field  [r]
>> program freeform
>> conftest.f(2): error #5149: Illegal character in statement label field  [o]
>> program freeform
>> conftest.f(2): error #5118: First statement in file must not be continued
>> program freeform
>> conftest.f(2): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>> program freeform
>> conftest.f(4): error #5082: Syntax error, found '&' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
>>      print *, 'Hello ', &
>> conftest.f(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
>>         'world.'
>> compilation aborted for conftest.f (code 1)
>> configure:7279: $? = 1
>> | |   program freeform
>> |        ! FIXME: how to best confuse non-freeform compilers?
>> |           'world.'
>> |        end
>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ffree-form  conftest.f >&5
>> ifort: command line warning #10006: ignoring unknown option '-ffree-form'
>> program freeform
>> program freeform
>> program freeform
>> program freeform
>> program freeform
>>         'world.'
>> | |   program freeform
>> |           'world.'
>> |        end
>> configure:7279: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -FR  conftest.f >&5
>> configure:7279: $? = 0
>> configure:7288: result: -FR
>> configure:7323: checking if MPIF77 is valid
>> configure:7332: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:7332: $? = 0
>> configure:7339: result: yes
>> configure:7399: checking for Fortran flag to compile preprocessed .f files
>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> conftest.f(3): warning #5117: Bad # preprocessor line
>> #if 0
>> conftest.f(4): warning #5117: Bad # preprocessor line
>> #include <ac_nonexistent.h>
>> conftest.f(6): warning #5117: Bad # preprocessor line
>> #endif
>> conftest.f(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
>>     choke me
>> configure:7427: $? = 1
>> |       program main
>> | | #if 0
>> |       choke me
>> | #endif
>> |       end
>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ftpp conftest.f >&5
>> ifort: command line warning #10006: ignoring unknown option '-ftpp'
>> #if 0
>> #endif
>>     choke me
>> |       program main
>> | | #if 0
>> |       choke me
>> | #endif
>> |       end
>> configure:7427: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f >&5
>> configure:7427: $? = 0
>> configure:7437: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f >&5
>> conftest.f(4): #error: can't find include file: ac_nonexistent.h
>> configure:7437: $? = 1
>> |       program main
>> | | #if 1
>> |       choke me
>> | #endif
>> |       end
>> configure:7451: result: -fpp
>> configure:7474: checking for Fortran flag to compile preprocessed .F files
>> configure:7502: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>> configure:7502: $? = 0
>> configure:7512: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>> conftest.F(4): #error: can't find include file: ac_nonexistent.h
>> configure:7512: $? = 1
>> |       program main
>> | | #if 1
>> |       choke me
>> | #endif
>> |       end
>> configure:7526: result: none
>> configure:7549: checking for Fortran flag to compile preprocessed .f90 files
>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f90 >&5
>> conftest.f90(3): warning #5117: Bad # preprocessor line
>> #if 0
>> conftest.f90(4): warning #5117: Bad # preprocessor line
>> conftest.f90(6): warning #5117: Bad # preprocessor line
>> #endif
>> conftest.f90(5): error #5082: Syntax error, found IDENTIFIER 'ME' when expecting one of: => = . [ % ( :
>>     choke me
>> compilation aborted for conftest.f90 (code 1)
>> configure:7577: $? = 1
>> |       program main
>> | | #if 0
>> |       choke me
>> | #endif
>> |       end
>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ftpp conftest.f90 >&5
>> #if 0
>> #endif
>>     choke me
>> |       program main
>> | | #if 0
>> |       choke me
>> | #endif
>> |       end
>> configure:7577: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f90 >&5
>> configure:7577: $? = 0
>> configure:7587: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fpp conftest.f90 >&5
>> conftest.f90(4): #error: can't find include file: ac_nonexistent.h
>> configure:7587: $? = 1
>> |       program main
>> | | #if 1
>> |       choke me
>> | #endif
>> |       end
>> configure:7601: result: -fpp
>> configure:7624: checking for Fortran flag to compile preprocessed .F90 files
>> configure:7652: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:7652: $? = 0
>> configure:7662: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> conftest.F90(4): #error: can't find include file: ac_nonexistent.h
>> configure:7662: $? = 1
>> |       program main
>> | | #if 1
>> |       choke me
>> | #endif
>> |       end
>> configure:7676: result: none
>> configure:7719: checking for Fortran flag to compile preprocessed .F files
>> configure:7771: result: configure:7791: checking how to define symbols for preprocessed Fortran
>> configure:7813: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -DFOOBAR -DZORK=42  conftest.F >&5
>> configure:7813: $? = 0
>> configure:7822: result: -D
>> configure:7849: checking for Fortran flag to compile .f files
>> configure:7869: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f >&5
>> configure:7869: $? = 0
>> configure:7878: result: none
>> configure:7903: checking for Fortran flag to compile .F files
>> configure:7923: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F >&5
>> configure:7923: $? = 0
>> configure:7932: result: none
>> configure:7957: checking for Fortran flag to compile .f90 files
>> configure:7977: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.f90 >&5
>> configure:7977: $? = 0
>> configure:7986: result: none
>> configure:8011: checking for Fortran flag to compile .F90 files
>> configure:8031: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:8031: $? = 0
>> configure:8040: result: none
>> configure:8076: checking for Fortran flag needed to accept fixed-form source
>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> conftest.F90(2): error #5082: Syntax error, found IDENTIFIER 'THIS' when expecting one of: => = . [ % ( :
>> C     This comment should confuse free-form compilers.
>> compilation aborted for conftest.F90 (code 1)
>> configure:8093: $? = 1
>> |       program main
>> |       end
>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -ffixed-form  conftest.F90 >&5
>> ifort: command line warning #10006: ignoring unknown option '-ffixed-form'
>> |       program main
>> |       end
>> configure:8093: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fixed  conftest.F90 >&5
>> configure:8093: $? = 0
>> configure:8102: result: -fixed
>> configure:8137: checking for dummy main to link with Fortran libraries
>> configure:8171: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/.!
>> ./lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl >&5
>> configure:8171: $? = 0
>> configure:8216: result: none
>> configure:8249: checking for Fortran name-mangling scheme
>> configure:8262: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:8262: $? = 0
>> configure:8303: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c cfortran_test.o   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../li!
>> b64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl >&5
>> /tmp/iccl8ejIz.o: In function `main':
>> /nobackup/parallel-netcdf-1.8.1/conftest.c:28: undefined reference to `foobar'
>> configure:8303: $? = 1
>> | /* confdefs.h */
>> | #define PACKAGE_NAME "parallel-netcdf"
>> | #define PACKAGE_TARNAME "parallel-netcdf"
>> | #define PACKAGE_VERSION "1.8.1"
>> | #define PACKAGE_STRING "parallel-netcdf 1.8.1"
>> | #define PACKAGE_BUGREPORT "parallel-netcdf at mcs.anl.gov"
>> | #define PACKAGE_URL ""
>> | /* end confdefs.h.  */
>> | | /* Override any GCC internal prototype to avoid an error.
>> |    Use char because int might match the return type of a GCC
>> |    builtin and then its argument prototype would still apply.  */
>> | #ifdef __cplusplus
>> | extern "C"
>> | #endif
>> | char foobar ();
>> | #ifdef FC_DUMMY_MAIN
>> | #ifndef FC_DUMMY_MAIN_EQ_F77
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> |    int FC_DUMMY_MAIN() { return 1; }
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | return foobar ();
>> |   return 0;
>> configure:8303: $? = 0
>> configure:8361: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c cfortran_test.o   -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../li!
>> configure:8361: $? = 0
>> configure:8403: result: lower case, underscore, no extra underscore
>> configure:8444: checking for C-equivalent to Fortran routine "SUB_A"
>> configure:8466: result: sub_a_
>> configure:8498: checking if Fortran compiler is NAG
>> configure:8513: result: no
>> configure:8524: checking Fortran compiler treating constant modifier
>> configure:8543: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:8543: $? = 0
>> configure:8582: result: 8
>> configure:8645: checking for a BSD-compatible install
>> configure:8713: result: /usr/bin/install -c
>> configure:8728: checking whether ln -s works
>> configure:8732: result: yes
>> configure:8739: checking whether make sets $(MAKE)
>> configure:8761: result: yes
>> configure:8771: checking for grep that handles long lines and -e
>> configure:8829: result: /usr/bin/grep
>> configure:8834: checking for egrep
>> configure:8896: result: /usr/bin/grep -E
>> configure:8910: checking for m4
>> configure:8926: found /usr/bin/m4
>> configure:8937: result: m4
>> configure:8993: checking m4 flags
>> configure:9005: result: "none"
>> configure:9021: checking for ar
>> configure:9037: found /usr/bin/ar
>> configure:9048: result: ar
>> configure:9104: checking ar flags
>> configure:9109: result: cru
>> configure:9119: checking for nm
>> configure:9135: found /usr/bin/nm
>> configure:9146: result: nm
>> configure:9202: checking nm flags
>> configure:9207: result: configure:9257: checking for ranlib
>> configure:9273: found /usr/bin/ranlib
>> configure:9284: result: ranlib
>> configure:9312: checking how to run the C preprocessor
>> configure:9343: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>> configure:9343: $? = 0
>> configure:9357: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>> conftest.c(10): error #2379: cannot open source file "ac_nonexistent.h"
>> configure:9357: $? = 2
>> | /* confdefs.h */
>> | #define F77_NAME_LOWER_USCORE /**/
>> configure:9382: result: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E
>> configure:9402: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>> configure:9402: $? = 0
>> configure:9416: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>> configure:9416: $? = 2
>> | /* confdefs.h */
>> configure:9445: checking for ANSI C header files
>> configure:9473: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9473: $? = 0
>> configure:9546: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9546: $? = 0
>> configure:9546: ./conftest
>> configure:9557: result: yes
>> configure:9570: checking for sys/types.h
>> configure:9570: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9570: $? = 0
>> configure:9570: result: yes
>> configure:9570: checking for sys/stat.h
>> configure:9570: checking for stdlib.h
>> configure:9570: checking for string.h
>> configure:9570: checking for memory.h
>> configure:9570: checking for strings.h
>> configure:9570: checking for inttypes.h
>> configure:9570: checking for stdint.h
>> configure:9570: checking for unistd.h
>> configure:9582: checking for stdbool.h that conforms to C99
>> configure:9657: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9657: $? = 0
>> configure:9664: result: yes
>> configure:9666: checking for _Bool
>> configure:9666: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9666: $? = 0
>> conftest.c(64): error: expected an expression
>> if (sizeof ((_Bool)))
>> compilation aborted for conftest.c (code 2)
>> configure:9666: $? = 2
>> | /* confdefs.h */
>> | #define STDC_HEADERS 1
>> | #define HAVE_SYS_TYPES_H 1
>> | #define HAVE_SYS_STAT_H 1
>> | #define HAVE_STDLIB_H 1
>> | #define HAVE_STRING_H 1
>> | #define HAVE_MEMORY_H 1
>> | #define HAVE_STRINGS_H 1
>> | #define HAVE_INTTYPES_H 1
>> | #define HAVE_STDINT_H 1
>> | #define HAVE_UNISTD_H 1
>> | #include <stdio.h>
>> | #ifdef HAVE_SYS_TYPES_H
>> | # include <sys/types.h>
>> | #endif
>> | #ifdef HAVE_SYS_STAT_H
>> | # include <sys/stat.h>
>> | #endif
>> | #ifdef STDC_HEADERS
>> | # include <stdlib.h>
>> | # include <stddef.h>
>> | #else
>> | # ifdef HAVE_STDLIB_H
>> | # endif
>> | #endif
>> | #ifdef HAVE_STRING_H
>> | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
>> | #  include <memory.h>
>> | # endif
>> | # include <string.h>
>> | #endif
>> | #ifdef HAVE_STRINGS_H
>> | # include <strings.h>
>> | #endif
>> | #ifdef HAVE_INTTYPES_H
>> | # include <inttypes.h>
>> | #endif
>> | #ifdef HAVE_STDINT_H
>> | # include <stdint.h>
>> | #endif
>> | #ifdef HAVE_UNISTD_H
>> | # include <unistd.h>
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:9666: result: yes
>> configure:9684: checking for inline
>> configure:9700: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9700: $? = 0
>> configure:9708: result: inline
>> configure:9729: checking for IEEE floating point format
>> configure:9767: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9767: $? = 0
>> configure:9767: ./conftest
>> configure:9776: result: yes
>> configure:9788: checking for strerror
>> configure:9788: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9788: $? = 0
>> configure:9788: result: yes
>> configure:9788: checking for access
>> configure:9788: checking for unlink
>> configure:9811: checking search.h usability
>> configure:9811: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9811: $? = 0
>> configure:9811: result: yes
>> configure:9811: checking search.h presence
>> configure:9811: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E  conftest.c
>> configure:9811: checking for search.h
>> configure:9824: checking for tsearch
>> configure:9824: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9824: $? = 0
>> configure:9824: result: yes
>> configure:9824: checking for tdelete
>> configure:9843: checking for MPI_Offset
>> configure:9843: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9843: $? = 0
>> conftest.c(42): error: expected an expression
>> if (sizeof ((MPI_Offset)))
>> configure:9843: $? = 2
>> | /* confdefs.h */
>> | #define HAVE__BOOL 1
>> | #define HAVE_STDBOOL_H 1
>> | #define HAVE_STRERROR 1
>> | #define HAVE_ACCESS 1
>> | #define HAVE_UNLINK 1
>> | #define HAVE_SEARCH_H 1
>> | #define HAVE_TSEARCH 1
>> | #define HAVE_TDELETE 1
>> | #define PNC_MALLOC_TRACE 1
>> | #include <mpi.h>
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:9843: result: yes
>> configure:9854: checking size of MPI_Offset
>> configure:9859: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9859: $? = 0
>> configure:9859: ./conftest
>> configure:9874: result: 8
>> configure:9891: checking size of MPI_Aint
>> configure:9896: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9896: $? = 0
>> configure:9896: ./conftest
>> configure:9911: result: 8
>> configure:9954: checking for MPI_Info_dup
>> configure:9954: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9954: $? = 0
>> configure:9954: result: yes
>> configure:9954: checking for MPI_Info_free
>> configure:9954: checking for MPI_Get_address
>> configure:9966: checking for MPI_Type_create_subarray
>> configure:9966: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:9966: $? = 0
>> configure:9966: result: yes
>> configure:9966: checking for MPI_Type_create_hvector
>> configure:9966: checking for MPI_Type_create_hindexed
>> configure:9966: checking for MPI_Type_create_struct
>> configure:9966: checking for MPI_Type_create_resized
>> configure:9966: checking for MPI_Type_get_extent
>> configure:9977: checking if MPI constant MPI_COMBINER_DUP is defined configure:9986: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:9986: $? = 0
>> configure:9987: result: yes
>> configure:10001: checking if MPI constant MPI_COMBINER_HVECTOR_INTEGER is defined configure:10010: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10010: $? = 0
>> configure:10011: result: yes
>> configure:10025: checking if MPI constant MPI_COMBINER_HINDEXED_INTEGER is defined configure:10034: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10034: $? = 0
>> configure:10035: result: yes
>> configure:10049: checking if MPI constant MPI_COMBINER_SUBARRAY is defined configure:10058: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10058: $? = 0
>> configure:10059: result: yes
>> configure:10073: checking if MPI constant MPI_COMBINER_DARRAY is defined configure:10082: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10082: $? = 0
>> configure:10083: result: yes
>> configure:10097: checking if MPI constant MPI_COMBINER_RESIZED is defined configure:10106: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10106: $? = 0
>> configure:10107: result: yes
>> configure:10121: checking if MPI constant MPI_COMBINER_STRUCT_INTEGER is defined configure:10130: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10130: $? = 0
>> configure:10131: result: yes
>> configure:10145: checking if MPI constant MPI_COMBINER_INDEXED_BLOCK is defined configure:10154: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10154: $? = 0
>> configure:10155: result: yes
>> configure:10169: checking if MPI constant MPI_COMBINER_F90_REAL is defined configure:10178: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10178: $? = 0
>> configure:10179: result: yes
>> configure:10193: checking if MPI constant MPI_COMBINER_F90_INTEGER is defined configure:10202: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10202: $? = 0
>> configure:10203: result: yes
>> configure:10217: checking if MPI constant MPI_COMBINER_F90_COMPLEX is defined configure:10226: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10226: $? = 0
>> configure:10227: result: yes
>> configure:10242: checking if MPI constant MPI_ERR_FILE_EXISTS is defined configure:10251: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10251: $? = 0
>> configure:10252: result: yes
>> configure:10266: checking if MPI constant MPI_ERR_NO_SUCH_FILE is defined configure:10275: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10275: $? = 0
>> configure:10276: result: yes
>> configure:10290: checking if MPI constant MPI_ERR_AMODE is defined configure:10299: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10299: $? = 0
>> configure:10300: result: yes
>> configure:10314: checking if MPI constant MPI_ERR_NOT_SAME is defined configure:10323: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10323: $? = 0
>> configure:10324: result: yes
>> configure:10338: checking if MPI constant MPI_ERR_BAD_FILE is defined configure:10347: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10347: $? = 0
>> configure:10348: result: yes
>> configure:10362: checking if MPI constant MPI_ERR_READ_ONLY is defined configure:10371: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10371: $? = 0
>> configure:10372: result: yes
>> configure:10386: checking if MPI constant MPI_ERR_ACCESS is defined configure:10395: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10395: $? = 0
>> configure:10396: result: yes
>> configure:10410: checking if MPI constant MPI_ERR_NO_SPACE is defined configure:10419: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10419: $? = 0
>> configure:10420: result: yes
>> configure:10434: checking if MPI constant MPI_ERR_QUOTA is defined configure:10443: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10443: $? = 0
>> configure:10444: result: yes
>> configure:10459: checking if MPI datatype MPI_CHAR is defined configure:10468: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10468: $? = 0
>> configure:10469: result: yes
>> configure:10483: checking if MPI datatype MPI_BYTE is defined configure:10492: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10492: $? = 0
>> configure:10493: result: yes
>> configure:10507: checking if MPI datatype MPI_SIGNED_CHAR is defined configure:10516: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10516: $? = 0
>> configure:10517: result: yes
>> configure:10531: checking if MPI datatype MPI_UNSIGNED_CHAR is defined configure:10540: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10540: $? = 0
>> configure:10541: result: yes
>> configure:10555: checking if MPI datatype MPI_SHORT is defined configure:10564: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10564: $? = 0
>> configure:10565: result: yes
>> configure:10579: checking if MPI datatype MPI_UNSIGNED_SHORT is defined configure:10588: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10588: $? = 0
>> configure:10589: result: yes
>> configure:10603: checking if MPI datatype MPI_INT is defined configure:10612: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10612: $? = 0
>> configure:10613: result: yes
>> configure:10627: checking if MPI datatype MPI_UNSIGNED is defined configure:10636: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10636: $? = 0
>> configure:10637: result: yes
>> configure:10651: checking if MPI datatype MPI_LONG is defined configure:10660: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10660: $? = 0
>> configure:10661: result: yes
>> configure:10675: checking if MPI datatype MPI_FLOAT is defined configure:10684: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10684: $? = 0
>> configure:10685: result: yes
>> configure:10699: checking if MPI datatype MPI_DOUBLE is defined configure:10708: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10708: $? = 0
>> configure:10709: result: yes
>> configure:10723: checking if MPI datatype MPI_LONG_LONG_INT is defined configure:10732: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10732: $? = 0
>> configure:10733: result: yes
>> configure:10747: checking if MPI datatype MPI_UNSIGNED_LONG_LONG is defined configure:10756: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10756: $? = 0
>> configure:10757: result: yes
>> configure:10771: checking if MPI datatype MPI_UB is defined configure:10780: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(77): warning #1786: variable "ompi_mpi_ub" (declared at line 926 of "/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include/mpi.h") was declared deprecated ("MPI_UB is deprecated in MPI-2.0")
>>           MPI_Datatype dummy = MPI_UB;
>> configure:10780: $? = 0
>> configure:10781: result: yes
>> configure:10795: checking if MPI datatype MPI_LB is defined configure:10804: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(78): warning #1786: variable "ompi_mpi_lb" (declared at line 925 of "/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/include/mpi.h") was declared deprecated ("MPI_LB is deprecated in MPI-2.0")
>>           MPI_Datatype dummy = MPI_LB;
>> configure:10804: $? = 0
>> configure:10805: result: yes
>> configure:10819: checking if MPI datatype MPI_OFFSET is defined configure:10828: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10828: $? = 0
>> configure:10829: result: yes
>> configure:10845: checking if MPI datatype MPI_CHARACTER is defined configure:10854: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10854: $? = 0
>> configure:10855: result: yes
>> configure:10869: checking if MPI datatype MPI_REAL is defined configure:10878: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10878: $? = 0
>> configure:10879: result: yes
>> configure:10893: checking if MPI datatype MPI_INTEGER is defined configure:10902: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10902: $? = 0
>> configure:10903: result: yes
>> configure:10917: checking if MPI datatype MPI_DOUBLE_PRECISION is defined configure:10926: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10926: $? = 0
>> configure:10927: result: yes
>> configure:10941: checking if MPI datatype MPI_INTEGER1 is defined configure:10950: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10950: $? = 0
>> configure:10951: result: yes
>> configure:10965: checking if MPI datatype MPI_INTEGER2 is defined configure:10974: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10974: $? = 0
>> configure:10975: result: yes
>> configure:10989: checking if MPI datatype MPI_INTEGER4 is defined configure:10998: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:10998: $? = 0
>> configure:10999: result: yes
>> configure:11013: checking if MPI datatype MPI_INTEGER8 is defined configure:11022: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11022: $? = 0
>> configure:11023: result: yes
>> configure:11037: checking if MPI datatype MPI_INTEGER16 is defined configure:11046: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(88): error: identifier "MPI_INTEGER16" is undefined
>>           MPI_Datatype dummy = MPI_INTEGER16;
>> configure:11046: $? = 2
>> | /* confdefs.h */
>> | #define SIZEOF_MPI_OFFSET 8
>> | #define SIZEOF_MPI_AINT 8
>> | #define ENABLE_CDF5 /**/
>> | #define ENABLE_REQ_AGGREGATION /**/
>> | #define HAVE_MPI_INFO_DUP 1
>> | #define HAVE_MPI_INFO_FREE 1
>> | #define HAVE_MPI_GET_ADDRESS 1
>> | #define HAVE_MPI_TYPE_CREATE_SUBARRAY 1
>> | #define HAVE_MPI_TYPE_CREATE_HVECTOR 1
>> | #define HAVE_MPI_TYPE_CREATE_HINDEXED 1
>> | #define HAVE_MPI_TYPE_CREATE_STRUCT 1
>> | #define HAVE_MPI_TYPE_CREATE_RESIZED 1
>> | #define HAVE_MPI_TYPE_GET_EXTENT 1
>> | #define HAVE_MPI_COMBINER_DUP 1
>> | #define HAVE_MPI_COMBINER_HVECTOR_INTEGER 1
>> | #define HAVE_MPI_COMBINER_HINDEXED_INTEGER 1
>> | #define HAVE_MPI_COMBINER_SUBARRAY 1
>> | #define HAVE_MPI_COMBINER_DARRAY 1
>> | #define HAVE_MPI_COMBINER_RESIZED 1
>> | #define HAVE_MPI_COMBINER_STRUCT_INTEGER 1
>> | #define HAVE_MPI_COMBINER_INDEXED_BLOCK 1
>> | #define HAVE_MPI_COMBINER_F90_REAL 1
>> | #define HAVE_MPI_COMBINER_F90_INTEGER 1
>> | #define HAVE_MPI_COMBINER_F90_COMPLEX 1
>> | #define HAVE_MPI_ERR_FILE_EXISTS 1
>> | #define HAVE_MPI_ERR_NO_SUCH_FILE 1
>> | #define HAVE_MPI_ERR_AMODE 1
>> | #define HAVE_MPI_ERR_NOT_SAME 1
>> | #define HAVE_MPI_ERR_BAD_FILE 1
>> | #define HAVE_MPI_ERR_READ_ONLY 1
>> | #define HAVE_MPI_ERR_ACCESS 1
>> | #define HAVE_MPI_ERR_NO_SPACE 1
>> | #define HAVE_MPI_ERR_QUOTA 1
>> | #define HAVE_MPI_CHAR 1
>> | #define HAVE_MPI_BYTE 1
>> | #define HAVE_MPI_SIGNED_CHAR 1
>> | #define HAVE_MPI_UNSIGNED_CHAR 1
>> | #define HAVE_MPI_SHORT 1
>> | #define HAVE_MPI_UNSIGNED_SHORT 1
>> | #define HAVE_MPI_INT 1
>> | #define HAVE_MPI_UNSIGNED 1
>> | #define HAVE_MPI_LONG 1
>> | #define HAVE_MPI_FLOAT 1
>> | #define HAVE_MPI_DOUBLE 1
>> | #define HAVE_MPI_LONG_LONG_INT 1
>> | #define HAVE_MPI_UNSIGNED_LONG_LONG 1
>> | #define HAVE_MPI_UB 1
>> | #define HAVE_MPI_LB 1
>> | #define HAVE_MPI_OFFSET_DATATYPE 1
>> | #define HAVE_MPI_CHARACTER 1
>> | #define HAVE_MPI_REAL 1
>> | #define HAVE_MPI_INTEGER 1
>> | #define HAVE_MPI_DOUBLE_PRECISION 1
>> | #define HAVE_MPI_INTEGER1 1
>> | #define HAVE_MPI_INTEGER2 1
>> | #define HAVE_MPI_INTEGER4 1
>> | #define HAVE_MPI_INTEGER8 1
>> | |           #include <mpi.h>
>> | configure:11054: result: no
>> configure:11061: checking if MPI datatype MPI_REAL4 is defined configure:11070: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11070: $? = 0
>> configure:11071: result: yes
>> configure:11085: checking if MPI datatype MPI_REAL8 is defined configure:11094: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11094: $? = 0
>> configure:11095: result: yes
>> configure:11109: checking if MPI datatype MPI_REAL16 is defined configure:11118: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11118: $? = 0
>> configure:11119: result: yes
>> configure:11133: checking if MPI datatype MPI_COMPLEX8 is defined configure:11142: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11142: $? = 0
>> configure:11143: result: yes
>> configure:11157: checking if MPI datatype MPI_COMPLEX16 is defined configure:11166: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11166: $? = 0
>> configure:11167: result: yes
>> configure:11181: checking if MPI datatype MPI_COMPLEX32 is defined configure:11190: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11190: $? = 0
>> configure:11191: result: yes
>> configure:11221: checking whether char is unsigned
>> configure:11248: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11248: $? = 0
>> configure:11255: result: no
>> configure:11262: checking whether byte ordering is bigendian
>> configure:11277: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(93): error: identifier "not" is undefined
>> 	       not a universal capable compiler
>> conftest.c(93): error: expected a ";"
>> configure:11277: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_MPI_REAL4 1
>> | #define HAVE_MPI_REAL8 1
>> | #define HAVE_MPI_REAL16 1
>> | #define HAVE_MPI_COMPLEX8 1
>> | #define HAVE_MPI_COMPLEX16 1
>> | #define HAVE_MPI_COMPLEX32 1
>> | #ifndef __APPLE_CC__
>> | 	     #endif
>> | 	     typedef int dummy;
>> | configure:11330: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11330: $? = 0
>> configure:11356: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(107): error: identifier "not" is undefined
>> 		 not big endian
>> conftest.c(107): error: expected a ";"
>> 		 not big endian
>> conftest.c(110): warning #12: parsing restarts here after previous syntax error
>> configure:11356: $? = 2
>> | /* confdefs.h */
>> | #include <sys/types.h>
>> | 		#include <sys/param.h>
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | #if BYTE_ORDER != BIG_ENDIAN
>> | 		 not big endian
>> | 		#endif
>> |   return 0;
>> configure:11516: result: no
>> configure:11547: checking for size_t
>> configure:11547: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11547: $? = 0
>> conftest.c(136): error: expected an expression
>> if (sizeof ((size_t)))
>> configure:11547: $? = 2
>> | /* confdefs.h */
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11547: result: yes
>> configure:11558: checking for off_t
>> configure:11558: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11558: $? = 0
>> if (sizeof ((off_t)))
>> configure:11558: $? = 2
>> configure: failed program was:
>> | /* confdefs.h */
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11558: result: yes
>> configure:11569: checking for ssize_t
>> configure:11569: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11569: $? = 0
>> if (sizeof ((ssize_t)))
>> configure:11569: $? = 2
>> | /* confdefs.h */
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11569: result: yes
>> configure:11578: checking for ptrdiff_t
>> configure:11578: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11578: $? = 0
>> conftest.c(137): error: expected an expression
>> if (sizeof ((ptrdiff_t)))
>> configure:11578: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_SSIZE_T 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11578: result: yes
>> configure:11587: checking for uchar
>> configure:11587: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(138): error: identifier "uchar" is undefined
>> if (sizeof (uchar))
>> configure:11587: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_PTRDIFF_T 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | if (sizeof (uchar))
>> | 	 return 0;
>> |   return 0;
>> configure:11587: result: no
>> configure:11596: checking for ushort
>> configure:11596: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11596: $? = 0
>> conftest.c(138): error: expected an expression
>> if (sizeof ((ushort)))
>> configure:11596: $? = 2
>> | /* confdefs.h */
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11596: result: yes
>> configure:11605: checking for uint
>> configure:11605: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> configure:11605: $? = 0
>> conftest.c(139): error: expected an expression
>> if (sizeof ((uint)))
>> configure:11605: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_USHORT 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	    return 0;
>> |   return 0;
>> configure:11605: result: yes
>> configure:11614: checking for longlong
>> configure:11614: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(140): error: identifier "longlong" is undefined
>> if (sizeof (longlong))
>> configure:11614: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_UINT 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	 return 0;
>> |   return 0;
>> configure:11614: result: no
>> configure:11623: checking for ulonglong
>> configure:11623: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(140): error: identifier "ulonglong" is undefined
>> if (sizeof (ulonglong))
>> configure:11623: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_UINT 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	 return 0;
>> |   return 0;
>> configure:11623: result: no
>> configure:11632: checking for int64
>> configure:11632: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(140): error: identifier "int64" is undefined
>> if (sizeof (int64))
>> configure:11632: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_UINT 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | if (sizeof (int64))
>> | 	 return 0;
>> |   return 0;
>> configure:11632: result: no
>> configure:11641: checking for uint64
>> configure:11641: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c -g -O2  conftest.c >&5
>> conftest.c(140): error: identifier "uint64" is undefined
>> if (sizeof (uint64))
>> configure:11641: $? = 2
>> | /* confdefs.h */
>> | #define HAVE_UINT 1
>> | #include <stdio.h>
>> | #endif
>> | #endif
>> | #ifdef STDC_HEADERS
>> | #else
>> | # endif
>> | #endif
>> | # endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #endif
>> | #  ifdef __cplusplus
>> |      extern "C"
>> | #  endif
>> | #endif
>> | #endif
>> | int
>> | main ()
>> | 	 return 0;
>> |   return 0;
>> configure:11641: result: no
>> configure:11656: checking size of size_t
>> configure:11661: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11661: $? = 0
>> configure:11661: ./conftest
>> configure:11675: result: 8
>> configure:11689: checking size of off_t
>> configure:11694: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11694: $? = 0
>> configure:11694: ./conftest
>> configure:11708: result: 8
>> configure:11722: checking size of signed char
>> configure:11727: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11727: $? = 0
>> configure:11727: ./conftest
>> configure:11741: result: 1
>> configure:11755: checking size of unsigned char
>> configure:11760: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11760: $? = 0
>> configure:11760: ./conftest
>> configure:11774: result: 1
>> configure:11788: checking size of short
>> configure:11793: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11793: $? = 0
>> configure:11793: ./conftest
>> configure:11807: result: 2
>> configure:11821: checking size of unsigned short int
>> configure:11826: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11826: $? = 0
>> configure:11826: ./conftest
>> configure:11840: result: 2
>> configure:11854: checking size of unsigned short
>> configure:11859: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11859: $? = 0
>> configure:11859: ./conftest
>> configure:11873: result: 2
>> configure:11887: checking size of int
>> configure:11892: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11892: $? = 0
>> configure:11892: ./conftest
>> configure:11906: result: 4
>> configure:11920: checking size of unsigned int
>> configure:11925: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11925: $? = 0
>> configure:11925: ./conftest
>> configure:11939: result: 4
>> configure:11953: checking size of long
>> configure:11958: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11958: $? = 0
>> configure:11958: ./conftest
>> configure:11972: result: 8
>> configure:11986: checking size of float
>> configure:11991: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:11991: $? = 0
>> configure:11991: ./conftest
>> configure:12005: result: 4
>> configure:12019: checking size of double
>> configure:12024: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:12024: $? = 0
>> configure:12024: ./conftest
>> configure:12038: result: 8
>> configure:12052: checking size of long long
>> configure:12057: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:12057: $? = 0
>> configure:12057: ./conftest
>> configure:12071: result: 8
>> configure:12085: checking size of unsigned long long
>> configure:12090: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:12090: $? = 0
>> configure:12090: ./conftest
>> configure:12104: result: 8
>> configure:12120: checking size of ushort
>> configure:12125: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:12125: $? = 0
>> configure:12125: ./conftest
>> configure:12139: result: 2
>> configure:12155: checking size of uint
>> configure:12160: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -o conftest -g -O2   conftest.c  >&5
>> configure:12160: $? = 0
>> configure:12160: ./conftest
>> configure:12174: result: 4
>> configure:12383: checking for C-equivalent to Fortran routine "SUB"
>> configure:12404: result: sub_
>> configure:12422: checking for Fortran "integer*1"
>> configure:12431: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:12431: $? = 0
>> configure:12432: result: yes
>> configure:12461: checking for Fortran "integer*2"
>> configure:12470: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:12470: $? = 0
>> configure:12471: result: yes
>> configure:12500: checking for Fortran "integer*8"
>> configure:12509: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:12509: $? = 0
>> configure:12510: result: yes
>> configure:12544: checking if Fortran "integer*1" is configure:12554: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12557: $? = 0
>> configure:12560: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12563: $? = 0
>> configure:12566: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12569: $? = 0
>> configure:12572: ./conftest
>> configure:12575: $? = 0
>> configure:12577: result: "signed char" in C
>> configure:12619: checking if Fortran "integer*2" is configure:12629: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12632: $? = 0
>> configure:12635: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12638: $? = 0
>> configure:12641: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12644: $? = 0
>> configure:12647: ./conftest
>> configure:12650: $? = 0
>> configure:12652: result: "short" in C
>> configure:12694: checking if Fortran "integer*8" is configure:12704: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12707: $? = 0
>> configure:12710: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12713: $? = 0
>> configure:12716: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12719: $? = 0
>> configure:12722: ./conftest
>> configure:12725: $? = 0
>> configure:12727: result: "int" in C
>> configure:12767: checking if Fortran "integer" is configure:12777: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12780: $? = 0
>> configure:12783: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12786: $? = 0
>> configure:12789: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12792: $? = 0
>> configure:12795: ./conftest
>> configure:12798: $? = 0
>> configure:12800: result: "int" in C
>> configure:12838: checking if Fortran "real" is configure:12848: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12851: $? = 0
>> configure:12854: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12857: $? = 0
>> configure:12860: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12863: $? = 0
>> configure:12866: ./conftest
>> configure:12869: $? = 0
>> configure:12871: result: "float" in C
>> configure:12909: checking if Fortran "doubleprecision" is configure:12919: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -c  -g -O2 conftest.c
>> configure:12922: $? = 0
>> configure:12925: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -g -c conftestf.f
>> configure:12928: $? = 0
>> configure:12931: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -o conftest -g  conftestf.o conftest.o configure:12934: $? = 0
>> configure:12937: ./conftest
>> configure:12940: $? = 0
>> configure:12942: result: "double" in C
>> configure:12973: checking for Fortran-equivalent to netCDF "byte"
>> configure:12988: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:12988: $? = 0
>> configure:13004: result: byte
>> configure:13010: checking for Fortran-equivalent to netCDF "short"
>> configure:13025: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:13025: $? = 0
>> configure:13041: result: integer*2
>> configure:13054: checking for Fortran NFMPI_OFFSET "integer*8"
>> configure:13068: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:13068: $? = 0
>> configure:13082: result: yes
>> configure:13097: checking Fortran 90 module extension
>> configure:13119: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:13119: $? = 0
>> configure:13136: result: mod
>> configure:13154: checking Fortran 90 module inclusion flag
>> configure:13176: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:13176: $? = 0
>> configure:13190: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Iconftest.dir -Iconftest.dir  conftest.F90 >&5
>> configure:13190: $? = 0
>> configure:13211: result: -I
>> configure:13233: checking Fortran 90 module output flag
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Jsub  conftest.F90 >&5
>> ifort: command line warning #10006: ignoring unknown option '-Jsub'
>> configure:13261: $? = 0
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -Jsub  conftest.F90 >&5
>> conftest.F90(3): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [CONFTEST_MODULE]
>>     use conftest_module
>> configure:13270: $? = 1
>> | |       program main
>> |       use conftest_module
>> |       call conftest_routine
>> |       end
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -J sub  conftest.F90 >&5
>> ifort: command line warning #10006: ignoring unknown option '-J'
>> ifort: warning #10145: no action performed for file 'sub'
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -J sub  conftest.F90 >&5
>> ifort: error #10236: File not found:  'sub'
>>     use conftest_module
>> | |       program main
>> |       use conftest_module
>> |       end
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fmod=sub  conftest.F90 >&5
>> ifort: command line warning #10006: ignoring unknown option '-fmod=sub'
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -fmod=sub  conftest.F90 >&5
>>     use conftest_module
>> | |       program main
>> |       use conftest_module
>> |       end
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -moddir=sub  conftest.F90 >&5
>> ifort: command line warning #10159: invalid argument for option '-m'
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -moddir=sub  conftest.F90 >&5
>>     use conftest_module
>> | |       program main
>> |       use conftest_module
>> |       end
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g +moddir=sub  conftest.F90 >&5
>> ifort: error #10236: File not found:  '+moddir=sub'
>> configure:13261: $? = 1
>> | |       module conftest_module
>> |       contains
>> |       subroutine conftest_routine
>> |       write(*,'(a)') 'gotcha!'
>> |       end subroutine
>> |       end module
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -qmoddir=sub  conftest.F90 >&5
>> ifort: command line warning #10006: ignoring unknown option '-qmoddir=sub'
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -qmoddir=sub  conftest.F90 >&5
>>     use conftest_module
>> | |       program main
>> |       use conftest_module
>> |       end
>> configure:13261: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -mod sub  conftest.F90 >&5
>> configure:13270: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g -mod sub  conftest.F90 >&5
>> configure:13270: $? = 0
>> configure:13292: result: -mod configure:13320: checking for Fortran 77 GNU intrinsic INT
>> configure:13344: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:13344: $? = 0
>> configure:13357: result: yes
>> configure:13370: checking for Fortran 77 intrinsic INT1
>> configure:13388: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:13388: $? = 0
>> configure:13401: result: yes
>> configure:13413: checking for Fortran 77 intrinsic INT2
>> configure:13431: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:13431: $? = 0
>> configure:13444: result: yes
>> configure:13456: checking for Fortran 77 intrinsic INT8
>> configure:13474: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g conftest.f >&5
>> configure:13474: $? = 0
>> configure:13487: result: yes
>> configure:13508: checking if Fortran 90 compiler capitalizes .mod filenames
>> configure:13517: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90 -c -g  conftest.F90 >&5
>> configure:13517: $? = 0
>> configure:13527: result: no
>> configure:13647: checking for manual-page index command
>> configure:13649: result: configure:13685: checking if C++ macro __func__ or __FUNCTION__ is defined
>> configure:13717: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>> configure:13717: $? = 0
>> configure:13740: /apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx -c -g -O2  conftest.cpp >&5
>> configure:13740: $? = 0
>> configure:13752: result: yes
>> configure:13854: checking for latex
>> configure:13872: found /usr/bin/latex
>> configure:13884: result: /usr/bin/latex
>> configure:13894: checking for dvipdf
>> configure:13912: found /usr/bin/dvipdf
>> configure:13924: result: /usr/bin/dvipdf
>> configure:13986: checking for gcc
>> configure:14004: found /usr/bin/gcc
>> configure:14017: result: /usr/bin/gcc
>> configure:14170: creating ./config.status
>> ## Running config.status. ##
>> This file was extended by parallel-netcdf config.status 1.8.1, which was
>> generated by GNU Autoconf 2.69.  Invocation command line was
>> CONFIG_FILES    =
>> CONFIG_HEADERS  =
>> CONFIG_LINKS    =
>> CONFIG_COMMANDS =
>> $ ./config.status
>> on login2.arc3.leeds.ac.uk
>> config.status:1111: creating macros.make
>> config.status:1111: creating Makefile
>> config.status:1111: creating pnetcdf_pc
>> config.status:1111: creating src/Makefile
>> config.status:1111: creating src/lib/Makefile
>> config.status:1111: creating src/lib/pnetcdf.h
>> config.status:1111: creating src/utils/Makefile
>> config.status:1111: creating src/utils/ncmpidump/Makefile
>> config.status:1111: creating src/utils/ncmpidiff/Makefile
>> config.status:1111: creating src/utils/ncmpigen/Makefile
>> config.status:1111: creating src/utils/ncmpivalid/Makefile
>> config.status:1111: creating src/utils/pnetcdf_version/Makefile
>> config.status:1111: creating src/utils/ncoffsets/Makefile
>> config.status:1111: creating test/Makefile
>> config.status:1111: creating test/common/Makefile
>> config.status:1111: creating test/nc_test/Makefile
>> config.status:1111: creating test/C/Makefile
>> config.status:1111: creating test/fandc/Makefile
>> config.status:1111: creating test/testcases/Makefile
>> config.status:1111: creating test/nonblocking/Makefile
>> config.status:1111: creating test/header/Makefile
>> config.status:1111: creating test/cdf_format/Makefile
>> config.status:1111: creating test/largefile/Makefile
>> config.status:1111: creating examples/C/Makefile
>> config.status:1111: creating examples/tutorial/Makefile
>> config.status:1111: creating examples/Makefile
>> config.status:1111: creating doc/Makefile
>> config.status:1111: creating man/Makefile
>> config.status:1111: creating scripts/Makefile
>> config.status:1111: creating benchmarks/Makefile
>> config.status:1111: creating benchmarks/C/Makefile
>> config.status:1111: creating test/nf_test/Makefile
>> config.status:1111: creating test/nf_test/tests.inc
>> config.status:1111: creating test/nf90_test/Makefile
>> config.status:1111: creating test/F90/Makefile
>> config.status:1111: creating examples/F77/Makefile
>> config.status:1111: creating examples/F90/Makefile
>> config.status:1111: creating src/libf90/Makefile
>> config.status:1111: creating src/libf90/pnetcdf.f90
>> config.status:1111: creating src/libf90/api.f90
>> config.status:1111: creating src/libf90/nfmpi_constants.f90
>> config.status:1111: creating src/libf/Makefile
>> config.status:1111: creating src/libf/pnetcdf.inc
>> config.status:1111: creating src/libcxx/Makefile
>> config.status:1111: creating examples/CXX/Makefile
>> config.status:1111: creating test/CXX/Makefile
>> config.status:1111: creating benchmarks/FLASH-IO/Makefile
>> config.status:1111: creating test/subfile/Makefile
>> config.status:1111: creating stamp-h
>> config.status:1111: creating pnetcdf-config
>> config.status:1111: creating check_install
>> config.status:1111: creating src/lib/ncconfig.h
>> config.status:1111: creating src/libf/nfconfig_inc
>> ## Cache variables. ##
>> ac_cv_CHECK_MPI_CPP_SEEK_SET=no
>> ac_cv_NFMPI_OFFSET=yes
>> ac_cv_build=x86_64-unknown-linux-gnu
>> ac_cv_c_bigendian=no
>> ac_cv_c_char_unsigned=no
>> ac_cv_c_compiler_gnu=yes
>> ac_cv_c_ieeefloat=yes
>> ac_cv_c_inline=inline
>> ac_cv_cxx_compiler_gnu=yes
>> ac_cv_cxx_macro_func=yes
>> ac_cv_cxx_macro_function=yes
>> ac_cv_env_CCC_set=
>> ac_cv_env_CCC_value=
>> ac_cv_env_CC_set=set
>> ac_cv_env_CC_value=icc
>> ac_cv_env_CFLAGS_set=
>> ac_cv_env_CFLAGS_value=
>> ac_cv_env_CPPFLAGS_set=
>> ac_cv_env_CPPFLAGS_value=
>> ac_cv_env_CPP_set=
>> ac_cv_env_CPP_value=
>> ac_cv_env_CXXFLAGS_set=
>> ac_cv_env_CXXFLAGS_value=
>> ac_cv_env_CXX_set=set
>> ac_cv_env_CXX_value=icpc
>> ac_cv_env_F77_set=set
>> ac_cv_env_F77_value=ifort
>> ac_cv_env_FCFLAGS_set=
>> ac_cv_env_FCFLAGS_value=
>> ac_cv_env_FC_set=set
>> ac_cv_env_FC_value=ifort
>> ac_cv_env_FFLAGS_set=
>> ac_cv_env_FFLAGS_value=
>> ac_cv_env_FPPFLAGS_set=
>> ac_cv_env_FPPFLAGS_value=
>> ac_cv_env_LDFLAGS_set=
>> ac_cv_env_LDFLAGS_value=
>> ac_cv_env_LIBS_set=
>> ac_cv_env_LIBS_value=
>> ac_cv_env_MPICC_set=set
>> ac_cv_env_MPICC_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>> ac_cv_env_MPICXX_set=set
>> ac_cv_env_MPICXX_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx
>> ac_cv_env_MPIF77_set=set
>> ac_cv_env_MPIF77_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> ac_cv_env_MPIF90_set=set
>> ac_cv_env_MPIF90_value=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90
>> ac_cv_env_RM_set=
>> ac_cv_env_RM_value=
>> ac_cv_env_TEST_MPIRUN_set=
>> ac_cv_env_TEST_MPIRUN_value=
>> ac_cv_env_TEST_OUTDIR_set=
>> ac_cv_env_TEST_OUTDIR_value=
>> ac_cv_env_TEST_SEQRUN_set=
>> ac_cv_env_TEST_SEQRUN_value=
>> ac_cv_env_build_alias_set=
>> ac_cv_env_build_alias_value=
>> ac_cv_env_host_alias_set=
>> ac_cv_env_host_alias_value=
>> ac_cv_env_target_alias_set=
>> ac_cv_env_target_alias_value=
>> ac_cv_f77_compiler_gnu=no
>> ac_cv_f77_gnu_int=yes
>> ac_cv_f77_int1=yes
>> ac_cv_f77_int2=yes
>> ac_cv_f77_int8=yes
>> ac_cv_f77_libs=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compiler!
>> s/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin/ -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl'
>> ac_cv_fc_compiler_gnu=no
>> ac_cv_fc_compiler_nag=no
>> ac_cv_fc_constant_modifier=8
>> ac_cv_fc_dummy_main=none
>> ac_cv_fc_fixedform=-fixed
>> ac_cv_fc_freeform=-FR
>> ac_cv_fc_libs=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers!
>> ac_cv_fc_mangling='lower case, underscore, no extra underscore'
>> ac_cv_fc_module_ext=mod
>> ac_cv_fc_module_flag=-I
>> ac_cv_fc_module_output_flag='-mod '
>> ac_cv_fc_pp_define=-D
>> ac_cv_fc_pp_srcext_F90=
>> ac_cv_fc_pp_srcext_F=
>> ac_cv_fc_pp_srcext_f90=-fpp
>> ac_cv_fc_pp_srcext_f=-fpp
>> ac_cv_fc_srcext_F90=none
>> ac_cv_fc_srcext_F=none
>> ac_cv_fc_srcext_f90=none
>> ac_cv_fc_srcext_f=none
>> ac_cv_fortran_dummy_main=none
>> ac_cv_func_MPI_Comm_rank=yes
>> ac_cv_func_MPI_File_close=yes
>> ac_cv_func_MPI_File_open=yes
>> ac_cv_func_MPI_Get_address=yes
>> ac_cv_func_MPI_Info_dup=yes
>> ac_cv_func_MPI_Info_free=yes
>> ac_cv_func_MPI_Type_create_hindexed=yes
>> ac_cv_func_MPI_Type_create_hvector=yes
>> ac_cv_func_MPI_Type_create_resized=yes
>> ac_cv_func_MPI_Type_create_struct=yes
>> ac_cv_func_MPI_Type_create_subarray=yes
>> ac_cv_func_MPI_Type_get_extent=yes
>> ac_cv_func_access=yes
>> ac_cv_func_strerror=yes
>> ac_cv_func_tdelete=yes
>> ac_cv_func_tsearch=yes
>> ac_cv_func_unlink=yes
>> ac_cv_header_inttypes_h=yes
>> ac_cv_header_memory_h=yes
>> ac_cv_header_search_h=yes
>> ac_cv_header_stdbool_h=yes
>> ac_cv_header_stdc=yes
>> ac_cv_header_stdint_h=yes
>> ac_cv_header_stdlib_h=yes
>> ac_cv_header_string_h=yes
>> ac_cv_header_strings_h=yes
>> ac_cv_header_sys_stat_h=yes
>> ac_cv_header_sys_types_h=yes
>> ac_cv_header_unistd_h=yes
>> ac_cv_host=x86_64-unknown-linux-gnu
>> ac_cv_m4_stdout=
>> ac_cv_objext=o
>> ac_cv_path_DVIPDF=/usr/bin/dvipdf
>> ac_cv_path_EGREP='/usr/bin/grep -E'
>> ac_cv_path_GREP=/usr/bin/grep
>> ac_cv_path_LATEX=/usr/bin/latex
>> ac_cv_path_SEQ_CC=/usr/bin/gcc
>> ac_cv_path_install='/usr/bin/install -c'
>> ac_cv_prog_AR=ar
>> ac_cv_prog_CPP='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc -E'
>> ac_cv_prog_M4=m4
>> ac_cv_prog_NM=nm
>> ac_cv_prog_ac_ct_CC=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc
>> ac_cv_prog_ac_ct_RANLIB=ranlib
>> ac_cv_prog_cc_c89=
>> ac_cv_prog_cc_g=yes
>> ac_cv_prog_cxx_g=yes
>> ac_cv_prog_f77_g=yes
>> ac_cv_prog_f77_v=-v
>> ac_cv_prog_f90_uppercase_mod=no
>> ac_cv_prog_fc_g=yes
>> ac_cv_prog_fc_v=-v
>> ac_cv_prog_make_make_set=yes
>> ac_cv_sizeof_MPI_Aint=8
>> ac_cv_sizeof_MPI_Offset=8
>> ac_cv_sizeof_double=8
>> ac_cv_sizeof_float=4
>> ac_cv_sizeof_int=4
>> ac_cv_sizeof_long=8
>> ac_cv_sizeof_long_long=8
>> ac_cv_sizeof_off_t=8
>> ac_cv_sizeof_short=2
>> ac_cv_sizeof_signed_char=1
>> ac_cv_sizeof_size_t=8
>> ac_cv_sizeof_uint=4
>> ac_cv_sizeof_unsigned_char=1
>> ac_cv_sizeof_unsigned_int=4
>> ac_cv_sizeof_unsigned_long_long=8
>> ac_cv_sizeof_unsigned_short=2
>> ac_cv_sizeof_unsigned_short_int=2
>> ac_cv_sizeof_ushort=2
>> ac_cv_sys_file_offset_bits=no
>> ac_cv_sys_largefile_CC=no
>> ac_cv_type_MPI_Offset=yes
>> ac_cv_type__Bool=yes
>> ac_cv_type_int64=no
>> ac_cv_type_longlong=no
>> ac_cv_type_off_t=yes
>> ac_cv_type_ptrdiff_t=yes
>> ac_cv_type_size_t=yes
>> ac_cv_type_ssize_t=yes
>> ac_cv_type_uchar=no
>> ac_cv_type_uint64=no
>> ac_cv_type_uint=yes
>> ac_cv_type_ulonglong=no
>> ac_cv_type_ushort=yes
>> ## Output variables. ##
>> AR='ar'
>> ARFLAGS='cru'
>> BUILDDIR='/nobackup/parallel-netcdf-1.8.1'
>> CC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>> CC_MAKEDEPEND='false'
>> CFLAGS='-g  -O0'
>> CONFIGURE_ARGS_CLEAN='--prefix=/nobackup/issmcd/n/build --with-mpi=/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1 --enable-debug'
>> CONFIG_DATE='Thu Feb  2 16:22:34 GMT 2017'
>> CPPFLAGS=''
>> CXX='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx'
>> CXXCPPFLAGS=''
>> CXXFLAGS='-g  -O0'
>> DEFS='-DHAVE_CONFIG_H'
>> DVIPDF='/usr/bin/dvipdf'
>> ECHO_C=''
>> ECHO_N='-n'
>> ECHO_T=''
>> ENABLE_ERANGE_FILL='1'
>> ENABLE_SUBFILING='0'
>> EXEEXT=''
>> F77='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>> F77FLAGS='-g -O0'
>> F77FLAGS_F=''
>> F77FLAGS_f=''
>> F77PPFLAGS_F=''
>> F77PPFLAGS_f='-fpp'
>> F77_SUPPORT_FREEFORM='yes'
>> F90FLAGS='-g -O0'
>> F90FLAGS_F90=''
>> F90FLAGS_f90=''
>> F90LDFLAGS=''
>> F90LIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel!
>> F90PPFLAGS_F90=''
>> F90PPFLAGS_f90='-fpp'
>> FC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>> FCFLAGS='-g  -O0'
>> FCFLAGS_F90=''
>> FCFLAGS_F=''
>> FCFLAGS_f90=''
>> FCFLAGS_f=''
>> FCLIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/!
>> FC_DEFINE='-D'
>> FC_MODEXT='mod'
>> FC_MODINC='-I'
>> FC_MODOUT='-mod ${ac_empty}'
>> FFIXEDFORMFLAG='-fixed'
>> FFLAGS='-g'
>> FFREEFORMFLAG='-FR'
>> FLDFLAGS=''
>> FLIBS=' -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/ipp/lib/intel64 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/tbb/lib/intel64/gcc4.7 -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/lib/intel64_lin -L/apps/developers/compilers/intel/17.0.1/1/default/compilers_and_libraries_2017.1.132/linux/daal/../tbb/lib/intel64_lin/gcc4.4 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/ -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/lib/ -L/apps/developers/compilers/intel/1!
>> FPP=''
>> FPPFLAGS=''
>> GREP='/usr/bin/grep'
>> HAVE_F77_GNU_INT='yes'
>> HAVE_F77_INT1='yes'
>> HAVE_F77_INT2='yes'
>> HAVE_F77_INT8='yes'
>> INSTALL_DATA='${INSTALL} -m 644'
>> INSTALL_PROGRAM='${INSTALL}'
>> INSTALL_SCRIPT='${INSTALL}'
>> INTENTV='INOUT'
>> LATEX='/usr/bin/latex'
>> LCOV_LIB=''
>> LDFLAGS=''
>> LIBOBJS=''
>> LIBS=''
>> LN_S='ln -s'
>> LTLIBOBJS=''
>> M4='m4'
>> M4FFLAGS=''
>> M4FLAGS=''
>> MAKEWHATIS_CMD=''
>> MPICC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>> MPICXX='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicxx'
>> MPIF77='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>> MPIF90='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpif90'
>> NAG_FCFLAGS=''
>> NAGf90FPPFLAGS=''
>> NM='nm'
>> NMFLAGS=''
>> OBJEXT='o'
>> PACKAGE_BUGREPORT='parallel-netcdf at mcs.anl.gov'
>> PACKAGE_NAME='parallel-netcdf'
>> PACKAGE_STRING='parallel-netcdf 1.8.1'
>> PACKAGE_TARNAME='parallel-netcdf'
>> PACKAGE_URL=''
>> PACKAGE_VERSION='1.8.1'
>> PATH_SEPARATOR=':'
>> PNETCDF_DEBUG='1'
>> PNETCDF_INC='/nobackup/parallel-netcdf-1.8.1/src/libf90'
>> PNETCDF_LIB='-L/nobackup/parallel-netcdf-1.8.1/src/lib'
>> PNETCDF_RELEASE_DATE2='2017-01-28'
>> PNETCDF_RELEASE_DATE='28 Jan 2017'
>> PNETCDF_VERSION='1.8.1'
>> PNETCDF_VERSION_MAJOR='1'
>> PNETCDF_VERSION_MINOR='8'
>> PNETCDF_VERSION_PRE=''
>> PNETCDF_VERSION_SUB='1'
>> PNF_FILL_INT64='-9223372036854775806_8'
>> PNF_FILL_UINT64='18446744073709551614_8'
>> PNF_FILL_UINT='4294967295_8'
>> PNF_INT8_MODIFIER=''
>> PNF_X_INT8_MAX='9223372036854775807_8'
>> PNF_X_INT8_MIN='-9223372036854775807_8'
>> PNF_X_UINT8_MAX='18446744073709551615_8'
>> PNF_X_UINT_MAX='4294967295_8'
>> RANLIB='ranlib'
>> RELAX_COORD_BOUND='0'
>> RM='rm'
>> SEQ_CC='/usr/bin/gcc'
>> SET_MAKE=''
>> SHELL='/bin/sh'
>> SIZEOF_MPI_AINT_IS_4='no'
>> SIZEOF_MPI_OFFSET='8'
>> TEST_MPIRUN='mpiexec -n NP'
>> TEST_OUTDIR='.'
>> TEST_SEQRUN=''
>> UPPER_CASE_MOD='no'
>> USE_MPIF_HEADER='use mpi, only: MPI_OFFSET_KIND'
>> WHATIS='whatis'
>> ac_ct_CC='/apps/developers/libraries/openmpi/2.0.2/1/intel-17.0.1/bin/mpicc'
>> ac_ct_CXX=''
>> ac_ct_F77=''
>> ac_ct_FC=''
>> ac_empty=''
>> bindir='${exec_prefix}/bin'
>> build='x86_64-unknown-linux-gnu'
>> build_alias=''
>> build_cpu='x86_64'
>> build_os='linux-gnu'
>> build_vendor='unknown'
>> datadir='${datarootdir}'
>> datarootdir='${prefix}/share'
>> docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>> dvidir='${docdir}'
>> enable_coverage='no'
>> enable_erange_fill='yes'
>> enable_subfiling='no'
>> exec_prefix='${prefix}'
>> has_fortran='yes'
>> has_latex='yes'
>> has_mpicxx='yes'
>> have_yacc_lex='no'
>> host='x86_64-unknown-linux-gnu'
>> host_alias=''
>> host_cpu='x86_64'
>> host_os='linux-gnu'
>> host_vendor='unknown'
>> htmldir='${docdir}'
>> in_place_swap='yes'
>> includedir='${prefix}/include'
>> infodir='${datarootdir}/info'
>> is_bigendian='no'
>> large_file_test='no'
>> libdir='${exec_prefix}/lib'
>> libexecdir='${exec_prefix}/libexec'
>> localedir='${datarootdir}/locale'
>> localstatedir='${prefix}/var'
>> mandir='${datarootdir}/man'
>> mpi_mod='yes'
>> oldincludedir='/usr/include'
>> pdfdir='${docdir}'
>> prefix='/nobackup/issmcd/n/build'
>> prog=''
>> program_transform_name='s,x,x,'
>> psdir='${docdir}'
>> rm_cmd=''
>> sbindir='${exec_prefix}/sbin'
>> sharedstatedir='${prefix}/com'
>> sysconfdir='${prefix}/etc'
>> target_alias=''
>> ## confdefs.h. ##
>> /* confdefs.h */
>> #define PACKAGE_NAME "parallel-netcdf"
>> #define PACKAGE_TARNAME "parallel-netcdf"
>> #define PACKAGE_VERSION "1.8.1"
>> #define PACKAGE_STRING "parallel-netcdf 1.8.1"
>> #define PACKAGE_BUGREPORT "parallel-netcdf at mcs.anl.gov"
>> #define PACKAGE_URL ""
>> #define HAVE_UINT 1
>> #define SIZEOF_SIZE_T 8
>> #define SIZEOF_OFF_T 8
>> #define SIZEOF_SIGNED_CHAR 1
>> #define SIZEOF_UNSIGNED_CHAR 1
>> #define SIZEOF_SHORT 2
>> #define SIZEOF_UNSIGNED_SHORT_INT 2
>> #define SIZEOF_UNSIGNED_SHORT 2
>> #define SIZEOF_INT 4
>> #define SIZEOF_UNSIGNED_INT 4
>> #define SIZEOF_LONG 8
>> #define SIZEOF_FLOAT 4
>> #define SIZEOF_DOUBLE 8
>> #define SIZEOF_LONG_LONG 8
>> #define SIZEOF_UNSIGNED_LONG_LONG 8
>> #define SIZEOF_USHORT 2
>> #define SIZEOF_UINT 4
>> #define NF_INT1_T integer*1
>> #define NF_INT2_T integer*2
>> #define NF_INT8_T integer*8
>> #define NF_INT1_IS_C_SIGNED_CHAR 1
>> #define NF_INT2_IS_C_SHORT 1
>> #define NF_INT8_IS_C_INT 1
>> #define NF_INT_IS_C_INT 1
>> #define NF_REAL_IS_C_FLOAT 1
>> #define NF_DOUBLEPRECISION_IS_C_DOUBLE 1
>> #define NCBYTE_T byte
>> #define NCSHORT_T integer*2
>> #define HAVE_FUNC_MACRO 1
>> #define HAVE_FUNCTION_MACRO 1
>> configure: exit 0
