Release of PnetCDF 1.9.0
Wei-keng Liao wkliao at eecs.northwestern.edu
Wed Dec 20 16:50:34 CST 2017
I just built an OpenMPI 3.0.0 with GNU 6.2.0 compilers on a Redhat but
could not reproduce the errors you are seeing.
To check whether the problem is OpenMPI related, could you try
using MPICH and see if the errors go away?
Wei-keng
On Dec 20, 2017, at 1:52 PM, Bruno Pagani wrote:
> Le 20/12/2017 à 20:15, Wei-keng Liao a écrit :
>> I notice a few environment variables that have been set before you ran
>> configure command, including CFLAGS, CPPFLAGS, CXXFLAGS, and LDFLAGS.
>> Could you try unsetting them? Or try this command:
>> ./configure --prefix=/usr --enable-shared CFLAGS="" CPPFLAGS="" CXXFLAGS="" LDFLAGS=""
> Yes, this are distro-wide flags (I’m building the official ArchLinux
> package). I’ve tried unsetting them, but building failed anyway.
>> If the above does not work, could you do the followings?
>> cd src/libs
>> Run command below and send me the screen output, file out.txt.
>> make -s clean; make V=1 >& out.txt
> Here you go: https://paste.xinu.at/I27qR/
>> Sorry for asking you to run additional commands for diagnosis, as
>> I do not have an access to GNU 7.2.1.
> No problem, that’s part of the game when you run bleeding-edge software
> chains. ;)
> Regards,
> Bruno
