Release of PnetCDF 1.9.0
Bruno Pagani bruno.pagani at astrophysics.eu
Wed Dec 20 13:52:10 CST 2017
Le 20/12/2017 à 20:15, Wei-keng Liao a écrit :
> I notice a few environment variables that have been set before you ran
> configure command, including CFLAGS, CPPFLAGS, CXXFLAGS, and LDFLAGS.
> Could you try unsetting them? Or try this command:
> ./configure --prefix=/usr --enable-shared CFLAGS="" CPPFLAGS="" CXXFLAGS="" LDFLAGS=""
Yes, this are distro-wide flags (I’m building the official ArchLinux
package). I’ve tried unsetting them, but building failed anyway.
> If the above does not work, could you do the followings?
> cd src/libs
> Run command below and send me the screen output, file out.txt.
> make -s clean; make V=1 >& out.txt
Here you go: https://paste.xinu.at/I27qR/
> Sorry for asking you to run additional commands for diagnosis, as
> I do not have an access to GNU 7.2.1.
No problem, that’s part of the game when you run bleeding-edge software
chains. ;)
Bruno
