pnetcdf-1.7.0 and MPT
Jim Edwards
jedwards at ucar.edu
Wed Sep 21 12:53:18 CDT 2016
Thanks - I'll give that a try and let you know.
On Wed, Sep 21, 2016 at 11:50 AM, Wei-keng Liao <
wkliao at eecs.northwestern.edu> wrote:
> Hi, Jim, Michael
> Eric Kemp @ NASA/GSFC also encountered a similar error message.
> http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2016-June/001854.html
> It seems like he was able to solve the problem by trying the build recipe
> in README.SGI. Let me know whether this works for you.
> Wei-keng
> On Sep 21, 2016, at 12:36 PM, Michael Raymond wrote:
> > Are you passing a count of 0? That’s probably what MPT is getting
> caught on. I can have a fix for you to try in a few minutes if so.
> > Michael A. Raymond
> > SGI MPT Team Leader
> > 1 (651) 683-7523
> >> On Sep 21, 2016, at 12:26, Jim Edwards <jedwards at ucar.edu> wrote:
> >> Trying to use parallel netcdf on an SGI system with mpi/2.14 I am
> getting the following error:
> >> MPT ERROR: rank:10, function:MPI_TYPE_CREATE_HVECTOR, Invalid argument
> >> with a traceback:
> >> MPT: #7 0x00002aaaaf46dd2a in PMPI_Type_create_hindexed
> (count=<optimized out>,
> >> MPT: blocklens=0x0, indices=0xbf71470, oldtype=27,
> newtype=0x7fffffff5588)
> >> MPT: at type_create_hindexed.c:23
> >> MPT: #8 0x0000000000cc01ac in fillerup_aggregate (ncp=0x4ff9,
> >> MPT: old_ncp=0x7fffffff4990) at fill.c:727
> >> MPT: #9 0x0000000000cb5141 in ncmpii_NC_enddef (ncp=0x4ff9,
> >> MPT: h_align=140737488308624, h_minfree=0, v_align=-1,
> v_minfree=20438,
> >> MPT: r_align=0) at nc.c:1187
> >> MPT: #10 0x0000000000cb42fb in ncmpii_enddef (ncp=0x4ff9) at nc.c:1318
> >> MPT: #11 0x0000000000ca8d7f in ncmpi_enddef (ncid=20473) at
> mpinetcdf.c:806
> >> Have you seen this before or have an idea of a fix?
> >> Thanks,
> >> Jim Edwards
> >> CESM Software Engineer
> >> National Center for Atmospheric Research
> >> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20160921/c2bb3d59/attachment.html>
More information about the parallel-netcdf
