runtime errors mpt
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Nov 10 10:47:36 CST 2016
Thanks, Jim and Michael.
FYI. The next release of PnetCDF will be ready soon.
I will add this to the release note.
Wei-keng
On Nov 10, 2016, at 10:05 AM, Jim Edwards wrote:
> It turned out to be an error in the way they installed the pnetcdf module, it's been fixed now.
> On Wed, Nov 9, 2016 at 4:55 PM, Michael Raymond <mraymond at sgi.com> wrote:
>   This is SGI MPT bug 1066364. You have a pre-release of SGI MPT 2.15, as the actual release (which has the fix) doesn’t ship until the end of the month. This bug was discussed on this list a few weeks ago.
> > On Nov 9, 2016, at 15:37 , Jim Edwards <jedwards at ucar.edu> wrote:
> > I'm using pnetcdf on an sgi system with mpt/2.15, the system support group has installed a pnetcdf-1.7.0 module that causes runtime errors in my application, but when I download from subversion and build my own pnetcdf it works fine - are you aware of any fixes that could explain this?   If so could  you tag a new version so that I can ask the system folks to install it?
> > The runtime error is:
> > 10:MPT ERROR: rank:10, function:MPI_TYPE_CREATE_HVECTOR, Invalid argument
> > Thanks,
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> Michael A. Raymond
> SGI MPT Team Leader
> 1 (651) 683-7523
> Jim Edwards
> Boulder, CO
