runtime errors mpt
Jim Edwards
jedwards at ucar.edu
Thu Nov 10 10:05:06 CST 2016
It turned out to be an error in the way they installed the pnetcdf module,
it's been fixed now.
On Wed, Nov 9, 2016 at 4:55 PM, Michael Raymond <mraymond at sgi.com> wrote:
> This is SGI MPT bug 1066364. You have a pre-release of SGI MPT 2.15, as
> the actual release (which has the fix) doesn’t ship until the end of the
> month. This bug was discussed on this list a few weeks ago.
> > On Nov 9, 2016, at 15:37 , Jim Edwards <jedwards at ucar.edu> wrote:
> > I'm using pnetcdf on an sgi system with mpt/2.15, the system support
> group has installed a pnetcdf-1.7.0 module that causes runtime errors in my
> application, but when I download from subversion and build my own pnetcdf
> it works fine - are you aware of any fixes that could explain this? If so
> could you tag a new version so that I can ask the system folks to install
> it?
> > The runtime error is:
> > 10:MPT ERROR: rank:10, function:MPI_TYPE_CREATE_HVECTOR, Invalid
> argument
> > Thanks,
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> Michael A. Raymond
> SGI MPT Team Leader
> 1 (651) 683-7523
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20161110/3702a660/attachment.html>
More information about the parallel-netcdf
