release of PnetCDF 1.8.0.pre1
Wei-keng Liao wkliao at eecs.northwestern.edu
Tue Nov 15 17:39:55 CST 2016
Hello to the PnetCDF community,
A new preview release of Parallel-netCDF 1.8.0.pre1, is now available for download.
This preview release is for the 1.8.0 release. We are sincerely soliciting
feedbacks from the PnetCDF community for this test release. The tar balls can
be downloaded from:
http://cucis.ece.northwestern.edu/projects/PnetCDF/download.html
Below is a brief list of noticeable changes.
1. Two new configure options were added: --disable-erange-fill and
   --enable-relax-coord-bound. The former is to disable the new, now default,
   feature that uses a variable's fill value for data elements that cause
   NC_ERANGE error and the latter is to enable a more relaxed boundary check
   for argument start in all APIs.
2. Use a hash function for checking whether the name of a variable or dimension
   has already been used.
3. Added pnetcdf-config shell script to display the options used in building
   PnetCDF.
4. Consistency check for header data has been moved to individual APIs and
   the check is only enabled when safe mode is on.
For detailed changes from the previous release can be found in
http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-8-0pre1/sneak_peek
Wei-keng Liao and The PnetCDF Team
