runtime errors mpt
Michael Raymond
mraymond at sgi.com
Wed Nov 9 17:55:51 CST 2016
This is SGI MPT bug 1066364. You have a pre-release of SGI MPT 2.15, as the actual release (which has the fix) doesn’t ship until the end of the month. This bug was discussed on this list a few weeks ago.
> On Nov 9, 2016, at 15:37 , Jim Edwards <jedwards at ucar.edu> wrote:
> I'm using pnetcdf on an sgi system with mpt/2.15, the system support group has installed a pnetcdf-1.7.0 module that causes runtime errors in my application, but when I download from subversion and build my own pnetcdf it works fine - are you aware of any fixes that could explain this? If so could you tag a new version so that I can ask the system folks to install it?
> The runtime error is:
> 10:MPT ERROR: rank:10, function:MPI_TYPE_CREATE_HVECTOR, Invalid argument
> Thanks,
> Jim Edwards
> CESM Software Engineer
> National Center for Atmospheric Research
> Boulder, CO
Michael A. Raymond
SGI MPT Team Leader
1 (651) 683-7523
More information about the parallel-netcdf
