Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Fri Sep 18 17:15:41 CDT 2015
Hi, Craig
Could you send us your config.log file?
Wei-keng
On Sep 18, 2015, at 4:57 PM, Craig Tierney - NOAA Affiliate wrote:
> Hello,
> I am trying to build Pnetcdf 1.6.1 with Intel 15.0.3.048 and Mvapich2 2.1. I am getting some failures in the tests. I so far am getting 4 failures. The flash-io test fails and the make process exits. When I build Pnetcdf 1.6.1 with Intel 15.0.3.048 and Intel MPI 5.1.1.109, all tests complete cleanly.
> Are there known issues with Pnetcdf 1.6.1 and Mvapich2 2.1?
> Thanks,
> Craig
> ./nc_test -d /lfs3/jetmgmt/Craig.Tierney
> FAILURE at line 112 of test_read.c: ncmpi_open of non-netCDF file: status = -220
> ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
> ./nc_test: expects 0 failures ... Total number of failures: 1
> *** TESTING C ./nc_test for format CDF-1 ------ failed
> And:
> *** TESTING C ./varn_int for ncmpi_put_varn_int_all() ------ pass
> Error: expect error code -220 but got -51
> *** TESTING C ./modes for file create/open modes ------ failed
> *** TESTING C ./one_record for only one record variable ------ pass
> Also:
> Error at line=71: NetCDF: Not a valid ID
> Error at line=72: NetCDF: Not a valid ID
> Error at line=69: NetCDF: Not a valid ID
> *** TESTING C ./wait_after_indep for ncmpi_end_indep_data ------ fail
> Lastly:
> make -w -C FLASH-IO ptest
> make[2]: Entering directory `/misc/whome/admin/software/pnetcdf/parallel-netcdf-1.6.1-intel-mvapich2/benchmarks/FLASH-IO'
> mpiexec.hydra -np 4 ./flash_benchmark_io /lfs3/jetmgmt/Craig.Tierney/flash_io_test_
> nfmpi_enddef
> (Internal error) beginning file offset of this variable is inconsistent among p
> r
> nfmpi_enddef
> r
> nfmpi_enddef
> r
> [cli_1]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
> [cli_2]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
> [cli_3]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = PID 9284 RUNNING AT fe1
> = EXIT CODE: 255
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> make[2]: *** [ptest] Error 255
More information about the parallel-netcdf
