pnetcdf port to nag/6.0
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Sep 4 17:20:30 CDT 2015
Hi, Jim,
Is NAG compiler OK with _8 modifier?
Could you try manually change 4294967295 to 4294967295_8 and see if it compiles?
Wei-keng
On Sep 4, 2015, at 3:12 PM, Jim Edwards wrote:
> Actually I still have a problem and I'm not sure how it should be resolved...
> Error: ../../src/libf/pnetcdf.inc, line 79: Integer literal 4294967295 too large for default KIND
> Error: ../../src/libf/pnetcdf.inc, line 80: Integer literal 9223372036854775806 too large for default KIND
> Warning: mcoll_testf77.f, line 30: Unused PARAMETER NREADS
> Errors in declarations, no further processing for MCOLL_TESTF
> I'm not sure of an F77 conformant way to define these constants - are you?
> On Fri, Sep 4, 2015 at 1:39 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> Thanks, Jim. I have applied your patch.
> I do not have an access to a NAG compiler.
> Please check it builds and tests fine.
> Wei-keng
> On Sep 4, 2015, at 11:49 AM, Jim Edwards wrote:
> > Here is a patch for pnetcdf R2088 to the nag/6.0 compiler.   I also needed a compiler flag           -mismatch_all to turn errors about data type mismatches into warnings.
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> > <pnetcdfR2088.nag6port>
> Jim Edwards
> Boulder, CO
