pnetcdf port to nag/6.0
Jim Edwards jedwards at ucar.edu
Fri Sep 4 15:12:14 CDT 2015
Actually I still have a problem and I'm not sure how it should be
resolved...
Error: ../../src/libf/pnetcdf.inc, line 79: Integer literal 4294967295 too
large for default KIND
Error: ../../src/libf/pnetcdf.inc, line 80: Integer literal
9223372036854775806 too large for default KIND
Warning: mcoll_testf77.f, line 30: Unused PARAMETER NREADS
Errors in declarations, no further processing for MCOLL_TESTF
I'm not sure of an F77 conformant way to define these constants - are you?
On Fri, Sep 4, 2015 at 1:39 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu>
wrote:
> Thanks, Jim. I have applied your patch.
> I do not have an access to a NAG compiler.
> Please check it builds and tests fine.
> Wei-keng
> On Sep 4, 2015, at 11:49 AM, Jim Edwards wrote:
> > Here is a patch for pnetcdf R2088 to the nag/6.0 compiler.   I also
> needed a compiler flag           -mismatch_all to turn errors about data
> type mismatches into warnings.
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> > <pnetcdfR2088.nag6port>
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150904/e0fa62d4/attachment.html>
