pnetcdf port to nag/6.0
Jim Edwards
jedwards at ucar.edu
Fri Sep 4 17:27:24 CDT 2015
No it doesn't like _8 either - here is a patch that fixes that problem -
I also tested it with pgi.
Now I have another error but it'll wait until next week, have a great
weekend.
(here is the other error, haven't looked into it at all yet...)
Error: mcoll_testf77.f, line 497: Inconsistent structure for arg 2 in call
to MPI_ALLREDUCE
Error: mcoll_testf77.f, line 499: Inconsistent structure for arg 2 in call
to MPI_ALLREDUCE
On Fri, Sep 4, 2015 at 4:20 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu>
wrote:
> Hi, Jim,
> Is NAG compiler OK with _8 modifier?
> Could you try manually change 4294967295 to 4294967295_8 and see if it
> compiles?
> Wei-keng
> On Sep 4, 2015, at 3:12 PM, Jim Edwards wrote:
> > Actually I still have a problem and I'm not sure how it should be
> resolved...
> > Error: ../../src/libf/pnetcdf.inc, line 79: Integer literal 4294967295
> too large for default KIND
> > Error: ../../src/libf/pnetcdf.inc, line 80: Integer literal
> 9223372036854775806 too large for default KIND
> > Warning: mcoll_testf77.f, line 30: Unused PARAMETER NREADS
> > Errors in declarations, no further processing for MCOLL_TESTF
> > I'm not sure of an F77 conformant way to define these constants - are
> you?
> > On Fri, Sep 4, 2015 at 1:39 PM, Wei-keng Liao <
> wkliao at eecs.northwestern.edu> wrote:
> > Thanks, Jim. I have applied your patch.
> > I do not have an access to a NAG compiler.
> > Please check it builds and tests fine.
> > Wei-keng
> > On Sep 4, 2015, at 11:49 AM, Jim Edwards wrote:
> > > Here is a patch for pnetcdf R2088 to the nag/6.0 compiler. I also
> needed a compiler flag -mismatch_all to turn errors about data
> type mismatches into warnings.
> > > Jim Edwards
> > > CESM Software Engineer
> > > National Center for Atmospheric Research
> > > Boulder, CO
> > > <pnetcdfR2088.nag6port>
> > Jim Edwards
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150904/bd623b2b/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150904/bd623b2b/attachment.obj>
More information about the parallel-netcdf
