PNetCDF problem
HLung at us.fujitsu.com HLung at us.fujitsu.com
Wed Nov 11 20:39:53 CST 2015
Hi Wei-keng,
Thanks so much for your quick response.  I will try the latest 1.6.1 version and see how it works.
Best regards,
Han
-----Original Message-----
From: Wei-keng Liao [mailto:wkliao at eecs.northwestern.edu]
Sent: Wednesday, November 11, 2015 5:39 PM
To: Lung, Han
Cc: parallel-netcdf at lists.mcs.anl.gov
Subject: Re: PNetCDF problem
Hi, Han
Thanks for reporting the problem you are encountering.
Since PnetCDF 1.3.0 is quite old now (more than 3 years), I wonder if you can try 1.6.1, the latest stable release. ncx.c has had a significant revision since 1.3.0.
We do not have access to Fujitsu compilers. I would not be surprised by problems on your environment. Actually, I was recently informed the same BUS_ADRALN error was observed when using Fujitsu compilers. I am in the process of getting an account on a machine with Fujitsu compilers, so I can debug this issue. Before I can do anything, could you at least try 1.6.1? Thanks.
Wei-keng
On Nov 11, 2015, at 6:42 PM, hlung at us.fujitsu.com wrote:
> Hi,
> This is Han Lung, Director of HPC Group, Fujitsu America, Inc.
> I am working on WRF 3.7+PNetcdf 1.3.0 and got some errors.  The test case is conus12km.
> I was told by wrfhelp that this error is related to internal of PNetCDF, so I am writing to you and hope I can get some help from you.
> I traced the error to ncmpix_put_size_t(void  **xpp, const MPI_Offset   lp, int sizeof_t) in ncx.c of parallel-netcdf-1.3.0.  Here is the part of the code that caused the error:
> #ifdef WORDS_BIGENDIAN
>         MPI_Offset *ptr = (MPI_Offset*) (*xpp); /* typecast to 8-byte integer */
>         *ptr = lp;    ç error here
> #else
> This is an operation for 8-byte integer lp (sizeof_t = 8).  However,
> *xpp is incremented each time by 4 or 8, depending on sizeof_t:  *xpp
> = (void *)((char *)(*xpp) + sizeof_t);
> Now when *xpp is not on 8-byte boundary (due to previous operation of 4-byte increment) the operation "*ptr = lp;" will cause the address not aligned error (BUS_ADRALN).
> In my case, for most of the time, sizeof_t is 4, and there is no problem.  The first two times when sizeof_t is 8, *xpp is 591725472 and 591725720, respectively, which are at 8-byte boundary, so there is no problem, either.  The third time when sizeof_t is 8, *xpp is 591725972, which is not at 8-byte boundary, and that caused the problem.
> I modified ncx.c to pad a 4-byte space if it's not on 8-byte boundary.  It did solve this mis-alignment problem but died at the free() call later.  I am also not sure if this padding is a right approach since the padded parts are all garbage.
> Do you see this kind of error before?  Any advice on how to resolve it?
> Thanks,
> Han
