input/output errors from "make check"
Wei-keng Liao wkliao at eecs.northwestern.edu
Wed May 27 18:41:53 CDT 2015
Those MPI error messages are expected if you are using OpenMPI or older versions of MPICH.
This error happens when trying to delete a non-existing file.
A correct MPI implementation should return MPI_ERR_NO_SUCH_FILE, instead of MPI_ERR_IO.
This has been fixed in the MPI-IO part of the latest MPICH release.
OpenMPI is copying the MPI-IO part of MPICH and has not updated to the latest yet.
You can safely ignore those error messages.
However, you should see the same error messages when testing C programs, i.e. nc_test.
Is it not the case for you?
As for the issue you encountered when using PGI compilers, can you send me the file config.log and show me the standard output on screen where the program hangs?
A successful run of "make check" should look like below.
Are you saying it does not show this first line when entering directory nf90_test?
*** TESTING F90 ./nf90_test for CDF-1                              ------ pass
make[1]: Entering directory `... /PnetCDF/test/nf_test'
/bin/rm -f ./scratch.nc ./test.nc
./nf_test -c    -d .
./nf_test       -d .
*** TESTING F77 ./nf_test for CDF-1                                ------ pass
./nf_test -c -2 -d .
./nf_test -2    -d .
*** TESTING F77 ./nf_test for CDF-2                                ------ pass
./nf_test -c -5 -d .
./nf_test -5    -d .
*** TESTING F77 ./nf_test for CDF-5                                ------ pass
make[1]: Leaving directory `... /PnetCDF/test/nf_test'
make  -C nf90_test testing
make[1]: Entering directory `... /PnetCDF/test/nf90_test'
./nf90_test -c    -d .
./nf90_test       -d .
./nf90_test -c -2 -d .
./nf90_test -2    -d .
*** TESTING F90 ./nf90_test for CDF-2                              ------ pass
./nf90_test -c -5 -d .
./nf90_test -5    -d .
*** TESTING F90 ./nf90_test for CDF-5                              ------ pass
make[1]: Leaving directory `... /PnetCDF/test/nf90_test'
Wei-keng
On May 27, 2015, at 5:41 PM, Carl Ponder wrote:
> I'm building HPC tools on a shared cluster, and trying to "bulletproof" them as much as possible by enabling all the capabilities and running all the built-in validation tests.
> In this case I'm building PNetCDF 1.6.0 using OpenMPI 1.8.5 and GCC/5.1.0.
> Here are some oddities from the "make check" that I ran:
> ./nf_test       -d .
> rank 0: MPI error (MPI_File_delete) : MPI_ERR_IO: input/output error
> ./nf_test -2    -d .
> ./nf_test -5    -d .
> ./nf90_test       -d .
> ./nf90_test -2    -d .
> ./nf90_test -5    -d .
> So the tests are listed as passing, but the messages indicate that an error had occurred.
> Are there any global MPI settings that I need to make in order for these tests to work?
> Or did these tests really run OK?
> Also when I used the PGI 15.5 compiler instead of the GCC compiler, I got similar messages on the F77 tests.
> But when it started the first F90 test, it hanged.
> This email message is for the sole use of the intended recipient(s) and may contain confidential information.  Any unauthorized review, use, disclosure or distribution is prohibited.  If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
