input/output errors from "make check"
Carl Ponder cponder at nvidia.com
Wed May 27 17:41:17 CDT 2015
I'm building HPC tools on a shared cluster, and trying to "bulletproof"
them as much as possible by enabling all the capabilities and running
all the built-in validation tests.
In this case I'm building PNetCDF 1.6.0 using OpenMPI 1.8.5 and GCC/5.1.0.
Here are some oddities from the "make check" that I ran:
    ./nf_test       -d .
    rank 0: MPI error (MPI_File_delete) : MPI_ERR_IO: input/output error
    *** TESTING F77 ./nf_test for CDF-1
    ------ pass
    ./nf_test -c -2 -d .
    ./nf_test -2    -d .
    *** TESTING F77 ./nf_test for CDF-2
    ------ pass
    ./nf_test -c -5 -d .
    ./nf_test -5    -d .
    *** TESTING F77 ./nf_test for CDF-5
    ------ pass
    ./nf90_test       -d .
    *** TESTING F90 ./nf90_test for CDF-1
    ------ pass
    ./nf90_test -c -2 -d .
    ./nf90_test -2    -d .
    *** TESTING F90 ./nf90_test for CDF-2
    ------ pass
    ./nf90_test -c -5 -d .
    ./nf90_test -5    -d .
    *** TESTING F90 ./nf90_test for CDF-5
    ------ pass
So the tests are listed as passing, but the messages indicate that an
error had occurred.
Are there any global MPI settings that I need to make in order for these
tests to work?
Or did these tests really run OK?
Also when I used the PGI 15.5 compiler instead of the GCC compiler, I
got similar messages on the F77 tests.
But when it started the first F90 test, it hanged.
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150527/c73fb624/attachment.html>
