File header is inconsistent among processes
Sean Byland seanb at cray.com
Fri Sep 19 14:39:50 CDT 2014
Wei-keng, Rob,
Thanks for the info. When I get the users qsub script (a job launching
script), I’ll try looking at the headers with ncmpidump and check the
output of PNETCDF_SAFE_MODE for any useful information. This gives me a
good starting point. I’ll reply back once I have more information
(hopefully a solution).
Sean B
On 9/19/14, 1:53 PM, "Wei-keng Liao" <wkliao at eecs.northwestern.edu> wrote:
>Hi, Sean
>This error means the metadata (dimension names, variable names,
>variable's dimensions,
>attributes, and whatever will be stored in the file header) is
>inconsistent among all
>MPI processes.
>Starting from 1.5.0, users can set the environment variable
>PNETCDF_SAFE_MODE to 1
>to enable the internal checking for header consistency. So, by doing that
>you might get additional information about what metadata is inconsistent.
>Wei-keng
>On Sep 19, 2014, at 12:54 PM, Sean Byland wrote:
>> Hello,
>> A parallel-netcdf user gets this error:
>>   NetCDF error: File header is inconsistent among processes
>>   NetCDF error ( -250 ) from NFMPI_ENDDEF in
>>ext_pnc_open_for_write_commit wrf_io.F90, line 1360
>>  med_restart_out: opening wrfrst_d01_2013-06-01_00_10_00 for writing
>> when running  software/parallel-netcdf (1.5.0) libraries that were
>>built with CCE but doesn’t with an application/library that were built
>>with Intel’s compiler. I’m still waiting on the user for something that
>>I need to reproduce the error and start experimenting but was hoping
>>that someone on this mailing list might have some useful information or
>>hints about what’s causing this error and how I might fix it (or where I
>>might look). All of the “make check” test pass. Thanks for any input.
>> Sean B
