File header is inconsistent among processes
Wei-keng Liao
wkliao at eecs.northwestern.edu
Fri Sep 19 13:53:48 CDT 2014
Hi, Sean
This error means the metadata (dimension names, variable names, variable's dimensions,
attributes, and whatever will be stored in the file header) is inconsistent among all
MPI processes.
Starting from 1.5.0, users can set the environment variable PNETCDF_SAFE_MODE to 1
to enable the internal checking for header consistency. So, by doing that
you might get additional information about what metadata is inconsistent.
Wei-keng
On Sep 19, 2014, at 12:54 PM, Sean Byland wrote:
> Hello,
> A parallel-netcdf user gets this error:
> NetCDF error: File header is inconsistent among processes
> NetCDF error ( -250 ) from NFMPI_ENDDEF in ext_pnc_open_for_write_commit wrf_io.F90, line 1360
> med_restart_out: opening wrfrst_d01_2013-06-01_00_10_00 for writing
> when running software/parallel-netcdf (1.5.0) libraries that were built with CCE but doesn’t with an application/library that were built with Intel’s compiler. I’m still waiting on the user for something that I need to reproduce the error and start experimenting but was hoping that someone on this mailing list might have some useful information or hints about what’s causing this error and how I might fix it (or where I might look). All of the “make check” test pass. Thanks for any input.
> Sean B
More information about the parallel-netcdf
