pnetcdf test
BasitAli Khan
BasitAli.Khan at kaust.edu.sa
Wed May 28 07:05:43 CDT 2014
Hi there,
I am new to pnetcdf. I want to compile it for faster IO of WRF model on our bluegeneP with Linux RedHat 10 on it. I apparently successfully installed the latest version of pnetcdf 1.4.1, however when i run 'make testing', i got few errors (log file attached). I would greatly appreciate if you could have a look and advise where i am going wrong.
The compilation of parallel netcdf created 4 directories. The contents of these dir are as follows:
/lib/libpnetcdf.a
/include/pnetcdf.h pnetcdf.inc pnetcdf.mod
/bin/ncmpidiff ncmpidump ncmpigen ncmpivalid
/man/man1/ncmpidiff.1 ncmpidump.1 ncmpigen.1 ncmpivalid.1
/man/man3/pnetcdf.3 pnetcdf_f77.3 pnetcdf_f90.3
Another question is that, do i have to do anything special to use it with WRF?
Thanks in advance and best regards,
b:)
Basit A. Khan, Ph.D.
Postdoctoral Research Fellow
Division of Physical Sciences & Engineering
Office# 3204, Level 3, Building 1,
King Abdullah University of Science & Technology
4700 King Abdullah Blvd, Box 2753, Thuwal 23955 –6900,
Kingdom of Saudi Arabia.
Office: +966(0)12 808 0276, Mobile: +966(0)5 0860 3617
E-mail: basitali.khan at kaust.edu.sa<mailto:basitali.khan at kaust.edu.sa>
Skype name: basit.a.khan
This message and its contents including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140528/c5782fac/attachment.html>
Desc: test.log
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140528/c5782fac/attachment.obj>
More information about the parallel-netcdf
