pnetcdf test
Rob Latham robl at mcs.anl.gov
Wed May 28 08:52:49 CDT 2014
On 05/28/2014 07:05 AM, BasitAli Khan wrote:
> Hi there,
> I am new to pnetcdf. I want to compile it for faster IO  of WRF model on
> our bluegeneP with Linux RedHat 10 on it. I apparently successfully
> installed the latest version of pnetcdf 1.4.1, however when i run  'make
> testing', i got few errors (log file attached).  I would greatly
> appreciate if you could have a look and advise where i am going wrong.
Pnetcdf's 'make testing' assumes you build and run on the same platform.
  On BGQ, that's not the case.  I'm pleased you found README.IBM, where
you must have found the instructions for how to cross-compile
parallel-netcdf.  Now you have executables that must run on the compute
nodes, not the login nodes.
I don't know Kaust's setup for job submission, but you'll have to pick a
few tests and run them by hand on the compute nodes.
==rob
> The compilation of parallel netcdf created 4 dectories. The contents
> of these dir are as follows:
> /lib/libpnetcdf.a
> /include/pnetcdf.h  pnetcdf.inc  pnetcdf.mod
> /bin/ncmpidiff  ncmpidump  ncmpigen  ncmpivalid
> /man/man1/ncmpidiff.1  ncmpidump.1  ncmpigen.1  ncmpivalid.1
> /man/man3/pnetcdf.3  pnetcdf_f77.3  pnetcdf_f90.3
> Another question is that, do i have to do anything special to use it
> with WRF?
> Thanks in advance and best regards,
> b:)
> Basit A. Khan, Ph.D.
> Postdoctoral Research Fellow
> Division of Physical Sciences & Engineering
> Office# 3204, Level 3, Building 1,
> King Abdullah University of Science & Technology
> 4700 King Abdullah Blvd, Box 2753, Thuwal 23955 –6900,
> Kingdom of Saudi Arabia.
> Office: +966(0)12 808 0276,  Mobile: +966(0)5 0860 3617
> E-mail: basitali.khan at kaust.edu.sa <mailto:basitali.khan at kaust.edu.sa>
> Skype name: basit.a.khan
> This message and its contents including attachments are intended solely
> for the original recipient. If you are not the intended recipient or
> have received this message in error, please notify me immediately and
> delete this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before
> printing this email.
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
