use of mpi derived data types in nfmpi_iput_vara
Jim Edwards
jedwards at ucar.edu
Tue Feb 12 13:47:08 CST 2013
Hi Rob,
I want to make sure that my mpi datatype is correct so I am working on an
mpi-io binary version of the
same case, once I have that working I'll try pnetcdf again and if it's
still a problem I'll send you the
datatype dump.
- Jim
On Tue, Feb 12, 2013 at 9:26 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Tue, Feb 12, 2013 at 08:49:20AM -0700, Jim Edwards wrote:
> > Are there any limitations to the data type passed to nfmpi_iput_vara? I
> > am trying to create a
> > type using mpi_type_create_subarray and pass it to nfmpi_iput_vara and I
> am
> > getting an error
> > with traceback:
> > #10 0x00002b06f5f90ce3 in PMPI_Pack () from
> > /opt/ibmhpc/pe1209/mpich2/gnu/lib64/libmpich.so.3
> > #11 0x00000000005c9d2f in ncmpii_data_repack ()
> > #12 0x00000000005b4532 in ncmpii_igetput_varm ()
> > #13 0x00000000005969ed in ncmpi_iput_vara ()
> > Is this a possible bug in parallel-netcdf or are my assumptions about
> usage
> > incorrect?
> Wow, an error from MPI_Pack... and one that causes a traceback.
> and it's IBM's MPI_Pack, sort of, by way of MPICH.
> So, you've caused some surprise here.
> Can you share the type with us? Or, if it's hard to capture (because
> it's generated algorithmically) you might, depending on how IBM built
> their MPI, have access to the c routine MPIDU_Datatype_debug:
> MPIDU_Datatype_debug(MPI_Datatype type, int array_ct)
> (128 should be big enough for array_ct)
> and that should spit out a bunch of information about the datatype:
> enough that I could re-create it and see if other MPI implementations
> choke when packing it.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130212/a879152b/attachment.html>
More information about the parallel-netcdf
