use of mpi derived data types in nfmpi_iput_vara
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Feb 12 14:13:40 CST 2013
Hi, Jim,
I just now fixed a bug that is related to using the flexible APIs.
Please see r1159. However, the error message you got does not seem
to relate to this bug. Anyway, if you figure out the MPI derived data
type issue, you will still encounter this bug. So, please apply this
patch.
I also added 2 new examples (C and Fortran) for using the flexible APIs.
See examples/flex.c and examples/flex_f.F They both call
MPI_Type_create_subarray() to create their buffer type.
Please note that in Fortran, the array indices for MPI functions start with 1.
Wei-keng
On Feb 12, 2013, at 1:47 PM, Jim Edwards wrote:
> Hi Rob,
> I want to make sure that my mpi datatype is correct so I am working on an mpi-io binary version of the
> same case, once I have that working I'll try pnetcdf again and if it's still a problem I'll send you the
> datatype dump.
> - Jim
> On Tue, Feb 12, 2013 at 9:26 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Tue, Feb 12, 2013 at 08:49:20AM -0700, Jim Edwards wrote:
> > Are there any limitations to the data type passed to nfmpi_iput_vara?   I
> > am trying to create a
> > type using mpi_type_create_subarray and pass it to nfmpi_iput_vara and I am
> > getting an error
> > with traceback:
> > #10 0x00002b06f5f90ce3 in PMPI_Pack () from
> > /opt/ibmhpc/pe1209/mpich2/gnu/lib64/libmpich.so.3
> > #11 0x00000000005c9d2f in ncmpii_data_repack ()
> > #12 0x00000000005b4532 in ncmpii_igetput_varm ()
> > #13 0x00000000005969ed in ncmpi_iput_vara ()
> > Is this a possible bug in parallel-netcdf or are my assumptions about usage
> > incorrect?
> Wow, an error from MPI_Pack... and one that causes a traceback.
> and it's IBM's MPI_Pack, sort of, by way of MPICH.
> So, you've caused some surprise here.
> Can you share the type with us?  Or, if it's hard to capture (because
> it's generated algorithmically) you might, depending on how IBM built
> their MPI, have access to the c routine MPIDU_Datatype_debug:
>  MPIDU_Datatype_debug(MPI_Datatype type, int array_ct)
> (128 should be big enough for array_ct)
> and that should spit out a bunch of information about the datatype:
> enough that I could re-create it and see if other MPI implementations
> choke when packing it.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
