nfmpi_put_var_char expected behavior?
Jim Edwards jedwards at ucar.edu
Wed Aug 1 12:39:52 CDT 2012
This also happens in the installed parallel-netcdf/1.2.0  but not in the
serial netcdf/4.1.3
On Wed, Aug 1, 2012 at 10:27 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> If I declare a character string variable with a length x and then write a
> string of length y<x using nfmpi_put_var_char
> what is the expected behavior?     I think that what I am getting is
> incorrect (a bunch of garbage in the string from y:x )
> So for example I want to write string './none/foo.009.nc' into a variable
> of length 80.    In the file I am getting:
> './none/foo.009.nc 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> 0 0 0 0'
> I think that this is a bug.
> This is happening with the latest pnetcdf svn trunk code on jaguarpf
> compiled using:
> Currently Loaded Modulefiles:
>   1) modules/3.2.6.6                      10)
> xpmem/0.1-2.0400.31280.3.1.gem       19) DefApps
>   2) xtpe-network-gemini                  11)
> xe-sysroot/4.0.46                    20) altd/1.0
>   3) pgi/12.5.0                           12)
> xt-asyncpe/5.11                      21) subversion/1.6.17
>   4) xt-libsci/11.1.00                    13)
> atp/1.4.1                            22) szip/2.1
>   5) udreg/2.3.2-1.0400.5038.0.0.gem      14)
> PrgEnv-pgi/4.0.46                    23) hdf5/1.8.7
>   6) ugni/2.3-1.0400.4374.4.88.gem        15)
> xt-mpich2/5.5.0                      24) netcdf/4.1.3
>   7) pmi/3.0.0-1.0000.8661.28.2807.gem    16)
> xtpe-interlagos                      25) esmf/5.2.0rp1
>   8) dmapp/3.2.1-1.0400.4782.3.1.gem      17) eswrap/1.0.9
>   9) gni-headers/2.1-1.0400.4351.3.1.gem  18) lustredu/1.0
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
Jim Edwards
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120801/22e5b9f3/attachment.html>
