nfmpi_put_var_char expected behavior?
Wei-keng Liao
wkliao at ece.northwestern.edu
Wed Aug 1 20:58:17 CDT 2012
Hi, Jim
NetCDF's default for fill mode is NC_FILL and the default fill value for char type
is NC_FILL_CHAR == (char)0. See netCDF user guide below.
http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c.html#nc_005fset_005ffill
http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c.html#Fill-Values
In PnetCDF, only NC_NOFILL is implemented. So, for those spaces that were not
written by the application, their contents are undefined.
Wei-keng
On Aug 1, 2012, at 11:27 AM, Jim Edwards wrote:
> If I declare a character string variable with a length x and then write a string of length y<x using nfmpi_put_var_char
> what is the expected behavior? I think that what I am getting is incorrect (a bunch of garbage in the string from y:x )
> So for example I want to write string './none/foo.009.nc' into a variable of length 80. In the file I am getting:
> './none/foo.009.nc 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0'
> I think that this is a bug.
> This is happening with the latest pnetcdf svn trunk code on jaguarpf compiled using:
> Currently Loaded Modulefiles:
> 1) modules/3.2.6.6 10) xpmem/0.1-2.0400.31280.3.1.gem 19) DefApps
> 2) xtpe-network-gemini 11) xe-sysroot/4.0.46 20) altd/1.0
> 3) pgi/12.5.0 12) xt-asyncpe/5.11 21) subversion/1.6.17
> 4) xt-libsci/11.1.00 13) atp/1.4.1 22) szip/2.1
> 5) udreg/2.3.2-1.0400.5038.0.0.gem 14) PrgEnv-pgi/4.0.46 23) hdf5/1.8.7
> 6) ugni/2.3-1.0400.4374.4.88.gem 15) xt-mpich2/5.5.0 24) netcdf/4.1.3
> 7) pmi/3.0.0-1.0000.8661.28.2807.gem 16) xtpe-interlagos 25) esmf/5.2.0rp1
> 8) dmapp/3.2.1-1.0400.4782.3.1.gem 17) eswrap/1.0.9
> 9) gni-headers/2.1-1.0400.4351.3.1.gem 18) lustredu/1.0
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
More information about the parallel-netcdf
