nfmpi_put_var_char expected behavior?
Jim Edwards
jedwards at ucar.edu
Wed Aug 1 11:27:25 CDT 2012
If I declare a character string variable with a length x and then write a
string of length y<x using nfmpi_put_var_char
what is the expected behavior? I think that what I am getting is
incorrect (a bunch of garbage in the string from y:x )
So for example I want to write string './none/foo.009.nc' into a variable
of length 80. In the file I am getting:
'./none/foo.009.nc 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0'
I think that this is a bug.
This is happening with the latest pnetcdf svn trunk code on jaguarpf
compiled using:
Currently Loaded Modulefiles:
1) modules/3.2.6.6 10)
xpmem/0.1-2.0400.31280.3.1.gem 19) DefApps
2) xtpe-network-gemini 11)
xe-sysroot/4.0.46 20) altd/1.0
3) pgi/12.5.0 12)
xt-asyncpe/5.11 21) subversion/1.6.17
4) xt-libsci/11.1.00 13)
atp/1.4.1 22) szip/2.1
5) udreg/2.3.2-1.0400.5038.0.0.gem 14)
PrgEnv-pgi/4.0.46 23) hdf5/1.8.7
6) ugni/2.3-1.0400.4374.4.88.gem 15)
xt-mpich2/5.5.0 24) netcdf/4.1.3
7) pmi/3.0.0-1.0000.8661.28.2807.gem 16)
xtpe-interlagos 25) esmf/5.2.0rp1
8) dmapp/3.2.1-1.0400.4782.3.1.gem 17) eswrap/1.0.9
9) gni-headers/2.1-1.0400.4351.3.1.gem 18) lustredu/1.0
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120801/5fd8c23f/attachment.html>
More information about the parallel-netcdf
